Old 08-16-2018, 09:50 PM   #15
I just gave up at some point. I have no idea where it engages or where to get back on the throttle. There is no feel and no communication through the pedal. Sometimes it works, but I don't know why or how. It's accidental. I have found no consistent way.
Here ya go, StraightOuttaCanadaEh, and others.
The shifting challenge
To understand the "timing" of shifting a MT, I suggest you try this technique.
With the transmission warmed up, learn to shift UP the gears WITHOUT using the clutch OR blipping the throttle.
Drive your car a couple miles out to a quiet country road, without a co-pilot, so you can become one with your transmission.
Yes, use the clutch to put it into first gear, after the car gets going, let off the gas and slip the car into second gear (without using the clutch or hitting the throttle).
Do the same from 2nd to 3rd and 3rd to 4th.
Once you "learn" the timing, by getting it "right", you should be able to shift up through the gears without feeling (or hearing) the gears mesh and NOT using the clutch.
After you have mastered this technique, shifting using the clutch is a snap.
If old humfrz can consistently do this in his FR-S, I know you can in your car.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
jcw99 (08-17-2018), Ultramaroon (08-16-2018), x808drifter (08-17-2018)
Old 08-16-2018, 09:58 PM   #16
Wes
I'm telling you. Do my clutch mod. You will fall in love with your car all over again.
How much labour would a shop charge for something like that? How long does it take
Instagram: @gt86ws
Old 08-16-2018, 10:01 PM   #17
Wes
Well...I can comfortably say that I'd never attempt something like that haha
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (08-16-2018), radroach (08-18-2018)
Old 08-16-2018, 10:19 PM   #18
Well now, It's really not all that difficult. When the timing is right, the shifter will slip out of the lower gear, and after you point it to and give it a nudge, it will slip into the next higher gear.
Really!
How many of ya'll out there can do this consistently in your FR-S or BRZ ??
D-rek07 (08-17-2018), Ultramaroon (08-16-2018)
Old 08-16-2018, 10:22 PM   #19
Easy hour or less. Looks like way more because I was so detailed. The slave cylinder in this car is stupidly accessible. Guess that makes up for the plugs. :/
Legit technique. @humfrz is absolutely correct. You won't ruin your transmission unless you fuck up on purpose a lot.
humfrz (08-17-2018), StraightOuttaCanadaEh (08-16-2018)
Old 08-17-2018, 02:26 AM   #20
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Stock clutch is like driving with a condom. Can't feel shit.
Wrong hole.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
churchx (08-17-2018), Ultramaroon (08-17-2018)
Old 08-17-2018, 12:08 PM   #21
squelchy451
Drives: Pending
Originally Posted by Trueweltall View Post
I happen to own a 2018 Mazda 3 so I can give you some direct experience. The clutch in the BRZ has a lot more feeling compared to the Mazda 3, it also has a shorter travel too. Pushing the clutch all the way in on the Mazda 3 just feels like it goes forever. The shifter is also more direct feeling than the Mazda 3, probably because its RWD and not FWD, so you don't have 8 feet of clutch cable to manipulate the gears. The steering in my Mazda 3 is a lot more vague than the BRZ, even more so after installing stiffer steering rack bushings.
My advice is to drive in your bare feet to get a good feeling for the clutch engagement and then add shoes in the mix. I live in Florida so it's easy to kick the flipflops off and then drive around.
I did test drive the BRZ, and the clutch is the only thing I didn't get a ton of feedback from, but it's difficult to get a feel for the clutch, having driven only 3-4 different manual cars.
Which steering rack bushings did you get for the BRZ?
I got the Mazda3 to not get in the modding game, but ended up modding a good amount...lowering springs, engine mount, and of course tires. However, I found out the hard way I can't really live with a boring car.
squelchy451 is offline   Reply With Quote
The Following User Says Thank You to squelchy451 For This Useful Post:
Old 08-17-2018, 10:14 PM   #22
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I went with Whiteline, I have a bunch of their inserts for other bushings. I can feel every bump in the road(not in a bad way). The only thing I have done with the Mazda 3 so far is added hood struts because I hate using props now.
Trueweltall is offline   Reply With Quote
Old 08-18-2018, 05:55 AM   #23
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
I can drive mine just fine but I hate the lack of feel in the clutch. Might have to do that master cylinder swap. At least the electric power steering is excellent as far as electric power steerings go.
Yardjass is offline   Reply With Quote
DIY - Easy clutch grab adjustment (~10 mins) Koji_Online DIY (Do-It-Yourself) Guides 745 11-09-2022 12:44 AM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 01:57 PM
Easy Clutch Grab Adjustment frsfreak Southern California 2 03-28-2014 04:13 AM
Anyway easy way to fix this? FRSure Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 22 01-06-2014 09:54 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
