Old 05-26-2019, 06:42 PM   #15
tomm.brz
Drives: brz 2017 hksv2
how can you say jackson racing is "better choice" than innocate when they are totally different sc type
Old 05-26-2019, 07:14 PM   #16
86TOYO2k17
Drives: 2017 toyota 86
Not saying JRSC is bad by any means. But it definitely is over hyped by the fan boys and used to be heavily pushed by some vendors on here. I was on the verge of getting it but read way too many people having there blowers fail on them and taking months to get a replacement. Scared me off. Seems like most failures with sprintex where minor resolvable issues, install error or bent rods from too much torque. The unit itself as long as you didn’t starve it of oil seemed pretty reliable. For wanting 300whp or less and not wanting to go turbo id say it’s a solid option if you can E85 or are willing to WMI (which to be fare increases cost even more) and intercooler is a must.
Old 05-26-2019, 10:41 PM   #17
jflogerzi
jflogerzi's Avatar
If this is a purely street driven car, the sprintex 210 kit is nice. I got mine used with 30000 on the on the blower from a member here and works great. Keep looking and you can fine deals. Got mine for 2800$ and this was IC cooled. Do you need to be carb legal? If not why not go turbo?
2013 Series 10 FRS #553
Old 05-27-2019, 12:22 AM   #18
ltown
Drives: 2013
Originally Posted by 86TOYO2k17 View Post
Are you planning on building the engine?
What are your whp goals?
What kind of power delivery do you want?
Low/mid torque or high end peak hp?
Car use? DD, spirited driving, canyon/backroad, autox, track, dragstrip, stop light/roll racing?
C38 is larger with more potential, but even the C30 is plenty capable of blowing stock engine. I believe it’s about 350whp vs 400whp max potential on a normal non hero dyno.
i dont have whp goals, just safe horse power with good efficiency and maintain reliability. the car is a spirited DD first and foremost. the kits ive narrowed down to is the hks v3 and jackson racing. ive thrown out the idea of the used spintex. but still so lost on what ill actuall need to get the goals i want. for instance, will i need a different MAP sensor for either kit?
ltown is offline   Reply With Quote
Old 05-27-2019, 12:28 AM   #19
ltown
Drives: 2013
Originally Posted by jsimon7777 View Post
Bigger blower = more potential for more money. If you're going to stay on the carb tune with stock pulley, get the c30. Don't waste your money. If you're going to build your engine, swap pulleys, and get a custom tune, get the C38.
A lot of people find the JRSC reliable.
The innovate is just old tech. Why bother?
None of this is going to be as reliable or easy to keep up as stock. Maybe you should just go buy a Z or something else with more power stock? An Ace header, billet power blocks, and tune gets the car into a pretty sweet NA spot.
i love the 86 platform too much lol and i keep very good maintenance on the car, i just dont want to be fixing something ever 20k miles ya know? so i want a good kit that has good design. changing a belt and supercharger oil every 30k is totally doable, just dont want headache problems that are hard to figure out with all the changes i put on. things like(check engine lights and leaking supercharger oil)
Old 05-27-2019, 12:32 AM   #20
ltown
Drives: 2013
i want more broad power usage in low to mid range rpm, plus i upgraded exhaust already and dont want to have to buy turbo header lol
Old 05-27-2019, 12:57 AM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
No centrifugal is low to mid range. Harrop or Edelbrock then. Not sure why you want low to mid when high is what makes the car so fun.
Old 05-27-2019, 01:19 AM   #22
86TOYO2k17
Sprintex will have the most broad power band across entire RPM range highest low/mid torque in comparison to any other kit at or below 300whp. Does have heatsoak issues if tracking without E85 or WMI, not a big deal if just spirited driving though.
HKS/JRSC will have the lowest power band with least low/mid range torque. Harrop and edelbrock are in between closer to sprintex though. This is all in comparison with all kits making 300whp peak or less. If wanting more then 300whp which becomes increasingly less reliable especially for DD then sprintex can’t hang as it maxes out at 300whp. But at or below 300whp it’s a good option for a fun spirited DD.
JRSC/HKS aren’t bad but you need to rev it out to get power good for tracking when constantly at high rpm. Plus side with lower low/mid torque you may be able to run a little higher peak whp more safe and reliably but still need to really rev it out.
See attached dynos 1st sprintex. Second is JRSC
Old 05-27-2019, 12:33 PM   #23
ltown
Drives: 2013
i see the torque on the spintex is crazy right off idle lol, but they no longer sale the non intercooler version and the intercooled one is more expensive then the hks and jackson racing. the hks/JR kits dont have as much torque down low this is true but its still better then stock. so really i think im ok with that. if i want the power out i can decide myself how high to take the rpms, and for a daily driver that choice comes along alot. i think im going to go HKS with their v3 system, weirdly enough i like that it uses the stock air box. p.s. other then a tune, can i just run this kit with no other mods? etc MAP sensor?
Old 05-27-2019, 01:07 PM   #24
jflogerzi
jflogerzi's Avatar
Each kit if bought new will provide everything you need. Get the tuner kits so you can get a custom etune. With the Bluetooth version you can log with your phone and keep an eye on AFR and other important temps like coolant and oil. If your stuck on brand new, the eddlebrock is the best kit. Gives you plenty of headroom, and is also a twin screw unit giving you down low tq.
BTW no kit will be truly plug in play. Your adding power and tq to an engine that was not design to handle the extra power. Expect the worse and hope for the best. But with any kit the 2 most important things are:
Tune
Proper install
Old 05-27-2019, 02:15 PM   #25
86TOYO2k17
And oil / coolant temps.
Old 05-27-2019, 04:33 PM   #26
86TOYO2k17
I got mine new with intercooler for 3900$ from Bahn Brenner. My goal was 260whp. Or 310crank. For 300whp or less it’s the meatiest powerband. Instant power at any RPM, I have the torque/power anytime if and when I want/need. Just control it with the throttle. It’s always there if I want and not if i don’t. Centrifugal need to downshift and rev out to get power. It is more similar to stock power delivery just amplified. HKS v3 kit does look pretty solid though, after months of going back and forth between just about every kit I narrowed it down to sprintex and HKS V3. If I went HKS my goal would have been 280whp. But settled on sprintex at 260whp.
Regardless, both kits are basically bolt ons, just need a tune. Neither come with a map sensor but it’s not required they can be tuned just fine with the MAF. An oil cooler is highly recommended. I already had the OEM one so just got a mishimoto radiator and temps are fine. If I didn’t already have oem oil cooler I’d probably get a real oil cooler. You’ll also want some good tires, probably some 8.5-9” wide rims with a 245 tire to be able to actually put the power down or you’ll probably be spinning stock tires to the top of 2nd.
Old 05-27-2019, 05:49 PM   #27
ltown
Drives: 2013
OEM oil cooler? i didnt know stock 86 had that? do you know what your temps are at? both ECT and IAT? and what did you notice with gas mileage?
Old 05-27-2019, 06:22 PM   #28
EAGLE5
Dismember
EAGLE5's Avatar
HKS is centrifugal. Doesn't match what you say you want.
Question about FI / Innovate azynneo Forced Induction 47 06-15-2015 08:09 PM
Question; What Strut-tower bars and cross-braces fit with Innovate Stage 2 I/C SC? Michael Blue Forced Induction 5 05-26-2014 01:30 AM
Question: vortech+innovate possible? cjsporl1996 Forced Induction 32 03-28-2014 07:47 PM
Innovate Motorsports Supercharger Question jjkerr626 Forced Induction 3 01-04-2014 08:12 PM
Innovate OT-2 jamesm Engine, Exhaust, Bolt-Ons 0 12-03-2013 10:38 AM
