Old 09-12-2018, 11:53 AM   #15
Chimera
Drives: FRS
some additional thoughts.. If your 3.5 is a full range coax speaker, which are pretty common, you could prob do pretty ok by ditching the stock tweeter and bridging its harness with 2 pieces of wire and some tape. Like I said before, if you bridge spots 1&2 and 3&4 then the stock 2ch harness for the 3.5 will just have straight passthru to it from the headunit, and show a 4ohm load instead. This will prob sound better than 2(4 if both sides) tweeters. Anyways, what will work bet prob depends a little on what 3.5 or 4" speaker you got.
USB adapter help gpvecchi Electronics | Audio | NAV | Infotainment 6 02-06-2019 06:26 AM
Has anyone tried to replace the rear speakers with a sub and/or larger speakers? soilent Electronics | Audio | NAV | Infotainment 9 12-28-2017 03:48 PM
DashCommand + BT1 adapter Amadeus Electronics | Audio | NAV | Infotainment 5 09-09-2014 07:59 AM
Adapter help lookchris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-09-2013 10:39 AM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
