Old 04-17-2019, 01:49 AM   #15
srscion
srscion's Avatar
Drives: 2016 FRS
Originally Posted by Shark_Bait88 View Post
Saw in the comments of one of your videos that you're working on a swap kit. Is that still something you plan to produce? Any clue on ETA/cost estimate?
Definitely still plan on producing, just playing it by ear if any real interest will be generated. I am working with someone for a total canbus solution that has 100% full integration and I have an adapter plate design ready to go. My personal installation was pretty easy but I want the total swap to be as painless as possible.
srscion is offline   Reply With Quote
The Following User Says Thank You to srscion For This Useful Post:
Shark_Bait88 (04-17-2019)
Old 04-17-2019, 02:01 AM   #16
srscion
srscion's Avatar
Drives: 2016 FRS
Here is the car's current look. I am still in the middle of producing a respectable looking hood. The car makes between 320-340whp on 11 psi and roughly 350ft lbs of torque. The car weighs 2822 fully loaded and has nearly 50/50 balance left to right and from front to back is the same as stock. I will have a video of this thing in action after the hood is done.
The Following 5 Users Say Thank You to srscion For This Useful Post:
Dadhawk (04-17-2019), Irace86.2.0 (04-17-2019), mrg666 (04-27-2019), Sportsguy83 (04-17-2019), Tcoat (04-17-2019)
Old 04-17-2019, 02:07 AM   #17
srscion
srscion's Avatar
Drives: 2016 FRS
Any pics of the adapter? Curious to see how it works with the stock trans, clutch fork and the 2AZ flywheel, etc.
So engine, turbo, manifold, engine management, custom trans adapter, etc was $3k? What about BOV, external wastegate, intercooler setup, etc? I’m still confused how this all came together so cheap.
The engine came from a junkyard. It was stupid cheap ($240) It only needs to last long enough to complete all the trials I am putting it through because I want this build to be OEM spec strong (by Toyota standards) After that I might replace it with a fully built motor or an OE spec reman, either way I can get at least 5 years out of the 2az boosted and this is 5 years of intense use. The wastegate and BOV are both tial, the intercooler is from ebay, the oil cooling setup is G+. The engine management is a dual ecu configuration with AEM fuel and ignition management.
Old 04-17-2019, 02:08 AM   #18
srscion
srscion's Avatar
Drives: 2016 FRS
Originally Posted by evomike View Post
possibly had alot of that stuff laying around from old builds, i know i have all kinds of random parts laying around from years of modding cars.
I re-purposed and modified some things designed for the fa20 to work with the 2az so it saved me some money.
Old 04-17-2019, 09:07 AM   #19
Chillemall
Drives: Raven FRS
I love these engines.. I wish they'd sit a little better in the engine bay though. I would have done this swap too.
Strictly Performance Motorsports |Team PARTYCRASHERS| IG _Trainwreck
Chillemall is offline   Reply With Quote
Old 04-17-2019, 09:53 AM   #20
evomike
Drives: frs
why does the engine sit so high? Tony Angelo's sat completely under a flat hood.
evomike is offline   Reply With Quote
Old 04-17-2019, 11:45 AM   #21
srscion
srscion's Avatar
Drives: 2016 FRS
Tony Angelo had a 4 speed dogbox transmission that was different dimensions than the stock trans and of course he modified the mounting of this transmission in the tunnel. Different driveshaft and so on. I did no cutting or welding. The motor literally sits in the same spot as the fa20. Its just 3 inches taller.
Old 04-17-2019, 12:15 PM   #22
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
How did the adapter work with a stock 2ar flywheel and fa20 transmission? Did you have to machine the input shaft or what? What did you do about the fork/tob? Convert to hydraulic?
Old 04-17-2019, 12:38 PM   #23
gtpvette
Drives: 2015 FRS - FFR GTM
That engine compartment is super tidy. Nice job! No way not to have brace go all the way through the hood???
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
srscion (04-17-2019)
Old 04-17-2019, 12:47 PM   #24
srscion
srscion's Avatar
Drives: 2016 FRS
The motor I am running is a 2az-fe. I did not want the 2ar for various reasons. Availability, price, the fact that it has a plastic oil filter housing. I am using the stock clutch disc designed for the transmission input shaft and an act pressure plate designed for the motor as well as the stock flywheel for the motor. I have a hydraulic release bearing kit from Money Shift Racing, I just have not put it in yet. I'm going to wait until the stock release bearing gives up.The way I designed the adapter plate everything fits like a glove.
Old 04-17-2019, 12:48 PM   #25
srscion
srscion's Avatar
Drives: 2016 FRS
I have a custom hood that will cover everything up in a very elegant way.
gtpvette (04-17-2019)
Old 04-17-2019, 04:18 PM   #26
Irace86.2.0
Yea that was my mistype.
Normally an adapter plate adds distance between the donor engine and the stock transmission. Because of this, the splines on the input shaft don't fully fit on the clutch disc, and the end of the input shaft doesn't reach the pilot bearing. Usually this is accommodated by making a custom pilot bearing piece and a thickened flywheel.
As far as the clutch cylinder, I was having a major brain fart, thinking the cylinder mounted on the edge of the engine (which would require some consideration with a swap), and not on the transmission. I've pulled my tranny, so I should have known better.
Old 04-17-2019, 04:47 PM   #27
srscion
srscion's Avatar
Drives: 2016 FRS
Everything you said is correct. That's why I spent 6 months planning and 3 months executing.
Old 04-17-2019, 05:00 PM   #28
Irace86.2.0
Is it a secret?
Toyota Aristo Engine Harness Conversion to USDM Supra TT to Swap into FRS ThePurist Engine Swaps 0 11-23-2017 09:13 PM
Toyota left a nice surprise if you're doing a Toyota motor swap.. Manji Engine Swaps 15 01-07-2015 02:48 AM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 02:56 AM
Engine Swap hybrid35 Southern California 0 01-07-2013 02:04 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 04:58 AM
