Old 10-23-2018, 01:32 PM   #15
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Originally Posted by Tristor View Post
After resolving the issue with a stuck caliper, do you think this will resolve your wear issue? Was the stuck caliper on the same location as the tire that was wearing oddly?
It was, but truth be told I don't know. I think it would be smart to double check the alignment as I plan to, and I'll report back with my findings.
MCTeeJ is offline   Reply With Quote
Old 10-23-2018, 01:47 PM   #16
humfrz
Originally Posted by Bonburner View Post
I don't know about you guys, but alignment shops seems to mess up on my car .. a Lot.
I've had 2 shops mess up on me consecutively (after 3 days alignments go out each time) until I took it into the dealerships and they finally had everything tightened down right.
Well, I guess now, that you know of two places NOT to take your car for an alignment -
humfrz
Old 10-23-2018, 01:50 PM   #17
humfrz
Good plan!
humfrz
Old 10-23-2018, 02:04 PM   #18
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
What is your strut to tire clearance? Do you see any black marks / rub marks anywhere?
Old 10-23-2018, 02:17 PM   #19
cjd
cjd's Avatar
Drives: 2017 BRZ
That looks like wear from turning while stopped to me. Well, not so much wear as scrapes and scratches in the rubber from stones rolling / being crushed.
Old 10-23-2018, 02:27 PM   #20
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Something else to consider is that if the tire is chopping,the struts may be losing their capacity and leaking. I've seen this wear on vehicles when the spring is going most of the working, causing it to hop around. You end up with strange wear like that.
Since you've had caster, camber and toe checked, and are comfortable with them, I'm not sure what else it could be aside something allowing play in the wheel/tire
EDIT: The rest of the world refers to this as " cupping"
Old 10-23-2018, 02:42 PM   #21
MCTeeJ
MCTeeJ's Avatar
quite a bit of clearance considering I have coilovers lol
Old 10-23-2018, 02:48 PM   #22
MCTeeJ
MCTeeJ's Avatar
My coilovers are 1.5 years old I would hope they aren't going already. I've inspected the struts and haven't found any leaks either. I have learned in the past however that sometimes tires that aren't balanced well can cup especially in combination with stiff suspension. I guess I have a few things I can check.
Old 10-23-2018, 02:50 PM   #23
Summerwolf
Panda Trueno
Summerwolf's Avatar
I didn't look at your build thread and there is nothing in your signature. You see that kind of marking sometimes when there is shit clearance at the fender or the strut and the tire makes occasional contact.
I'm guessing you have no obvious marks or residual rubber anywhere?
Old 10-23-2018, 02:57 PM   #24
DarkPira7e
DarkPira7e's Avatar
Yeah if the wheels aren't balanced I guess it could contribute to this, but they'd probably give you serious vibration. I have no excuse for being so unobservant, didn't realize you were on aftermarket coilovers.
If it's only 1 tire doing it, I would tear that side apart, wrench everything down to be sure it's tight and re-assemble. I really suspect something loose, letting the adjustment suffer through a rough ride but not enough to affect the alignment you're being given.
Old 10-23-2018, 02:58 PM   #25
MCTeeJ
MCTeeJ's Avatar
No rub marks or anything like that, no. I'm hoping I find something alignment related or wheel balance related Sunday.
Old 10-23-2018, 03:04 PM   #26
MCTeeJ
MCTeeJ's Avatar
Forgot to mention this as I briefly checked today after rotating my tires last night. It seems the odd scuffing is most prominent on the passenger front but is also less present, but present, in the rear. Both driver side tires have straight wear lines. I'm slowly being swayed toward either alignment/crappy tire balance/bad tires themselves.
Old 10-23-2018, 03:25 PM   #27
DarkPira7e
DarkPira7e's Avatar
It could be gnomes with razor blades slowly attacking your tires one at a time. I'd considering driving through deep mud puddles
Old 10-23-2018, 03:27 PM   #28
MCTeeJ
MCTeeJ's Avatar
They'll never get my remaining tires! I'll put them in shrink wrap for safe keeping
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 07:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 12:55 PM
Front Passenger Tire Cupped shellslinger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-12-2017 10:52 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 03:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 11:31 AM
