#15 |
Drives: Subaru BRZ / Toyota 86 Experts
We have plenty of CSG Spec C1 pads stock with more pads on the way. Thank you for taking your time to post reviews especially during the holiday season!
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | mixxxx (01-10-2019) |
#16 |
Drives: 13' Toyota GT86
Some great feedback on this thread, but mainly seems to be with BBK's.
Does anyone have track experience using these pads in stock callipers (non PP) that they can share? Any comparisons to other pads would also be welcome on stock callipers. I was looking at Project Mu Club racers, but speaking to CSG, they have suggested I might be well suited to their C1 compound. (they didn't knock P Mu CR) |
#17 |
Drives: 2014 GT86
I have C1 pads for stock, non PP, brakes, but will be able to try out/comment only in end of spring when season will restart. No sense on trying out to evaluate them now during very limited grip during winter season.
| The Following User Says Thank You to churchx For This Useful Post: | wparsons (01-09-2019) |
#18 | |
Drives: Car
| The Following User Says Thank You to FirstWinter For This Useful Post: | AJ124 (01-10-2019) |
#19 | |
| The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post: | FirstWinter (01-14-2019), mixxxx (01-15-2019) |
#20 |
Drives: 2023 BRZ
Well there certainly seems to be some fans of the CSG pads around here. That's good to see. I must admit, my interest is piqued. Especially given the apparent skill of some drivers posting in this thread.
Something that surprises me is the number of people running staggered compounds. It has been my experience with this car that, as long as one has a properly-engineered BBK, or OEM brakes for that matter, the same compound should be used in the front as the rear. Is there some reason that may not be the case with the CSG pads? I'm having trouble reasoning that. Also, for those of you that have FIRST HAND experience with CSG pads and DTC-60s or 70s, how would you compare them? I'm not exactly in the market for purchasing pads, as I've got more than I can use thanks to NASA contingencies, but am always open to learning. TIA. |
#21 | |
#22 |
Drives: 2023 BRZ
I get that, but all things considered, those are pretty minor details. I'm just surprised the consensus has always been a non-split compound, then all of a sudden that seems to have changed with the introduction of a new line of pads. Odd. It's like this line of compounds doesn't play by the same rules as every other line of compounds, which makes no sense to me.
David, are you able to share a specific example of why this would be the case? |
#23 | |
Loading the tire is incredibly important. To sum up what you read in this thread thus far and other setups that we have done (we hope more people chime in TBH since we sold out a couple batches already): 1. OE BRZ F/R - C1 F/R 2. OE BRZ F/R - C2 F/R 3. OE BRZ F/R - CE2 F / some regular sprint pad R 4. Brembo PP F/R - C1 F/R 5. CSG Brembo GT Front / OE BRZ Rear - C1 F / R 6. CSG Brembo GT Front / OE BRZ Rear - C1 F / C11 R 7. CSG Brembo GT Front / OE BRZ Rear - C1 F / C2 R 8. CSG Brembo GT Front / OE BRZ Rear - C2 F / C1 R 9. AP Racing Sprint Front / OE BRZ Rear - C2 F / C11 R 10. AP Racing Sprint Front / OE BRZ Rear - C2 F / C1 R 11. StopTech ST-40 Front / OE BRZ Rear - C1 F / C1 R 12. StopTech C43 Front / OE BRZ Rear - C2 F / C1 R 13. StopTech C43 Front / OE BRZ Rear - C2 F / C2 R C1 = Our primary sprint brake compound focus - can be used from OEM tire to slick. Med/High friction characteristic. C2 = Slightly higher friction than the C1. Designated as high friction characteristic. C11 = Used sparingly for rear application. It's touch more friction than the C1. Med/High friction characteristic. CE2 = Long endurance application with strong bite and extremely long wear. Low/Medium friction characteristic. All pads have excellent consistency, modulation, high fade resistance, and high thermal capacity. They are compatible with OEM and Bosch ABS and TC application. The major issue with other manufacturers is the major difference between each compound. While other manufacturers mull over friction coefficient, longevity, etc. with each individual compound, we built in a varying degree of each to each of our compound, making the spread of friction coefficient much smaller than our competitors. Last edited by CounterSpace Garage; 06-24-2019 at 02:28 PM. |
| The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post: |
#24 | |
Drives: Car
Beginners who are new to the sport are often recommended these type of "cookie cutter" setups as well rather than experimenting with a multitude of combinations in order to minimize the variables they have to worry about. Having a simple set up will allow them to focus more on their driving as they develop. |
#25 | |
Sometimes, some cars, or even certain years of cars, are overly aggressive with their electronics, leading to using a different pad to alter or band-aid that behavior. E.g., there are CSG pads specifically designed for drivers who prefer to rely on their ABS to get 100% consistent braking every time, rather than trying to threshold brake and possibly losing that consistency. There are also compounds specifically designed to work with heavy stability control intervention |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Pat (01-16-2019) |
#26 |
Thank you for your patience. Our CSG Spec Brake Compounds are up on our website. StopTech users rejoice! We have a brake pad compound that would jive perfectly with the brake system. :thumbups:
https://www.counterspacegarage.com/csg-spec-brake-pads
| The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post: | FirstWinter (01-31-2019), Icecreamtruk (01-31-2019) |
#27 |
Drives: Track preped NA FRS
Hell yeah, pads for the C43 kit! I was wondering when someone was going to start adding those up (tired of looking at s2000 sites).
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | CounterSpace Garage (01-31-2019) |
#28 | |
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | Icecreamtruk (01-31-2019) |
| Tags |
| csg brakes, csg spec |
| CSG Brake Thread - Expert Tuner/Motorsport Brake Advice & Experience | CounterSpace Garage | Brakes, Suspension, Chassis | 14 | 10-23-2019 01:54 PM |
| D1 Spec Big Brake Kit W/ SS Brake lines | Sweet48 | Canada Classifieds | 1 | 11-19-2017 04:31 PM |
| Khumo V710 R Compounds $150 | Deep Six | Wheels and Tires | 0 | 10-17-2016 08:44 AM |
| Wtb: 245/45/17 r compounds | SterlingBrz | Want-To-Buy Requests | 2 | 08-31-2014 01:48 AM |
| Suggested R compounds and wheels for CS | Oldfatguy | Tracking / Autocross / HPDE / Drifting | 36 | 09-11-2013 12:14 PM |
