Old 06-18-2018, 01:44 PM   #15
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Well dig around and let us know what you find. Maybe someone else can chime in here with better advice.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
Nightflo (06-18-2018)
Old 06-18-2018, 02:13 PM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Nightflo View Post
It’ll stay on when I turn it on that way but it’ll idle so rough that it freaks me out so I shut it off
A rough idle isn't going to kill anything, but a log of it might help with diagnosis. I do wonder if it's something to do with fuel pump or fuel delivery somewhere. How's the DI ECU grounding connections?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-18-2018, 02:26 PM   #17
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
check all cold side piping and make sure everything is tight. Make sure the MAP sensor is correct (plugged in/right one) and make sure your MAF sensor is plugged in as well.
pgranberg11 is offline   Reply With Quote
Old 06-18-2018, 02:34 PM   #18
Nightflo
Nightflo's Avatar
The ground is good, first time I ever did injectors(supercharger it) I didn’t have ground, a code popped up. This time it’s griunded good. I was honking about logging it on the rough idle to better pinpoint it. Also, I was thinking reflashing to one of my old tunes I had for supercharger that didn’t run off the MAF to see if it will turn on and if it does, it’ll be my MAF being bad. Lastly, maybe spark plugs were put in correctly?
I’m making a list of everything to check for when I do it on my next day off. I work a ton and get 1 day off a week.
If I can’t figure it out, anybody know a good shop that specializes in brz near LA?
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Nightflo is offline   Reply With Quote
Old 06-18-2018, 02:36 PM   #19
Nightflo
Nightflo's Avatar
Checked it, everything looks good
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Old 06-18-2018, 02:40 PM   #20
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
dang, not sure what else to check. the only other thing is make sure the tune has the injectors scaled right and the fuel pump is mechanically functioning is all good. (i doubt the injectors are scaled incorrectly since DT is a pretty reputable tuner.)
The Following User Says Thank You to pgranberg11 For This Useful Post:
Old 06-18-2018, 04:38 PM   #21
Hags86
Drives: Toyota GTS 86
The car idles pretty much 100% on the OEM direct injectors so port injector scaling is unlikely to be the issue.
I'd be looking for a vacuum leak or bad electrical connection.
Hags86 is offline   Reply With Quote
The Following User Says Thank You to Hags86 For This Useful Post:
Old 06-18-2018, 04:46 PM   #22
Nightflo
Nightflo's Avatar
Tuner said vacuum was good but I’m gonna check that again along with all my fuses
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Old 06-23-2018, 07:22 PM   #23
mrloko
Drives: 2017 Subaru BRZ
did you ever find the issue
mrloko is offline   Reply With Quote
Old 06-23-2018, 10:26 PM   #24
ls1ac
ls1ac's Avatar
Interesting, we just had the same kind of problem with a new engine in the Noble. We fouled that a couple of plugs during startup and the computer saw excess o2 so it added more fuel. Making the problem worse. Disconnecting the battery to reset and putting in new plugs and the problem went away.
A lot of what if, head scratching and some language. And finally a good nights sleep before we got it.
The Following User Says Thank You to ls1ac For This Useful Post:
mrloko (06-26-2018)
car won't start, help me, turbo kit
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 10:35 PM
FR-S wont start or click... KingLos Issues | Warranty | Recalls / TSB 3 12-02-2016 02:38 AM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 01:43 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 02:01 AM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 09:57 PM
