Old 04-22-2019, 09:47 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by gravitylover View Post
You wouldn't pass the annual safety inspection in my state. You can't disable safety systems and pass so I always have to get the car inspected when I have the 3 season wheels on because I don't have TPMS sensors on my winter wheels.
indiana only does emissions testing, and because the car is a 2005+, they only check the gas cap and scan the car to make sure it clears itself.
i'm somewhat happy with it, as my '02 ranger wouldn't pass yearly inspection with some of the rust it's currently got.
Originally Posted by Grady View Post
This makes no sense.
i can explain it any way you'd like. i don't agree with the concept of spending all that money maintaining a singular idiot light, of something that we all should be visually checking before every drive anyways.
Old 04-22-2019, 09:49 PM   #16
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Originally Posted by DarkPira7e View Post
You know, they can just be within range right? I have the opposite - only my winters have tpms because I raise/lower my pressure in the summer depending on my activity, and I care far more if my winters go flat!
I can pass with the winters sitting in the car as long as they're at the right pressure level
I leave my summers with TPMS in the garage. The car in winter reads those from about 10 feet away and the TPMS won't come on until 22 miles later. I agree the low profile tires hide low pressures, so I check them regularly.
davesrave is offline   Reply With Quote
The Following User Says Thank You to davesrave For This Useful Post:
DarkPira7e (04-22-2019)
Old 04-22-2019, 10:19 PM   #17
Grady
Grady's Avatar
You paid for it already, It cost $0 to keep/maintain it. Now if you said you had a defective transmitter and did not want to purchase a new one I could almost see your point. You can not visually check pressure on low profile performance tires.
Old 04-23-2019, 08:38 PM   #18
gravitylover
Hey that's a good idea, keeping the wheels in the car. Cool, midwinter inspection problem solved. Thanks
Old 04-23-2019, 08:43 PM   #19
gravitylover
I only have safety no emissions. There also can't be any active CEL's and it has to be at least 75 miles since any codes have been thrown. This is why my 06 Durango is about to go past it's inspection, I can't get the light to stay off more than about 60 miles for a tank vent solenoid that doesn't want to read right.
Old 04-24-2019, 06:20 AM   #20
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
A tank vent solenoid doesn't "read", it's a valve that opens and closes, it has no built in feedback circuit, the PCM will come to the conclusion that the system isn't air tight with its leak detection strategy.
I assume you've already gone through the phase of throwing parts at it and that it has a new vent solenoid and is still throwing a leak code? I've seen quite a few of those chrysler fuel pump units break at the lock ring and leak vapors from the top of the tank.
Old 04-24-2019, 07:20 AM   #21
While I absolutely agree with you, I need to point out it is not $0 cost. The batteries in the sensors have a life, and on most cars you have to replace the entire sensor.
I have to do that the next time I get the tires changed on my '04 Suburban. At least one of the sensors is out. They are about $50 for a set, so not exactly expensive, but not exactly free either.
Fortunately, the Suburban just shows it on the info screen, you press a button and it goes away. It's not a constant light.
Grady (04-24-2019), soundman98 (04-24-2019)
Old 04-24-2019, 10:32 AM   #22
Grady
Grady's Avatar
We are on the same page. My point was until it breaks it is 100% paid for and free. When it breaks and you do not want the light on and unwilling to pay do the ghetto black tape method.
The Following User Says Thank You to Grady For This Useful Post:
Dadhawk (04-24-2019)
Old 04-24-2019, 03:46 PM   #23
gravitylover
I assume you've already gone through the phase of throwing parts at it and that it has a new vent solenoid and is still throwing a leak code? I've seen quite a few of those Chrysler fuel pump units break at the lock ring and leak vapors from the top of the tank.
Yup and actually it's an evap code. Good call on the lock ring/seal. Is that something I can check easily? Can I reach or at least see where that lock ring is?
Old 04-24-2019, 06:06 PM   #24
RZNT4R
Not easily. I usually find them with an evap tester hooked up at the purge solenoid and a super sensitive microphone (snap-on sonic check) because I can never get eyes on.
Old 04-25-2019, 04:54 PM   #25
rustymuffler
Originally Posted by PureRedBRZ17 View Post
Just lost a tire that I ran almost flat for a bit and didn’t notice the light (my fault). While relying on an idiot light isn’t ideal, lower profile tires don’t exactly give the same warning signs as a tire with a taller sidewall. Does an option exist to turn on an audible chime when the TPMS activates? Thanks!
I don’t believe there is a factory option to turn on an audible chime with the TPMS light, but I recall seeing a DIY to add auto door locking when the car reached a certain speed, and this was all done with an Arduino interfacing with the OBD port. so to answer your question: yes I think you could make it happen, and pretty cheaply too but it all depends how much effort you want to put in. it would take some time to figure out the specific canbus protocols for the tpms indicator and door chime, then programming the code to make it all work.
rustymuffler is offline   Reply With Quote
Old 04-25-2019, 05:44 PM   #26
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I don't agree with the concept of spending all that money maintaining a singular idiot light, of something that we all should be visually checking before every drive anyways.
What money are you spending on "TPMS maintenance?" At least for the first 5 or 6 years until the batteries in the sensors die? Arguably, you wasted more money going out of your way to disable everything, since you've basically disabled a system you already paid for when you purchased the vehicle...
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 04-25-2019, 11:29 PM   #27
soundman98
soundman98's Avatar
i don't like it, i didn't need it, and cutting it out didn't do anything harmful. so i cut it out. don't get me started on reverse camera's. i would have crank windows if i could on the car. and i'm still debating about deleting the a/c.
i didn't get the car because it was new and nice, i got it because it was cheaper in the long run than rebuilding a rusty drift missile.
now if you'll excuse me, there's some damn kids on my lawn that didn't learn their lesson last time
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (04-26-2019), Stang70Fastback (04-26-2019)
Old 04-26-2019, 12:40 AM   #28
humfrz
You tell em, Sparky -
My first vehicle was "basic" and I got along just fine -
humfrz
soundman98 (04-27-2019)
Is it possible to turn off your TPMS light with the OFT? dylandrivesacar Software Tuning 4 06-05-2018 03:07 PM
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 10:31 AM
Fog light issues *SME please chime in* thatfilipinoguy Cosmetic Modification (Interior/Exterior/Lighting) 5 10-09-2015 07:52 PM
TPMS warning light FRSowner Scion FR-S / Toyota 86 GT86 General Forum 6 12-30-2012 08:24 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
