Old 05-06-2014, 10:45 AM   #15
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by OICU812 View Post
To avoid any chance of rubbing outer fender. 2 year old thread lol.
Seemed more appropriate than starting a new thread and then referencing this one. I could be wrong.
Originally Posted by DAEMANO View Post
Two, no three reasons I can think of:
1. 25mm & 35mm might just make you hella flush (meaning you need the negative camber to tuck the tires under the fenders). Not everyone wants this, so most I've seen go 20mm and 25mm or 20mm and 30mm.
2. The stock tires/wheels are quite skinny so hella flushing a skinny setup can look rather dorky.
3. Scrub radius is already pretty far out there at 20/25, going any further might not be such a hot idea.
For 1&2, if it's only a 1inch drop, wouldn't there still be enough gap between the tire and fender so it wouldn't be hella flush with chance of rubbing fubber?
Sorry if these are newbish questions.
TM is offline   Reply With Quote
Old 05-06-2014, 01:37 PM   #16
DAEMANO
Time Traveller
They shouldn't tuck or rub at this point, but they might poke a bit.
Here is mine on 20/25 spacers with 1.125 drop in front and 1.25 in rear (after the springs settled).
http://www.ft86club.com/forums/showp...92&postcount=7
Old 05-07-2014, 02:31 AM   #17
LT
LT's Avatar
Drives: Raven FRS
Here's my setup. Eibach sportlines and 20mm and 25mm spacers. Just about flush except the rear. 30mm should do, because of the camber.
Flappy Paddlez~
LT is offline   Reply With Quote
The Following 3 Users Say Thank You to LT For This Useful Post:
93cc (05-12-2014), gramicci101 (05-07-2014), Tristor (03-27-2018)
Old 05-07-2014, 09:36 AM   #18
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
@LT that actually looks really good. Love the blacked out badges.
Originally Posted by humfrz
I'm old and lazy
LT (05-08-2014)
Old 05-12-2014, 10:26 PM   #19
93cc
Drives: 2017 GT86
RCE Yellow's installed with ICHIBA V2 Spacers 20mm (F) and 25mm (R)
after things setting in... I'll get measurements
93cc is offline   Reply With Quote
The Following User Says Thank You to 93cc For This Useful Post:
Mr.Impreza (05-12-2015)
Old 10-02-2014, 05:01 PM   #20
bobsacamenoh
Drives: 2014 Scion FRS
How has this set up been after a few months now? How has the steering/handling feel changed? Better or worse? And ride comfort? I'm mainly worried about a bouncy ride with the springs.
Thanks!
bobsacamenoh is offline   Reply With Quote
The Following User Says Thank You to bobsacamenoh For This Useful Post:
theneptune86 (03-25-2022)
Old 10-12-2014, 08:12 PM   #21
93cc
Drives: 2017 GT86
^not bouncy at all... I little more stiff but not too much for DD and steering/handling are awesome... You will need an alignment and you might want to get some caster bolts too, I did.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
Which stock JDM wheels do you prefer? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 40 02-08-2012 07:34 PM
