#15 | |
The shifting challenge To understand the "timing" of shifting a MT, I suggest you try this technique. With the transmission warmed up, learn to shift UP the gears WITHOUT using the clutch OR blipping the throttle. Drive your car a couple miles out to a quiet country road, without a co-pilot, so you can become one with your transmission. Yes, use the clutch to put it into first gear, after the car gets going, let off the gas and slip the car into second gear (without using the clutch or hitting the throttle). Do the same from 2nd to 3rd and 3rd to 4th. Once you "learn" the timing, by getting it "right", you should be able to shift up through the gears without feeling (or hearing) the gears mesh and NOT using the clutch. After you have mastered this technique, shifting using the clutch is a snap. If old humfrz can consistently do this in his FR-S, I know you can in your car. |
#16 |
Wes
How much labour would a shop charge for something like that? How long does it take
Instagram: @gt86ws
#17 |
Wes
Well...I can comfortably say that I'd never attempt something like that haha
Instagram: @gt86ws
#18 | |
Really! How many of ya'll out there can do this consistently in your FR-S or BRZ ?? humfrz |
#19 | ||
not playing cards
#20 |
Because compromise ®
Drives: Red Herring
Wrong hole.
#21 | |
Drives: Pending
Which steering rack bushings did you get for the BRZ? I got the Mazda3 to not get in the modding game, but ended up modding a good amount...lowering springs, engine mount, and of course tires. However, I found out the hard way I can't really live with a boring car. |
#22 |
Drives: 2016 Subaru BRZ
I went with Whiteline, I have a bunch of their inserts for other bushings. I can feel every bump in the road(not in a bad way). The only thing I have done with the Mazda 3 so far is added hood struts because I hate using props now.
#23 |
Drives: '14 Monogram, '95 Miata, '90 300ZX
I can drive mine just fine but I hate the lack of feel in the clutch. Might have to do that master cylinder swap. At least the electric power steering is excellent as far as electric power steerings go.
| DIY - Easy clutch grab adjustment (~10 mins) | Koji_Online | DIY (Do-It-Yourself) Guides | 745 | 11-09-2022 12:44 AM |
| EZCarLift Easy car lift portable super easy car lift | bren5279 | Mechanical Maintenance and Tools | 16 | 09-11-2015 01:57 PM |
| Easy Clutch Grab Adjustment | frsfreak | Southern California | 2 | 03-28-2014 04:13 AM |
| Anyway easy way to fix this? | FRSure | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 22 | 01-06-2014 09:54 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
