Old 09-20-2019, 02:55 PM   #15
Originally Posted by marco1ca View Post
Tell that to the owners whose cars blew up.
They didn't have tests done that say all is fine.
Bullshit! They caused the paranoia by forcing Californians to do an otherwise unnecessary recall.
Subaru didn't force anybody. The State of California did.
Your tests are fine. You have over 5,000 miles since the work was done. Relax!
Grady (09-20-2019), soundman98 (09-24-2019)
Old 09-20-2019, 02:55 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The issue that blew out engines were not things in the oil, they were insolubles that clogged passages for that very reason.
He's also curious as to why when you're being told test results, you don't believe the report. Don't ask for help if you don't want it
Old 09-20-2019, 04:08 PM   #17
marco1ca
Drives: Toyota Celica
Not believing and getting 2nd opinions are two different things. This is all i'm doing. There are very knowledgable people on this board I appreciate and trust. All I did was share this information and with you to verify. Thanks
marco1ca is offline   Reply With Quote
Old 09-20-2019, 04:21 PM   #18
You asked for "comments and suggestions".
My comment is that you have a valid test result from a respected company that says "No problem". Looking for support or rejection of that report from a bunch of guys with dubious qualifications is not going to help anything..
My suggestion is to take that good report, relax and enjoy your car. The oil looks good, you have 5K trouble free miles and no issues. Fretting and second guessing some slightly elevated silicon results isn't going to get you anyplace.
Grady (09-20-2019), gravitylover (09-25-2019), marco1ca (09-20-2019), soundman98 (09-24-2019)
Old 09-20-2019, 07:08 PM   #19
Grady
Grady's Avatar
I just can not wrap my head around the fact that this is even being discussed. Why bother to have a test done if you can't believe the report?
I agree!
Oil analysis are worthless one time. They are for looking for a change in the norm.
The Following User Says Thank You to Grady For This Useful Post:
Old 09-23-2019, 11:08 AM   #20
MaverickMonk
Drives: 13 BRZ Limited
So I didn't post this in "failure" thread or "no failure thread" as I"m not sure yet.
'13 BRZ, 1800 mi. post recall work. Just received oil analysis report (attached)
and could use input on the silicon level. Silicon level states "63" when the average is '26'.
Here's what I don't understand; I spoke with analysis from Blackstone who said this is normal for an engine that just had this type of recall work. I explained to him that too much sealer has been linked to the cause of many engines blowing up. He hadn't heard of this but is now researching it. He also said that brand new vehicles from factory will test higher levels of silicon than mine, but it should dissipate by the next oil change. Just wanted to share this test result and hear any comments or suggestions, thank you
I too had high silicon (94) and Iron (24), and I was also told this was normal. Silicon in the oil isn't what causes problems post recall. Chunks of silicon breaking off causes the failure. Silicon trace in the oil is from offgassing, which will occur any time new silicon is used.
I think we're gonna be ok man.
https://imgur.com/a/EveNAmj
MaverickMonk is offline   Reply With Quote
The Following 2 Users Say Thank You to MaverickMonk For This Useful Post:
marco1ca (09-23-2019), Tcoat (09-23-2019)
Old 09-23-2019, 06:29 PM   #21
marco1ca
Thank you; Blackstone just emailed to thank me because they were not aware of the recall issues. They said the same as you and others on here as to the cause. (this is a great board for info!)
They did recommend, however, I should do another one to check for bearing wear, which may be a sign of trouble.
Old 09-23-2019, 06:34 PM   #22
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Post Recall Blackstone Report
My post recall test came in pretty clean, only 2000 miles though
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
marco1ca (09-23-2019), radroach (09-23-2019)
Old 09-23-2019, 07:49 PM   #23
Decep
Drives: 2013 FR-S Series 10
chunks of siliconE, not silicon.
https://www.blackstone-labs.com/the-...ljinbhlr1))%2f Interesting write up here for OP.
Old 09-23-2019, 11:06 PM   #24
MaverickMonk
Originally Posted by Yoshoobaroo View Post
My post recall test came in pretty clean; only 2000 miles though
As a side note, @MaverickMonk my iron wear has always been on the higher side, it’s an engine that likes to rev high, so 24ppm is along the lines of normal. The OEM 0W20 doesn’t help. My iron wear was pretty much cut in half by switching to 0W30 and shortening my interval from 7500 to 5000 miles. (42ppm to 23 and then 18ppm)
Yeah I’m not terribly concerned, I have a rather intense 10+ run autoX novice school on there, as well as a fairly punishing short commute. I expected iron to be high in general.
This may come as a shock to you, but I dropped out of journalism school partly due to my atrocious spelling.
How long is too long for post-recall repair? ndsleep612 Issues | Warranty | Recalls / TSB 2 08-04-2019 06:35 PM
HORRIBLE GAS MILEAGE POST RECALL (ಥ﹏ಥ) ¯\(°_o)/¯ mswbrz Issues | Warranty | Recalls / TSB 14 08-02-2019 06:38 PM
Loud ticking post recall fix Outlander Issues | Warranty | Recalls / TSB 27 07-16-2019 01:11 AM
She lives once more! (post-recall damage) BlackOptics Northwest 9 03-22-2019 07:53 AM
