#15 |
Drives: Ultramarine frs
Sorry for the newbie question. Can u explain this in detail?
#16 |
Drives: Mint-Tiffany blue FRS
| The Following 2 Users Say Thank You to kendalldwhite For This Useful Post: | Imti (01-23-2013), Snoopyalien24 (07-22-2012) |
#17 |
86DESU
Drives: 86 GTS, S13, CB9
Hm. On second thoughts I don't think my pulley's getting changed-- those drill marks are balance marks...
#18 |
86DESU
A long and strong breaker bar, is a long and strong breaker bar. Google the tool, it's important to have a good one if you work on cars. I've got a few of varying lengths and some different angles too.
If you have the car on the ground, in sixth gear, with the handbrake on tight, that will help to add resistance against the crank from the drivetrain at the -back- of the crank, meaning you can pop the nut more easily. If you have an AT, disregard this step. You're going to have to use a rattlegun (pneumatic wrench), and hope for the best. |
#19 |
Drives: B9 S4/ND2
#20 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
you can see the rubber vibration dampener in the stock pulley, it's the ring between the rib section and the inner.
If you do change the crank pulley, ensure you torque the crank pulley bolt correctly. If the bolt isn't torqued correctly it can easily flog out the snout of the crank. |
#21 |
Boostin'
Drives: FRS-T
I bought it because someone mentionned the original pulley wasnt a damper. I just looked at it and i confirm that it is. I know of a couple of people that have been running those for years without any issues. We will see. Any engineer can tell us about the downsides?
#22 |
Boostin'
Drives: FRS-T
Pic of original pulley and pen pointing at the rubber damper.
#23 |
I Love custom Turbo kits
Drives: Limited BRZ
I got the perrin pulley and installed it, but still debating if keeping it because of this....
#24 |
When In Doubt...
Drives: Slowww
Will a Perrin pulley improve how quickly the car revs up out of gear for double clutching?
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#25 |
Drives: Limited BRZ
The downside is the potential for vibrations in your motor internals, especially at high RPM.
#26 |
Kouki-Monster
someone chime in on long term risks in running this?
I know for most engines it's a horrible idea. I replaced the stock pulley on my 1JZGTE with a properly balanced Fluidampr unit
Rich Anderson
EMPOWER AUTO |
#27 |
Boostin'
Drives: FRS-T
Im thinking of getting it balanced at a machine shop
#28 | |
Drives: Limited BRZ
My question to anyone with way more knowledge than me is: are those balance marks of just the pulley being balanced, or are those marks of the pulley being balanced together with the crank, rods, pistons, flywheel?
| Perrin Crank Pulley now available | milenko11 | Engine, Exhaust, Transmission | 96 | 12-10-2017 06:45 PM |
| pulley installed issue | Sall | Issues | Warranty | Recalls / TSB | 31 | 08-14-2012 11:36 PM |
| Crank Pulley and the warranty | Brimford | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-08-2012 03:47 PM |
| Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2012 10:24 PM |
