Old 11-01-2018, 05:59 AM   #15
Originally Posted by GrabTheWheel View Post
Ok Mike, you've convinced me. Now can I drive without any starvation at least to a half tank with their fuel pump hanger? Being able to convert the oem returnless system to a traditional return system seems like it would be beneficial. It would also address the filtration issue.
That, I can't confirm either way, as I've not tested or seen one in action in person
Old 11-01-2018, 11:17 AM   #16
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by Turbo View Post
You sure it's installed correctly? No problems with your fuel pump?
I'm boosted and can practically run down to vapours without issue. I see close to 2G's cornering and consistently hit 1.4G's braking on the track.
Yup. Pulled, checked, re-installed. It's in there correctly. Correct orientation, and flaps freely.
Regarding the fuel pump, I don't have any issues that I know about, and it is the factory fuel pump.
Headers and a 93 octane tune are all that's going on for power, so I'd be surprised if it's having issues keeping up. 24K miles on the car - how long do they last? Starving it a couple dozen times hasn't helped it I'm sure, but as long as I keep the tank at a level higher than I'd like, I don't get the starvation.
It happens repeatedly in 3 corners on one track, and one corner in another, so the issue is repeatable.
Joesurf79 is offline   Reply With Quote
Old 11-01-2018, 12:34 PM   #17
GrabTheWheel
Drives: 16' BRZ
2 G's in the corners and you can run down to empty?? Umm, ok I'll bite what is your setup? You must be faster on track than most Corvettes running slicks then. Lets see some video!
GrabTheWheel is offline   Reply With Quote
The Following 2 Users Say Thank You to GrabTheWheel For This Useful Post:
CSG Mike (11-01-2018), kch (11-01-2018)
Old 11-01-2018, 07:37 PM   #18
Jonsey
Jonsey's Avatar
I run time trial and on E85 couldn't go below a half tank on E85 when NA or below a half tank with 100 octane when supercharged without starving when I ran the velox flap. I now have a full surge system and can run down to vapors. The track Joe is talking about is also notoriously bad for fuel starving as there are two very long left sweepers right in a row.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following 4 Users Say Thank You to Jonsey For This Useful Post:
CounterSpace Garage (11-02-2018), CSG Mike (11-01-2018), Joesurf79 (11-01-2018), Tristor (02-27-2019)
Old 11-01-2018, 10:31 PM   #19
Joesurf79
Joesurf79's Avatar
I was hoping you'd chime in Jason - I need to pick your brain sometime about that surge system And being faster while I'm at it
Yep, you know exactly where I'm talking about. Heidi finally had it happen - while poaching Jim's wider wheels haha! Same thing at MSR Houston coming out of the carousel running ccw
Old 11-04-2018, 10:50 AM   #20
Turbo
Drives: FR-S Turbo
You don't need a surge tank - just a properly functioning transfer pump system with an actual pump doing the transferring from one side of the saddle tank to the other instead of the vacuum-based system Toyota went all cutesy with.
Turbo is offline   Reply With Quote
Old 11-27-2018, 04:36 PM   #21
Joesurf79
Joesurf79's Avatar
Radium Surge tank with e85 compatible pump and internal pressure regulator are coming my way. Got my order from Jegs yesterday with all the needed fittings, AN hose, connectors, etc. Just have to wire and plumb it up! Will report back on the process and function once I have it together.
The Following User Says Thank You to Joesurf79 For This Useful Post:
Code Monkey (11-27-2018)
Old 02-26-2019, 11:34 PM   #22
GrabTheWheel
Drives: 16' BRZ
You ever finish your surge tank setup?
Old 02-27-2019, 12:56 PM   #23
Turbo
Drives: FR-S Turbo
Are you ready to wear a fire suit every time you're in the car? Are you boosted? Ethanol?
What if the surge tank/external pumps were mounted outside - under the car? OEMs did that for decades without issue. You could even build a thick-walled housing, to protect it from damage.
I see they offer a horizontal mount system now.
Old 02-27-2019, 01:48 PM   #24
Still need a fire suit. It's safer in the car within the shell.
Of course, someone will do this on their street car anyways. It's their life.
Old 02-27-2019, 02:03 PM   #25
GrabTheWheel
Drives: 16' BRZ
Almost every modification you do to a car aside from brakes in someway might endanger your life. I still think the worst one is giving up the the steering wheel airbag in a street car. Mine will not be a street car for long, it's on the path to full time track car just not there yet...
The Following User Says Thank You to GrabTheWheel For This Useful Post:
CSG Mike (02-27-2019)
Old 02-27-2019, 02:13 PM   #26
Some more so than others, but messing with the fueling system has much higher consequences than say... using a different brand of tires, with TUV approved wheels.
Old 02-27-2019, 02:43 PM   #27
GrabTheWheel
Drives: 16' BRZ
Understood. It wasn't really something I wanted to do but I don't think I'd be able to make it through a single 20 minute session without starvation even with a full tank of fuel without one. I looked at the Radium fuel hanger and after everything was done including converting from OEM returnless system to traditional return system it was going to cost way more than a surge tank with no guarantee of fixing the issue. It definitley was a compromise as is everything when it comes to a street/track car.
Old 02-27-2019, 08:48 PM   #28
Turbo
Drives: FR-S Turbo
Understood.
Mike - what have you done to combat this issue with your track car? You're running a boosted setup with similar HP to me in your '86.
I have had zero problems to date in mine -- but I also haven't driven any tracks with long, left hand sweepers. I will be driving a few new tracks this coming season, and I'd rather solve this issue before running into it.
I do have an idea - anyone have a picture of the top of an FRS/BRZ fuel tank out of the car I can take a look at??
DIY : Draining the gas tank - Methods to empty fuel tank Mermoz DIY (Do-It-Yourself) Guides 13 10-09-2025 03:56 PM
JUN GT SURGE TANK FOR FT86/BRZ scubie.brz Engine, Exhaust, Transmission 60 11-23-2020 08:48 PM
Radium Engineering developing dual in-tank pump hanger slicktop Forced Induction 18 06-13-2017 03:42 AM
SARD Surge Tank Kit w/ ITB from TAS 2017 mav1178 Engine, Exhaust, Transmission 50 05-12-2017 11:50 PM
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion Xero-Limit Engine, Exhaust, Transmission 42 04-27-2017 10:16 PM
