Old 08-14-2018, 11:11 AM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Wheel ramps
Somebody recently posted a thread about getting a jack under the front of the car. Somebody replied with a link showing ramps to drive up on. I've looked all over and can't find that thread. I've been using two by eights but they're heavy and sometimes hard to get up on. I can't get any lumberyard here to cut the sides at an angle. The ramps in the link looked like they were rubber and probably lighter and easier to use.
Qwimby1 is offline   Reply With Quote
Old 08-14-2018, 11:48 AM   #2
Don't know what thread you were in but I had a set of Rhinoramps that served me well for many years. Of all the ramps I used over the decades these were my favorite.
https://www.homedepot.com/p/FloTool-...09MI/205152558
Old 08-14-2018, 11:58 AM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Originally Posted by BigTuna View Post
When I was lowered, my jack wouldn't fit either. I build some low profile ramps out of some 1x12 board. after driving up on it, the jack slid right under.
Something like this. https://forum.miata.net/vb/showthread.php?t=537487
I've also got a low profile jack from harbor freight that works like a charm as well.
https://www.harborfreight.com/3-ton-...ump-62326.html
This one?
BigTuna is offline   Reply With Quote
Old 08-14-2018, 12:07 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
My solution:
http://www.ft86club.com/forums/showp...0&postcount=10
Old 08-14-2018, 12:16 PM   #5
gravitylover
I wish that the store bought ramps were higher. Most of them barely lift this car enough to get under it to work. Years ago I had a set of steel ramps that brought the car up 16", those were really useful.
I was looking for a good way to get the car up high and motorcycle lifts kept popping up in my search so I started thinking that since they handle 1k-1500# each why can't we just put one under each wheel and lift the car 16 or 18"? It seems to me that a ~2800# car should be safe on 4 of these. No?
Old 08-14-2018, 12:26 PM   #6
I got those for my lowered Talon. Anything with much more lift just didn't work since I could not get the car up onto them. It was tight but I could get under the car without too much issue. Although now that you mention it I could probably only get halfway under the car nowadays.
The weight may be OK for the bike lifts but I would have some concerns about stability with all wheels up in the air.
Old 08-14-2018, 12:28 PM   #7
gravitylover
Hahaha
I was thinking to put them under the wheels rather than where you'd put jack stands.
Old 08-14-2018, 12:38 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Cusco jack assist ramps are awesome. Lower slope to help lowered cars get easily and then separate into two pieces to store in a small box
MJones_RB (08-14-2018)
Old 08-14-2018, 12:44 PM   #9
Qwimby1
There were just little risers, maybe 2 inches, to get the car high enough to get jacks under it. I know there was a link to them but can't find it. I use boards like a lot of us, but these looked pretty light and easy to carry and use.
I've thought about Rhino ramps for other applications, but they're not helpful when you need to pull a wheel.
Old 08-14-2018, 02:37 PM   #10
BigTuna
BigTuna's Avatar
The Following User Says Thank You to BigTuna For This Useful Post:
Qwimby1 (08-15-2018)
Old 08-14-2018, 04:11 PM   #11
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Yeah they're handy to have
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
finch1750 (08-14-2018), xArchangelx (08-14-2018)
Old 08-14-2018, 04:16 PM   #12
Those are sweet!
ichitaka05 (08-14-2018)
Old 08-14-2018, 04:27 PM   #13
ichitaka05
Site Moderator
ichitaka05's Avatar
Those are sweet!
Yeah, they had pink ver which I wanted, but I was broke back then, so couldn't get it... correction, I'm still broke lmao
The Following 4 Users Say Thank You to ichitaka05 For This Useful Post:
Leonardo (08-14-2018), strat61caster (08-14-2018), Tcoat (08-14-2018), wulfstan (08-15-2018)
Old 08-14-2018, 05:13 PM   #14
Freakin' weebo!
Oh... wait....
ichitaka05 (08-15-2018)
Recommended Car Ramps for the BRZ/FRS? mechaghost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 09-01-2017 12:41 AM
FS: HF Jack $65, Ramps $45 retrosmiths Mechanical Maintenance and Tools 1 10-22-2014 02:26 PM
Ramps for low cars Gunman DIY (Do-It-Yourself) Guides 10 06-11-2014 02:57 AM
ramps + jack stands so26 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 04-23-2013 04:43 PM
