#15 |
Has to poop
Drives: Queen size bed w/4WD
Thanks for the reply
Andy=20yo 99 Taco TRD 3.4 4x4 -"Terra"- trail rig95 F250 7.3 PSD 4x4-"Gertrude"- tow rig Soon- Asphalt/6MT |
#16 |
Drives: Subaru BRZ Limited WRB Manual
#17 | |
NW Region Moderator
Drives: FR-S No More
Yes, much of the manual is poorly translated, but not so much that you can't figure out what they really meant.
#18 | |
NW Region Moderator
Added a short review...
#19 |
That Guy
Drives: 2013 asphalt FRS MT
The adjustable camber at the hub should be used to calibrate the camber adjustment at the camber plate. You set the camber plate to some arbitrary position, say 1 deg negative, and then put the car on an alignment hoist and adjust the camber via the hub until you actually have 1 deg negative camber.
The adjustable length sway bar endlinks allow you to adjust the sway bar, to avoid preloading it, when you corner balance the car. Nice write up. The car looks great. |
#20 |
NW Region Moderator
Calum, that's great info... I am going to integrate that info into my review. Thanks!
#21 | |
Drives: Legacy GT
At the upright you want to dial in as much camber as you can possibly get. Basically whenever you run out of adjustment or the tire hits the suspension. Then, at the top mount, you want as little camber and as much caster as possible. The reason for this is what's called the steering axis inclination (SAI). Basically, SAI is the angle of the strut - more camber at the top mount means more SAI. More SAI means more loss of camber as you turn the wheel, and is also can result in a greater roll center propagation. Adding camber with plates adds SAI. You want to try to avoid this. Ideally what you will do is swap the plates left to right so they are at an angle. Max them out so they are as far back and inward as they can go, and then do your fine camber adjustment at the upright. On my car I have a set of whiteline com-c mounts and an ALK which give me a good amount more caster and a little more camber. Then to get the camber that I want I slotted the lower strut holes. From a geometry point of view it's the ideal way to do it. |
| The Following 2 Users Say Thank You to jamal For This Useful Post: | Matt Andrews (08-14-2012), ultra (08-05-2012) |
#22 |
NW Region Moderator
So it appears that the same factory that builds D2 coilovers also produces the K-Sport product, so this topic is being expanded to cover those as well. K-Sport has two part numbers (CSC080 for Scion, CSB200 for Subaru) but they are the exact same product with no differences.
| The Following 3 Users Say Thank You to DarrenDriven For This Useful Post: |
#23 | |
Drives: 2013 Scion FR-S - Firestorm
![]() By the way... they still aren't truly in-stock. I got a notice saying they're back ordered and not to expect them until September 18. |
#24 |
NW Region Moderator
I do appreciate that he pulled some strings to get my coilovers to me before they were available to the public, but still... you gotta under promise and over deliver, not the other way around!
#25 |
Agreed.
BTW, what are the D2 spring ratings that were shipped to you? Joe mentioned that D2 changed the rear spring rate after further testing. I'm curious to see what your kit came with. |
#26 |
Vtec Jesus
Where the review too lol.
#27 | |
Drives: race cars
Stiff does not equal high performance. grip does. And grip comes from quality damper valving that is matched to a spring rate that allows the tire to stay in contact with the ground as much as possible with as little change in force applied to the tread as possible to keep from shocking it loose. Good luck in your selection folks. learning what works for ones self is half the fun. ![]() Matt
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below. http://fecompetition.wordpress.com/ https://www.facebook.com/FECompetition |
| The Following 6 Users Say Thank You to Matt Andrews For This Useful Post: | chulooz (08-14-2012), danthedirt (08-15-2012), jamal (08-14-2012), schtebie (08-14-2012), TouchMyHonda (08-14-2012), Turbowned (08-15-2012) |
#28 |
Registered you sir
Drives: 99 impreza coupe
Try comparing dyno plots between the D2s and KWs instead of just looking at them.
Streched 19s and slammed Its not a VW, you car actually had decent performance at one point.
| DG-5 Coilover | harajukukei | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-27-2014 04:42 PM |
| Coilover suspension | oxygen | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 07-27-2012 05:04 PM |
| NW Coilover Shootout | DarrenDriven | Northwest | 14 | 07-24-2012 03:12 AM |
| KSport Kontrol Pro for FR-S/BRZ *PRE-ORDER* from Jordan Innovations! | Jordan Innovations | Brakes, Suspension, Chassis | 4 | 07-11-2012 07:43 PM |
| KSport Kontrol Pro!!- Deft Motion | StarsGarrador | Brakes, Suspension, Chassis | 0 | 07-06-2012 07:42 PM |
