Old 02-10-2019, 11:35 AM   #15
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
That is just it. The battery still works and the car starts. If the battery threw that much bizarre coloured crap it would not still be working. Battery acid should be a blackish translucent sort of colour. I have seen battery acid react with different surfaces and that reaction can look odd but if that was acid it should not be identical on all the different materials. It would have varied depending up the reaction with each.
I hear ya, the color of it's certainly a mystery. What has me is the apparent direction of the spew and the lines of whatever it is, running down the side of the battery from what appears to the seam where the top meets the side of the battery. Maybe the battery's not completely shot, just wounded.
BirdTRD is offline   Reply With Quote
Old 02-10-2019, 11:48 AM   #16
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
It seems a little unusual that a 2016 would have had it's OEM battery replaced already but that appears to be the case.
1. Is the OP the original owner of the vehicle? Do you know why or when the battery was replaced? None of the "install date" dots on the battery label have been removed.
2. A "Toyota TrueStart" battery was likely installed at a dealership. Can you log in to the the Toyota Owners Website at toyota.com and check for service records relating to the battery?
3. Is there something wrong with the charging system that it is overcharging and destroying batteries? The battery doesn't appear damaged in that way. Is there a pressure relief valve that would blow to the side of the battery?
4. Notice the amount of corrosion under the rear battery clamp. There almost had to be some acid present on the top of this battery (or a previous one) for an extended period of time to have that much corrosion. That didn't happen in just a couple days.
5. Is the battery cap nearest the positive terminal fully seated? It looks a little higher/different than the other one.
6. What does the underside of the hood look like? Is there a spray pattern that would provide further clues to the source? Was there something (other than battery acid) spraying on the hood and running off onto the battery?
I agree with Sapphireho and Tcoat: The stuff that is sprayed all over doesn't look or act like battery acid. It appears to be a little thicker than liquid acid and the wrong color.
LimitedSlip is offline   Reply With Quote
Old 02-10-2019, 12:07 PM   #17
What ever spewed may have cone from below, hit the lip of the battery and sprayed up from there. What didn't carry on just rand back down the side of the battery. It wouldn't make sense that there would be enough pressure in a battery to spray everywhere but while at the same same being low enough pressure to just run down the side. The more I think it through the less likely the battery had anything to do with the spray. It was just in the path.
Old 02-10-2019, 12:21 PM   #18
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Come on T, you never had a nice strong stream then dribbled at the end?
Old 02-10-2019, 12:39 PM   #19
humfrz
You trying to start a "pissing contest"?
humfrz
Old 02-10-2019, 12:44 PM   #20
LimitedSlip
humfrz
Further off-topic: Did you hear about the old guy who took 1/2 of a Viagra every day?
He was just trying to make enough distance to clear his shoes.
Old 02-10-2019, 12:49 PM   #21
ls1ac
ls1ac's Avatar
The only time I have seen that much out of a battery was when someone tried to jump a car and put the cables on the wrong terminals and got scared and left them on and stepped back. I would agree to checking the fluid level first then looking for a cooling leak.
Old 02-10-2019, 03:16 PM   #22
humfrz
Originally Posted by Bluegrass View Post
Thanks everyone for the quick responses! Will definitely try the baking soda/water combo to neutralize and clean.
Car starts fine and drives great, hence I didn't notice till I popped the hood.
I assumed it was from the battery looking at the splatter pattern. It is odd though, looks like someone shot a paintball gun off under the hood.
I'll update after trying the baking soda/water. Any other general engine bay cleaners you all would recommend?
Since your car runs, I'd suggest you fire it up and look for a leak, there is gotta be more yellow stuff spewing out where that came from -
humfrz
Old 02-10-2019, 04:24 PM   #23
I have blown up at least 3 batteries over the years. None looked like that. In fact most ended up with a really clean engine bay from the acid and then baking soda rinse.
Old 02-10-2019, 06:22 PM   #24
Ultramaroon
not playing cards
Ultramaroon's Avatar
How many more you figure before you get it right?
Old 02-10-2019, 06:26 PM   #25
None. I have it down pat now.
Old 02-10-2019, 06:29 PM   #26
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Old 02-10-2019, 08:29 PM   #27
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
It looks like the pollen mixed with moisture that has recently covered everything outdoors...
NCtoBRZ is offline   Reply With Quote
Old 03-30-2019, 07:24 PM   #28
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Went to check/change fluids, only to discover my battery has spewed it's guts all over my engine bay! Looks to be dry. I have no idea how long its been like this.
Did you ever figure out the source of this mess?
battery
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit jonesy Engine, Exhaust, Bolt-Ons 1 08-25-2017 10:46 AM
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
MeisterR ZetaCRD+ Coilovers pictures and contents MeisterR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-10-2016 09:46 AM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 09:58 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
