Old 03-16-2018, 12:57 PM   #15
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 03-16-2018, 02:29 PM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by olsonpg View Post
That would cost a fortune.
Better off skinning it yourself of having a carbon shop skin it for you.
I wrapped my own and It took probably 40 hours of work.
Dare I ask what the toggle switches are for?
Old 03-16-2018, 03:16 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
For launching missiles, of course!
Old 03-16-2018, 04:19 PM   #18
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Old 03-16-2018, 08:41 PM   #19
Circa85
Drives: 2017 Toyota 86
KD Aerostop makes one, they make a ton of knock offs FYI if you’re not about supporting that industry.
Circa85 is offline   Reply With Quote
Old 03-16-2018, 09:01 PM   #20
Clipping_Path
Drives: 13 FRS – Whiteout
Lay the epoxy on real thick and many coats. This piece takes a lot of sanding.
Did you finish off with an epoxy spray clear coat or other UV crystal clear? Or did you just sand and polish the resin to a high gloss?
Clipping_Path is offline   Reply With Quote
Old 03-20-2018, 03:16 PM   #21
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
do you have any full pictures of your interior?
JustSomeGuy is offline   Reply With Quote
Old 03-29-2018, 02:15 PM   #22
Allen Poe
AT Pleb
Allen Poe's Avatar
Drives: 2014 FR-S Monogram (Firestorm Red)
ugh, why didn't i find out about these last month when they still had some?
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad.
Allen Poe is offline   Reply With Quote
Old 03-29-2018, 03:36 PM   #23
olsonpg
olsonpg's Avatar
I will soon! Gotta get my car back from the shop and then I will.
Old 03-29-2018, 06:13 PM   #24
Allen Poe
AT Pleb
Allen Poe's Avatar
I think there might be an outside chance they bring these back. I asked them if they could point me somewhere else I might be able to buy, and the response I got was: "Unfortunately I do not. I brought it up with my director and we've seen a demand for these lately. It may be something we bring back, I'm not sure yet."
Sooooooooooo fingers crossed
Old 04-10-2018, 11:13 AM   #25
toast
Drives: 14 BSP Edelbrock BRZ
3. Cut your carbon out then spray the entire side with spray adhesive and wait 10-15 minute before you attempt to place the carbon on your piece. (very important). This allows you to rip the carbon off your piece if you screw up placing it with no weave distortion whatsoever. I had to pull and replace my piece 3 times.
I've done several skins so far and heard about the spray adhesive method but never done it. This is just to keep the fabric a little more rigid, right? This would help tremendously when trying to cut small pieces of cloth, they always want to just come apart in your hands. No problem with the bonding strength when you lay the adhesive-covered cloth onto the base layer of resin? Or do you skip the base layer altogether and just use the adhesive? Which spray glue do you use?
thanks
toast is offline   Reply With Quote
Old 04-11-2018, 10:36 AM   #26
olsonpg
olsonpg's Avatar
thanks
Yeah, it keeps the weave perfectly in-line so your part comes out looking perfect, when overlaying and when cutting it into pieces. This helps especially when cutting smaller pieces.
I just use 3m's spray on adhesive for that and to adhere the part. 3m 77 I believe is the only one I use.
Old 04-11-2018, 06:12 PM   #27
toast
Thanks. The worst part of skinning anything is trying to sit around and wait the right amount of time for the base layer to tack up. If you can skip that and just use the spray adhesive for the base layer that will save a ton of time and effort.
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 04:42 PM
CARBON FIBER CENTER CUP HOLDER COVER cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 4 03-04-2015 01:03 PM
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
WTB Toyota Carbon Fiber Console... xcelir8brz Exterior Parts (Aero, Lighting, Etc.) 21 09-09-2012 08:38 PM
