Old 05-20-2018, 11:28 PM   #15
Bkdshadow
Drives: 2013 Scion FRS
Originally Posted by 86TOYO2k17 View Post
Most people who do FD swap don’t notice a drop of MPG, in theory yes driving at 70mph in 6th on freeway you will get like 1mpg worse (which is nothing) but a lot of people record better mpg in city driving. (Depending how you drive) and as for the noise your rpms will be higher by the same percentage increase as the Fd ratio difference. 4.1 to 4.56 is 11% 3000rpm is 3330rpm. Slightly louder but most people then drive 3-4mph slower (bonus less tickets) and noise is same.
For manuals though 4.56 or 4.67 seem to be the “sweet spot” autos a little higher. But FD swaps really depend on car use.
That’s interesting and good to know. Sounds like I just need to purchase it then, i love aggressive gearing. The IS350 I used to have had relatively aggressive gearing and that’s thing felt QUICK
Bkdshadow is offline   Reply With Quote
Old 05-20-2018, 11:30 PM   #16
Bkdshadow
Originally Posted by Teseo View Post
I really want to do fd swap but still cant stand the price tag. Still waiting for someone who crash '17 so i can buy the entire diff
I’ve heard weir performance has some pretty cheap kits you can get, like 2-300ish cheap (too lazy to look up). Way cheaper than the competitors though!
Old 05-20-2018, 11:37 PM   #17
86TOYO2k17
Drives: 2017 toyota 86
That may be the cheapest way to get a 4.3. Weir performance has some cheap ones to. Also RHDjapan has full kits everything but shims 650$ shipped prob about 3-400$ labor if you pull diff or 6-800$ labor for everything should include oil / both oil changes. Not actually that bad cost to benefit. On par or better then other bolt ons.
Old 05-21-2018, 12:36 AM   #18
Teseo
Drives: frs
He quoted me 700 or so for a fd plus installation kit
Old 05-21-2018, 12:38 AM   #19
Bkdshadow
Ah, I think it was the ratios that I was looking at for those prices. My b
Old 05-26-2018, 04:30 PM   #20
shr133
shr133's Avatar
Drives: 2013 FRS
I would get the flex fuel kit.
I just put mine on this year, still setting it up, so even with a mix of E20 to E30 runs much better with my set up and still getting 27.5 mpg. The extra timing and octane help. I think you get gains up to around E50..
So far It runs better than I thought but you need a good tune...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Ernest's Flex-Fuel, FBM Stage 2 Turbo, Built FA20-V161 Driven BRZ - PHOTON Enalband24 Member's Car Journals 78 02-04-2020 01:55 PM
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
