Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-31-2019, 10:22 AM | #15 | |
Drives: 2017_86 2016_frs 2007_335i
yea, there r many way to get cambers but i am more worried about clearances as pic showed any experience for clearances on 17x8 +45 with 245 40 17 with camber?
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
07-31-2019, 11:54 AM | #16 |
Country Boy 4 Life
I think you will need at least a 10mm spacer. I used a 10mm spacer (but wanted more camber so) then went to a 25mm spacers on 8" +45 wheels.
18x8 +45 with 25mm spacer and -1.5 camber 215/40 front tire.
I LIKE TIRES! |
07-31-2019, 12:40 PM | #17 | |
thx for the info here is ur setup in the calculator which is 10mm spacer it looks like same as stock setup at space around suspension component don't really wanna spacer make me worried more do u have any rubbing problem without spacer with -1.5 camber at front? i have 10mm close to the suspension component
07-31-2019, 01:11 PM | #18 | |
Country Boy 4 Life
Yes, the difference is only 0.3mm, you will want more than a 10mm. Yes, it was too close. I'd suggest that you get 20 or 25mm bolt on spacers. You will have plenty of room between the spring perch and tire/wheel to add camber, they will look flush, and they are easy to install.
I LIKE TIRES! |
08-01-2019, 12:28 AM | #19 | |
get some info on facebook gt86 local group it looks like i will be fine! i man sure i will back to this and post the result next Thursday it is the day
08-01-2019, 09:28 AM | #20 | |
Drives: Crapcan
You may try running camber bolts in both upper and lower strut holes. |
08-01-2019, 01:07 PM | #21 | |
That would be correct if the wear was from too much load on the tire, but it's not. It's from not enough camber so there's too much load on the outside of the tire. You want the tire flat to the ground at max cornering loads, you're definitely well into the positive camber range based on that wear. Sway bars alone won't be enough to stop that, you'd need way too stiff of springs to keep the tire flat with such little camber.
08-01-2019, 02:40 PM | #22 | |
Camber blot first and sway bar second. Meanwhile watching on the tire pressures And temperature Still can’t fix it. I may go for camber plate or springs don’t really miss up with stock suspensions too much effort on set up Had go though it with my kwv3 on bmw, living in a small town wont help either In my case, driving on the re71 with stock suspension is hard to manage the tire pressure. Too high will cause less grip, too low will destroy the sidewalk of the tire. I was running on 28psi on hot. A bit low maybe
08-01-2019, 02:50 PM | #23 |
You can try those things, but at the end of the day upgraded sway bars, stock springs, and -1.5* of front camber won't be enough for RE71Rs. Will it be better than stock sways and 0* of camber, yes. Will you still be overheating the outer edge badly, yes.
RE71Rs are also a bad lapping tire, they're good for a couple laps at most. If you're not running time attack there's much better options for 10+ minute sessions.
The Following User Says Thank You to wparsons For This Useful Post: | NoHaveMSG (08-01-2019) |
08-02-2019, 01:28 AM | #24 |
Drives: 2015 BRZ Limited
Sway bars will not help with this issue.
You need more adjustable suspension. Look into some coilovers, this will give you plenty of camber, ride height, and dampening adjustment. These all will help with your bodyroll and tire wear. If you can't afford coilovers just yet, you could look into camber plates for your stock dampers. At that point sure, maybe look into sway bars. But, if you plan to go coilovers eventually, it makes more sense to do sway bars AFTER, if even at all. Eliminating body roll does have some negatives to it. Unless you are trying to drift your car, making it too stiff will actually make you slower around the track. You need to run anywhere from -3.0 to -3.5 in front and -2.0 to -2.5 in rear for your camber. You can daily a car with this. It wont kill your tires. 0 toe all around is a good starting point, then slight adjustments depending on how it feels.
The Following User Says Thank You to JeremyR For This Useful Post: | wparsons (08-02-2019) |
08-02-2019, 10:59 AM | #25 | |
Drives: '23 BRZ
245/40-17 RE71R on 17x9 +35, -3.2* front -2.5* rear camber, Swift BRZ sport springs, Raceseng camber plates. Not the best setup FWIW! No front bump travel, fronts pretty much on the bump stops (cut down from 60 to 20mm) at rest, any small bump = BAM!!! |
08-02-2019, 11:04 AM | #26 | |
Drives: '23 BRZ
FWIW I just aim for ~35psi hot and don'w worry about it beyond that. There's going to be a fairly broad range of hot pressure that will give be near optimal for lap times, my approach is to run near the high end of that range for tire life. I know that a lot of people seem to try to run as low low low as possible thinking there's more grip with lower pressures, but I haven't seen any evidence to make me subscribe to that approach... |
08-02-2019, 11:23 AM | #27 | |
Drives: '23 BRZ
In fact, if you go to a stiffer front bar, that will INcrease outside front tire load (and decrease rear outside tire load). Decreasing body roll will improve your dynamic camber situation though. |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | Icecreamtruk (08-05-2019), NoHaveMSG (08-02-2019) |
08-02-2019, 11:31 AM | #28 | |
IMO that's either a unicorn track, or you're under driving by a fair amount. I've never personally driven on them, but anyone I know that's a properly fast driver can get 2-3 hot laps absolute maximum.
Similar Threads | ||||
Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 02:08 PM |
Question about wheel/tire fittment | Jolt182 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 04-27-2015 12:51 AM |
Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
Camber Question | subaruatheart | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-24-2013 01:49 PM |
Fittment question | digital_assassin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 08-09-2012 12:21 AM |
