Old 02-08-2019, 02:41 PM   #15
humfrz
Originally Posted by covance View Post
Battery cutoff switch would be ideal but unfortunately my car is push to start. So with the battery off the only way I can enter the car is manually opening the trunk (there are no ways to manually open the doors), then knock the backseats in, then crawl into the front of the car and open the door and hood release
Now, THAT is a MAJOR brain fart -
humfrz
Old 02-11-2019, 10:12 AM   #16
covance
Drives: 2015 BRZ series.blue
battery update - got an interstate
more important, after reading all your comments I go downstairs and sure enough there is a keyhole. I decide to give it a try, but ofcourse the door just keeps opening automatically with the keyfob. so, I lock the car, remove the key from the keyfob, and leave the keyfob several feet away. I come back with just the key, put it in the hole, unlock the car and then the alarm starts blaring lolll
so I run back to my keyfob, plug the key back in, then go back to the car to shut the alarm
covance is offline   Reply With Quote
The Following User Says Thank You to covance For This Useful Post:
Tcoat (02-11-2019)
Old 02-11-2019, 10:53 AM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Which one?
Old 02-11-2019, 04:42 PM   #18
covance
Which one?
believe was this one:
https://www.interstatebatteries.com/...35?search=true
was available at a shop walking distance from me so that was the deciding factor
Old 02-11-2019, 04:52 PM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Cool. I've always have had good luck with interstate. Have them in 4 of my cars and 2 in my boat.
covance (02-19-2019)
Really good summer tire that doesn't heat cycle out quickly Keenercarguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 11-17-2017 05:10 PM
Car doesn't start without fully charged battery. frsq5 Issues | Warranty | Recalls / TSB 6 06-09-2017 09:59 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
