Old 04-25-2018, 03:45 PM   #15
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Be careful what you wish for...my wife's new Crosstrek leaves the radio on when the car is shutdown and switches it off as the door is opened, but the radio blares every time you get in the car and start it up...really annoying. Our dealer said it is the number one complaint right now with new purchases. Each to their own, I suppose.
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
The Following User Says Thank You to paiceyfan For This Useful Post:
bcj (04-25-2018)
Old 04-25-2018, 04:09 PM   #16
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
ALL my cars’ radios have done that so I thought that was normal. Besides, I’ve made it a habit to always lower the volume before turning the car off so it’s a non-issue.
Unless you mean the car raises the volume up afterwards?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-25-2018, 04:23 PM   #17
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by extrashaky View Post
Just step on the brake and pop the clutch to stop the engine.
Haven't laughed this hard in a while. Just make sure you don't park too close to the curb otherwise you'll ram into it
ajcarson11 is offline   Reply With Quote
Old 04-25-2018, 04:29 PM   #18
8RZ
The Gunshine State
8RZ's Avatar
Lol not if you step on the brake.
Current DD: M235i
Old 04-25-2018, 04:30 PM   #19
Chimera
Drives: FRS
I have a key instead of push start, but couldn't this be resolved with a capacitor on the Switched/acc power to the head unit? for oem head unit folks that would prob require a harness wired inbetween which would be a bit of work I guess.
Old 04-25-2018, 05:02 PM   #20
ajcarson11
Fair point.. but I like the mental image of ramming the curb more.
I can't imagine it's great for the car to be stopped in this abrupt fashion -- Anyone have general thoughts?
Old 04-25-2018, 06:19 PM   #21
paiceyfan
paiceyfan's Avatar
Sorry, I should been more clear...it goes to radio by default, so if you have been listening to an audiobook or music off USB, it still goes to radio when you get in the car.
Sent from my Moto G (5) Plus using Tapatalk
Old 04-25-2018, 08:54 PM   #22
I still see this as nothing but a minor annoyance but if it really bugs people they could just wire it into an always powered slot like old cars used to be. Many of my cars were like that but they were also AM only and took 3 or 4 minutes for the tubes to warm up before you heard anything. You had to always remember to turn it off though so probably still to much of an inconvenience.
Old 04-25-2018, 09:29 PM   #23
extrashaky
Drives: 2014 BRZ Limited
I was definitely kidding. Don't do it.
I have done it in other cars accidentally, and once on purpose to stop one that was running on after being shut off. None of them exploded. However, there's a definite risk to the engine, clutch and transmission. If you stop an airplane engine mechanically, for instance by a prop strike, the FAA requires you to tear it down and inspect it for internal damage before you can put that engine back in service. The stakes are lower for a vehicle that doesn't leave the ground, but the damage potential is still there.
Old 04-25-2018, 09:47 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
You saying my car has a radio?
How do you make this curandero mindscape manipulation occur?
There's an 0/l button that makes noises, but that's under utilized.
Old 04-25-2018, 09:47 PM   #25
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
If you don't mind getting behind the dash and doing some DIY, just rig up a switch in-line with the power cable and route it to the battery instead. As long as the switch is on, the radio will be on.
Jesse36m3 is offline   Reply With Quote
Old 04-26-2018, 01:48 PM   #26
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
This is the kind of innovative work arounds that I come here for
Horrid_Funk is offline   Reply With Quote
The Following User Says Thank You to Horrid_Funk For This Useful Post:
Tcoat (04-26-2018)
Old 04-29-2018, 09:00 PM   #27
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
You can always wire up 2 relays in sequence to keep the radio on until you open the door. Essentially create a feedback loop on the first relay, and the door trigger will release the loop. Wire that in series on the accessory wire and you're in business. Did it myself not too long ago.
sharpsicle is offline   Reply With Quote
Old 05-03-2018, 09:48 PM   #28
RBenz13
Custom User Title
RBenz13's Avatar
Drives: '13 SWP MT BRZ Ltd
It may just be me, but the photo's not showing...
RBenz13 is offline   Reply With Quote
Corvairs (Damnit Ultra) Tcoat Other Vehicles & General Automotive Discussions 49 07-20-2018 09:23 PM
Radio receptions cut when headlights turn on sufu05 Electronics | Audio | NAV | Infotainment 9 05-24-2015 08:14 AM
Damnit!!! Why!!! Cliu91 Scion FR-S / Toyota 86 GT86 General Forum 91 01-26-2015 06:49 PM
BRZ Limited NAV/Audio: Any way to keep the radio on when you turn the car off? DoomsdayJesus Electronics | Audio | NAV | Infotainment 13 04-16-2014 09:55 AM
Radio Flickers on Turn Signals taimysho0 Electronics | Audio | NAV | Infotainment 5 09-17-2013 08:32 PM
