Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-17-2018, 04:11 PM | #15 |
Drives: 2017 BRZ
Curious, if you do need to mount the oil cooler in front of the intercooler, is it better to have it as close as possible to the intercooler to reduce turbulence? Or is it smart to have room in between the cores? I’d like to keep both fogs so upfront is my only option.
01-17-2018, 07:28 PM | #16 | |
Drives: 2013 Black FR-S
It is not ideal for aerodynamics but if you need to cool things down..
The Following User Says Thank You to sw20kosh For This Useful Post: | CSG Mike (01-18-2018) |
01-17-2018, 08:22 PM | #17 |
Drives: 2017 BRZ
Thanks, I havent seen that setup before. I cant find any photos of it installed but im guessing it is mounted horizontally on the splash guard and the metal cover acts as an air dam for it? I currently have the Jackson Racing oil cooler so I'm sure I can modify it similarly.
01-17-2018, 08:27 PM | #18 |
Drives: 2015 Raven FRS
I have the e-force supercharger and mounted my oil cooler behind the hole for the driving light. Also have the AT transmission cooler on the passenger side.
The Following 2 Users Say Thank You to Lunatic For This Useful Post: | Barefootdan (01-17-2018), Cole (01-17-2018) |
01-17-2018, 08:46 PM | #19 | |
The Following User Says Thank You to sw20kosh For This Useful Post: | Barefootdan (01-17-2018) |
01-17-2018, 10:19 PM | #20 |
Wise old man
Drives: 86 GTS
Interesting, i might go move my oil cooler to the side and knock out one of the fog lights.
01-17-2018, 10:45 PM | #21 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
You can also check on FBM's oil cooler. It's a 19 row and says it will work with other turbo kits. I have one, it mounts to the left side of the intercooler if your facing it.
01-18-2018, 04:08 PM | #22 |
Have you tracked your car with the FBM oil cooler? If so what temps are you seeing?
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
01-18-2018, 06:52 PM | #23 |
Project Shadow
Not yet because my car isn't ready. I still gotta do a couple things before I take it to the track. Sorry.
01-18-2018, 11:57 PM | #24 |
Drives: 2017 BRZ
I tried to relocate my Jackson racing kit but due to the line length and angle of the fittings, I couldn’t lay it horizontally like the Harrop kit. So for now I settled on keeping it vertical. I placed it forward so it won’t interfere with the edelbrock kit. I also moved it as far to the driver side as I could to try and reduce the blocking of the LTR for the edelbrock. Hopefully this will be a compromise that won’t induce high IAT. I’ll post results when I install the kit. Anyone have an idea of what my IAT should be relative to ambient temps?
10-10-2018, 01:08 PM | #25 |
Drives: 2016 Halo FRS
10-10-2018, 03:15 PM | #27 |
Drives: Subaru BRZ
^ I know that Mike would pick the 915, but in terms of frontal area and volume the 619 and 915 are virtually the same.
10-10-2018, 03:24 PM | #28 |
https://www.pegasusautoracing.com/do...ocID=TECH00133
I’m more interested in how the cores differ, capability of cooling and pressure drop. just overthinking like I always do lol |
Similar Threads | ||||
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler | TheMedakaBox | Northern California | 4 | 08-09-2017 10:16 PM |
Oil cooler | mynameis940 | Engine, Exhaust, Bolt-Ons | 9 | 05-12-2017 11:38 PM |
WTB: FBM Oil Cooler Kit | asnatlas | Want-To-Buy Requests | 0 | 10-07-2015 12:36 AM |
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
