Old 10-02-2019, 02:00 PM   #15
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I never noticed
Old 10-02-2019, 02:02 PM   #16
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Originally Posted by jsimon7777 View Post
I never noticed
I think it's more noticeable when you install a bucket seat. If you line up the seats with the pedals the steering wheel is off to the right. Stupid transmission tunnel.
Kestrel is offline   Reply With Quote
Old 01-06-2020, 11:51 AM   #17
korhun
Database error
korhun's Avatar
This is a great thread. Thank you.. Do you think a rookie who has never mod his car can do this? And I wonder it can be applied to 2017+ BRZ?
korhun is offline   Reply With Quote
Old 01-06-2020, 01:30 PM   #18
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
This tutorial was designed so a rookie could do this.
That said like in the disclaimer working on airbag and safety equipment is a higher risk than working on brakes. You need them to work. Period if you are uncomfortable I would have a professional shop do the work.
This spacer physically works with the 17 and up models but it does not have the wiring harness needed to maintain the radio controls on the car.
Clutch Dog is offline   Reply With Quote
Old 01-07-2020, 02:38 AM   #19
korhun
Database error
korhun's Avatar
@Clutch Dog thank you for the valuable information. Until now, I haven't ever wanted to listen to radio in this car; and don't think I will. So the buttons on the steering wheel are already useless to me. I'll try to find a way to ship this to Turkey. But first, I should convince my wife; it's the hardest part
Old 06-16-2020, 06:48 PM   #20
Var
Drives: 2017 Subaru BRZ PP
I just tried putting mine on my 2017 BRZ, and I was not able to get my airbag back on. The airbag wires are a tad too short for the airbag to go back in and go low enough to line up the 3 pins. I guess I'll have to extend my airbag wires to make this work. And the steering wheel controls for sure need an extension but i can live without those
Var is offline   Reply With Quote
Old 02-07-2021, 10:03 PM   #21
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
The steering spacer has been on my to do list for a couple of years. Finally, I bought one and installed it. For the freakishly tall among us it's a revelation. With the stock set up, to get the seat far enough back to fit my legs and reclined enough to accommodate my melon, I'd be stretching my arms to reach the steering wheel. No more. I can finally set the car up to fit me rather than the other way around.
A couple of observations, 1. the added two inches makes the turn signal and wiper stalks noticeably farther away. Not a big deal - big hands usually accompany general largeness.
2. The added distance puts a serious stretch in the horn wire. I battled mine for quite a while and ultimately admitted defeat and fabbed a 2" jumper wire. [949 guys - including a short jumper would help those of use with big clumsy mitts]
My only issue is the steering wheel is slightly cocked - about 2 to 3 degrees to the left. It's far less than a full spline's worth. Not sure what the cause is. My guess is that random variation in manufacturing could easily be the culprit. I tried the next spline and the difference is far greater in the other direction. It's not a big deal - I'll get it sorted at the next visit to the alignment shop.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 03-26-2021, 05:07 PM   #22
yEEt42069
Drives: 2018 Subaru BRZ
Thanks for the write-up, I got my spacer in today and installation took only 20 minutes using this guide. I can't believe I didn't have this before, its so nice being able to drive without my knees hitting the wheel and getting in and out is now easier.
yEEt42069 is offline   Reply With Quote
Old 03-30-2021, 12:44 AM   #23
RayRay88
Drives: 2017 86 860 Special Edition
How was it getting the horn, airbag, and steering wheel control wires on? I'm assuming being a 2018 BRZ, you got the extended harness?
I plan on installing it as soon as the weather warms up a bit here.
RayRay88 is offline   Reply With Quote
Old 03-30-2021, 01:53 AM   #24
EAGLE5
Dismember
EAGLE5's Avatar
Really, only the horn will need an extension of some kind. Mine keeps getting disconnected though. I'm going to do those heat-shrink things to get the wire to stay.
Old 03-30-2021, 05:29 PM   #25
RayRay88
You ran into this issue on a 2017+?
I only ask because "Var" above was having problems with all wires including the ABS.
Old 03-30-2021, 05:43 PM   #26
EAGLE5
Dismember
EAGLE5's Avatar
Oh, sorry, 2013
Old 04-01-2021, 08:23 PM   #27
Mtl135i
Drives: BMW 135i
Anybody have one of these for sale in Canada ?
Cheers
Mtl135i is offline   Reply With Quote
Old 06-04-2021, 01:15 PM   #28
yEEt42069
Hey sorry for the super late response. I did get the extended wire harness and it was very easy, plug and play. You do have to play around a little with fitting the airbag back on because there is a little more wire sitting around.
949 Racing 50mm Steering Spacer 86 - GR86 949 Racing Tracking / Autocross / HPDE / Drifting 195 04-18-2022 11:45 AM
Spacer install EzyBrzy Northern California 1 03-05-2016 03:52 PM
Vibrations After Spacer Install Wyattkb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2015 12:20 PM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
