Old 08-14-2018, 01:38 AM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think longer bolts and new under mount plates are what is needed though. Forget the foam.
I dunno, Leo. I've been keeping my mouth shut. Feel bad for the kid but that trunk lid is toast. Maybe longer bolts and spacers between the sheet and some creative bracing... Gets complicated quickly.
Old 08-14-2018, 02:23 AM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, the trunk lid is FUBAR . Some creative efforts could save it though. Some welding, bodywork, and paint. Good as new... well not new. But it would be functional.
I LIKE TIRES!
Old 08-14-2018, 02:35 AM   #17
Ultramaroon
not playing cards
That's about it, really.
Leonardo (08-14-2018)
Old 08-14-2018, 09:27 AM   #18
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
too late but you have a 17' right? Could have bought the drambeenie risers for the stock wing
SuperTom is offline   Reply With Quote
Old 08-14-2018, 09:34 AM   #19
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by SuperTom View Post
could he use that stuff from home depot great stuff or whatever its called
No, that stuff sucks for structural applications. Real structural foam is literally rockhard when cured. Like you can hit it with a hammer.
I agree that the proper way to install he wing is to use longer bolts and backing plates through the bracing rather than cutting large holes in the bracing.
The trunk lid is already structurally ruined in those spots, so why not give the foam a shot? I'm willing to bet it does the job, I use this on composite airplanes, and BMW used a similar foam to reinforce their subframe mounting areas after it turned out they went too thin on the metal.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Leonardo (08-14-2018), texastwurkt3am (08-14-2018)
Old 08-14-2018, 02:01 PM   #20
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
Originally Posted by JoeC View Post
what on earth did you use to cut those access holes?
Cone bit from the top, but a Dremel on the underside. Disc broke and the guy at Home Depot sold me the wrong replacement ones. Gonna fix it later when I brace it
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
texastwurkt3am is offline   Reply With Quote
Old 08-14-2018, 05:38 PM   #21
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
As others have said, beyond trying foam and hoping of the best, its FUBAR.
Get a new trunk and megarisers. That'd be about as functional as that wing and less ricey.
Old 08-14-2018, 07:01 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Just read this thread. Doesn't look like anyone has made it clear to OP what he did wrong, and why it is toast. What a drag (no pun intended), a new trunk and paint is a pretty expensive lesson.
Old 08-14-2018, 10:50 PM   #23
Ultramaroon
not playing cards
OP, do you see where you goofed? We can discuss if you like.
Leonardo (08-15-2018)
Old 08-15-2018, 10:15 AM   #24
GrantedTaken
By the way, this is why I would never buy a modded car.
Kid takes perfectly good trunk lid and ruins it.
$500 for a new trunk
$500 to get it painted.
GrantedTaken is offline   Reply With Quote
Old 08-15-2018, 10:16 AM   #25
GrantedTaken
$500 for a new trunk. $500 to get it painted.
It adds up very quickly.
Old 08-15-2018, 05:42 PM   #26
texastwurkt3am
Drives: '17 PP BRZ
I don't like the risers tho. I liked this wing because it's subtler than others. I'm allowed one ricey thing lol
I thought the sheetmetal was thicker than it was and ruined it by not bracing it against anything but flimsy metal
I'm 30, and I had just installed locking hood latches that took all my mental effort into making them flawless. I assumed this was just measure, drill, and tighten. I'm not really too worried about making a mistake on something I'd never done before. You live and learn. If the foam helps, it helps, if not, I'll buy another trunk.
The one time you don't look up a DIY...
Old 08-15-2018, 11:26 PM   #27
Ultramaroon
not playing cards
Yeah. You said it, though. Live & learn.
I'm 30
Haha... oops. I think I started that.
texastwurkt3am (08-16-2018)
Old 08-15-2018, 11:42 PM   #28
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Still no explanation ultra. Op still doesn't get it. The structure was there, you cut it out.
Didn't it come with instructions?
Brace FRS/BRZ/86 trunk for GT Wing/Trunk lateral movement Ashikabi DIY (Do-It-Yourself) Guides 2 09-09-2016 05:04 PM
Truck brace to support a wing 08stiguy Cosmetic Modification (Interior/Exterior/Lighting) 29 03-30-2016 02:52 PM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 05:19 PM
sold all Whiteline Rear sway brace also dc Sports lateral brace stiboost08 Brakes, Suspension, Chassis 25 07-19-2015 08:49 PM
Wobbly gas pedal? Rayme Issues | Warranty | Recalls / TSB 1 09-30-2014 10:19 AM
