Old 01-17-2018, 04:11 PM   #15
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Curious, if you do need to mount the oil cooler in front of the intercooler, is it better to have it as close as possible to the intercooler to reduce turbulence? Or is it smart to have room in between the cores? I’d like to keep both fogs so upfront is my only option.
Barefootdan is offline   Reply With Quote
Old 01-17-2018, 07:28 PM   #16
sw20kosh
Drives: 2013 Black FR-S
If you must keep the fogs, a better option is to use the Harrop Engineering oil cooler kit. A friend of mine is tracking his Harrop SC'd car and is having no problems with temps whatsover.
It is not ideal for aerodynamics but if you need to cool things down..
The Following User Says Thank You to sw20kosh For This Useful Post:
CSG Mike (01-18-2018)
Old 01-17-2018, 08:22 PM   #17
Barefootdan
Drives: 2017 BRZ
Thanks, I havent seen that setup before. I cant find any photos of it installed but im guessing it is mounted horizontally on the splash guard and the metal cover acts as an air dam for it? I currently have the Jackson Racing oil cooler so I'm sure I can modify it similarly.
Old 01-17-2018, 08:27 PM   #18
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have the e-force supercharger and mounted my oil cooler behind the hole for the driving light. Also have the AT transmission cooler on the passenger side.
Lunatic is offline   Reply With Quote
The Following 2 Users Say Thank You to Lunatic For This Useful Post:
Barefootdan (01-17-2018), Cole (01-17-2018)
Old 01-17-2018, 08:46 PM   #19
sw20kosh
Yes this is how it mounts. My friends temp data is impressive.
Old 01-17-2018, 10:19 PM   #20
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Interesting, i might go move my oil cooler to the side and knock out one of the fog lights.
Surok is offline   Reply With Quote
Old 01-17-2018, 10:45 PM   #21
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
You can also check on FBM's oil cooler. It's a 19 row and says it will work with other turbo kits. I have one, it mounts to the left side of the intercooler if your facing it.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 01-18-2018, 04:08 PM   #22
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Have you tracked your car with the FBM oil cooler? If so what temps are you seeing?
tyler_win_photo is offline   Reply With Quote
Old 01-18-2018, 06:52 PM   #23
Drakiv
Project Shadow
Drakiv's Avatar
Not yet because my car isn't ready. I still gotta do a couple things before I take it to the track. Sorry.
614whp/421tq on E85
Instagram: Drakiv
Old 01-18-2018, 11:57 PM   #24
Barefootdan
Drives: 2017 BRZ
I tried to relocate my Jackson racing kit but due to the line length and angle of the fittings, I couldn’t lay it horizontally like the Harrop kit. So for now I settled on keeping it vertical. I placed it forward so it won’t interfere with the edelbrock kit. I also moved it as far to the driver side as I could to try and reduce the blocking of the LTR for the edelbrock. Hopefully this will be a compromise that won’t induce high IAT. I’ll post results when I install the kit. Anyone have an idea of what my IAT should be relative to ambient temps?
Old 10-10-2018, 01:08 PM   #25
Trust86
Drives: 2016 Halo FRS
Bump for questions.
Setrab 619 or Setrab 915?
Asking bc the 2 kits I’m considering are the Jackson racing and racer x. Car is not a daily and will see track and drifting. @sw20kosh @CSG Mike
*edit*
Car is turbocharged.
Trust86 is offline   Reply With Quote
Old 10-10-2018, 02:22 PM   #26
CSG Mike
CSG Mike's Avatar
Originally Posted by Trust86 View Post
Bump for questions.
*edit*
915 between the two.
Trust86 (10-10-2018)
Old 10-10-2018, 03:15 PM   #27
Code Monkey
Drives: Subaru BRZ
^ I know that Mike would pick the 915, but in terms of frontal area and volume the 619 and 915 are virtually the same.
Code Monkey is offline   Reply With Quote
Old 10-10-2018, 03:24 PM   #28
Trust86
https://www.pegasusautoracing.com/do...ocID=TECH00133
I’m more interested in how the cores differ, capability of cooling and pressure drop. just overthinking like I always do lol
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Oil cooler mynameis940 Engine, Exhaust, Bolt-Ons 9 05-12-2017 11:38 PM
WTB: FBM Oil Cooler Kit asnatlas Want-To-Buy Requests 0 10-07-2015 12:36 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
