Old 04-12-2019, 11:44 AM   #15
maslin
Benz Tech
Drives: 2017 BRZ Premium
Yes, heim as in Kleenex, band aid, etc.
Heim joint, for your race car.
Spherical bearing (or bushing) for your 1988 Mercedes, BMW, and a million other factory fresh cars.
Elastomer Whiteline bushings
Stock inner bushing.
All of the stock looking LCAs with slots and cam bolts use a spherical inner bearing. The Whitelines replace that bearing with elastomer bushings for STX compliance. Heim joints (as everyone in the world refers to them as) go on race cars.
We're talking about lower control arms. They are rated to be lower control arms. Except for those $25 Chinese child labor rips offs. Those probably aren't rated for much.
maslin is offline   Reply With Quote
Old 04-12-2019, 11:51 AM   #16
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Nope. That is a rod end. Possibly made by Heim, or one of a bunch of other manufacturers. Aurora doesn't sell Heim joints, they sell spherical rod ends.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 2 Users Say Thank You to venturaII For This Useful Post:
86MLR (12-17-2019), Ultramaroon (04-23-2019)
Old 04-12-2019, 12:06 PM   #17
maslin
Benz Tech
It's not an escalator, it's a moving staircase!
The $25 China arm you seem to be defending has the joint you are arguing against, if that didn't come across.
Old 04-12-2019, 12:44 PM   #18
venturaII
venturaII's Avatar
The $25 China joint you seem to be defending has the joint you are arguing against, if that didn't come across.
My understanding is that OEM uses a plain rubber bushing/sleeve on the inboard end, not a spherical joint, and that the cheap control arm also uses rubber, which is what I want. If that's not the case, then you are correct in that this is all academic. Still, regardless of what is used at the inboard end, the $25 arm does have the eccentric bolt and washers and the tabs for them to ride against, so it's still a relative bargain for what functionality I'm looking to gain. Since no one has apparently used the Ultra-Power brand, I guess I'll be cutting edge again. lol
Old 04-12-2019, 12:49 PM   #19
maslin
Benz Tech
The OE arm uses a solid rubber bushing. The SPC/Moog/8 other brands use an enclosed spherical bushing, that is why they are illegal in STX class. The Whiteline arm is the same arm, with the spherical bushing pressed out and solid "elastomer" bushing provided.
The ultra-power arm appears to be a replica of the SPC part, spherical bushing and all. Just noticed the picture, those cam plates are going to be a bitch, flat sides on a eccentric don't work very well.
Moog/SPC/et al
Ultra-Power!
Old 04-12-2019, 01:20 PM   #20
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Whoa...glad I asked. That's exactly what I want to avoid. Looks like the el-cheapos will be the pick. Can't really go wrong for $25 a piece anyways...time to use this lifetime alignment again.
the SPC arms work fine for what you want to do and will last you a long time.
I mentioned the bearing because others have already pointed it out... it's not legal for STX classification. Whiteline will be closer to stock + adjustment with minimal possibility of play.
-alex
Old 04-23-2019, 03:18 PM   #21
venturaII
venturaII's Avatar
Welp, I took a gamble and got the MegaPowerrrzz... They do use a spherical bearing(possibly Heim branded?...lol) rather than a sleeved rubber bushing like I wanted but I couldn't find any other options, plus the price is definitely right. Installed them over the weekend and got the car aligned and was able to easily get the numbers I was looking for. We'll see how long they last; might see if I can pull the rubber boot back a bit and get some extra grease in there...
maslin (04-23-2019), Ultramaroon (04-23-2019)
Old 04-23-2019, 08:36 PM   #22
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Blox LCA
FT86Motorsports Canadian branch have a nice deal on Blox LCA's.
And cheaper than the Whiteline units and pretty colors. Here is a link to the red ones. Not sure if their US shop offer the same pricing.
https://www.ft86motorsports.com/susp...-arms-red.html
EDIT: actually, they don't even list them on their US site. The link above is CA$. Your dollar is worth 35% more so even greater savings.
Muskoka800 is offline   Reply With Quote
Old 12-17-2019, 03:24 PM   #23
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
I just got a pair of coilovers for my car and found these UltraPower LCAs on RockAuto for much cheaper than the Moog’s or the SPCs, while looking fairly similar (I assume it’s a replica as others have stated).
I haven’t found much in the way of info on them other than this thread specifically; so I’d love to see how the UltraPowers been holding up for you? I don’t mind spending more for the Moog’s, however at $34CAD per arm vs $120CAD, I’d take the significant savings if the product holds up well.
JBezugs is offline   Reply With Quote
The Following User Says Thank You to JBezugs For This Useful Post:
venturaII (12-17-2019)
Old 12-17-2019, 03:44 PM   #24
venturaII
venturaII's Avatar
They seem to be holding up as well as any other stamped steel arm would. I was able to get the alignment numbers I wanted, they installed super easy, they haven't fallen off the car...not sure what else to say?It's not a bling part, but considering i DD my car in the rust/snow belt, chassis bling is kind of pointless. It does what I wanted for short money. I'd buy 'em again.
The Following User Says Thank You to venturaII For This Useful Post:
JBezugs (12-18-2019)
Old 12-17-2019, 09:54 PM   #25
Calum
That Guy
Drives: 2013 asphalt FRS MT
The cheapest way to do this is with a pair of 14mm camber bolts. I have no idea why this isn't common. It's been working on my car for years now.
Old 12-17-2019, 10:33 PM   #26
86MLR
86MLR's Avatar
#Calum On the rear??????
#JBezugs I had issues with designs typical to the blox seizing and chewing out the thread. Maybe their materials have improved.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 12-17-2019, 11:14 PM   #27
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Same
downside is not a lot of adjustment. +- .5~.75 degree adjustment for $30 bux.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Calum (12-20-2019)
Old 12-17-2019, 11:23 PM   #28
HaXx
Drives: jrsc_brz
im learning so much
HaXx is offline   Reply With Quote
Diftech Adjustable Rear Lower Control Arms justinco Brakes, Suspension, Chassis 0 03-14-2019 09:41 PM
FS: SPC Adjustable Rear Lower Control Arms skylinekin Brakes, Suspension, Chassis 6 09-09-2018 04:24 PM
SPL Parts Pro Rear Adjustable Lower Control Arms StickThatClutch Brakes, Suspension, Chassis 0 11-21-2016 10:17 PM
WTB - Adjustable Rear Lower Control Arms swift996 Want-To-Buy Requests 0 06-12-2013 01:23 PM
SPC Rear Adjustable Lower Control Arms Bcarlos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-19-2013 11:56 PM
