Old 08-14-2018, 05:29 PM   #15
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Don't know what thread you were in but I had a set of Rhinoramps that served me well for many years. Of all the ramps I used over the decades these were my favorite.
https://www.homedepot.com/p/FloTool-...09MI/205152558
Did you use these with your FRS? They were too steep to get my (stock) BRZ up on. I would like something like the Race Ramps, but they are six times as much $:
https://www.summitracing.com/parts/b...CABEgJo0PD_BwE
bmxr is offline   Reply With Quote
Old 08-14-2018, 06:03 PM   #16
I have not.The angle of the lip on the Talon worked but it was a bit different than the FRS
Old 08-14-2018, 06:17 PM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I have a set of rhinos, but like Tcoat, I also haven't tried using them with my twin. I will have to check. I'm lowered an inch.
Old 08-14-2018, 11:41 PM   #18
bmxr
bmxr's Avatar
I tried...
Old 08-15-2018, 10:37 AM   #19
Dake
Dake's Avatar
I use these to change my oil. They are just a hair steep, but a 1x4 at the lead-up gives just enough clearance.
Dake is offline   Reply With Quote
Old 08-15-2018, 11:43 AM   #20
extrashaky
Drives: 2014 BRZ Limited
Or maybe you could skip the jack altogether.
Old 08-15-2018, 04:29 PM   #21
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by BigTuna View Post
Those are the ones! I see Cusco also has them, but at about $95 a pair These are $45 a pair. I'm going to order two pair. That'll keep the car level for fluid changes and stuff.
Qwimby1 is offline   Reply With Quote
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 12:41 AM
FS: HF Jack $65, Ramps $45 retrosmiths Mechanical Maintenance and Tools 1 10-22-2014 02:26 PM
Ramps for low cars Gunman DIY (Do-It-Yourself) Guides 10 06-11-2014 02:57 AM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
