Old 05-25-2018, 01:41 PM   #15
Originally Posted by Cebal View Post
OK, got some code's showing up:
B27A2 : [Passenger side external antenna output stage open]
B2786 : No response from steering lock ECM
I managed to delete these codes but those 2 codes above are showing up even after I delete them:
B1011 : BATT power supply (control) malfunction
B1012 : BATT power supply (backup) malfunction
B1013 : IGN power supply failure
B1014 : ACC power failure
I checked fuse's but all are fine...
I know you charged the battery but check it again. Either it is toast or you have a really bad cable connection at the posts.
Old 05-25-2018, 02:19 PM   #16
Brz_racer
Drives: Subaru BRZ
This could possibly be an ECU problem as well, maybe try and get the ECU flashed and see what happens
Brz_racer is offline   Reply With Quote
Old 05-27-2018, 12:39 PM   #17
Cebal
Cebal's Avatar
Drives: 15' BRZ Limited
Yes, lights come up normally with bo issues, battery voltage is good too.
Im happy to say that I solved the problem. Was that simple I cant belive it caused so many problems. So few monts ago I had my passenger window changed. Since then I couldnt open the passengers door with key in my pocket. I mean I could open it clicking Unlock button twice on my key fob but not by grabing the handle with key in my pocket. Someone didnt plug the switch when I had my window changed and thats why it was causing immobilizer and start up problems... I pluged it in, deleted all codes and car runs without issues now... thanks for trying to help me. Im happy to drive it again.
Cebal is offline   Reply With Quote
The Following 2 Users Say Thank You to Cebal For This Useful Post:
humfrz (05-27-2018), sato (12-12-2022)
Old 05-28-2018, 12:55 AM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I was going to comment on this saying that "Passenger side external antenna output stage open" means something is wrong inside the passenger side door sensor, but looks like you figured it out!
Old 05-28-2018, 02:15 AM   #19
Cebal
Cebal's Avatar
Yeah but its kinda crazy that after months it started to be an issue tho
Old 12-10-2022, 03:49 PM   #20
srscion
srscion's Avatar
Drives: 2016 FRS
Sorry to resurrect a dead post but did you resolve these codes?
srscion is offline   Reply With Quote
Old 12-12-2022, 02:17 PM   #21
He said so
Opie (12-22-2022), x808drifter (12-16-2022)
Old 12-12-2022, 04:38 PM   #22
Ultramaroon
not playing cards
Ultramaroon's Avatar
He said so
"I'm too busy to read the thread."
Intermittent starting problem LS1M Software Tuning 4 06-12-2017 02:03 AM
Subaru BRZ With e85 Flex Fuel Kit Not Starting In Cold morswestford Engine, Exhaust, Transmission 52 05-03-2017 06:50 PM
BRZ limited odd starting problem. armstrom Issues | Warranty | Recalls / TSB 19 04-06-2016 10:21 PM
Del Sol starting problem Ashikabi Other Vehicles & General Automotive Discussions 5 03-22-2016 07:24 PM
Starting problem ricerocket93 Issues | Warranty | Recalls / TSB 5 09-06-2014 03:15 PM
