Old 07-22-2012, 06:10 PM   #15
mach330
Drives: Ultramarine frs
Originally Posted by Silverdub View Post
Took me 10 minutes to install. Release belt tension with a 14mm wrench on the tensionner. Make sure you have a long and strong breaker bar put the car in 6th gear with the handbrake on and thats it. The crank bolt is on reallytight so dont be shy!
Sorry for the newbie question. Can u explain this in detail?
mach330 is offline   Reply With Quote
Old 07-22-2012, 06:12 PM   #16
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
[ame="http://www.youtube.com/watch?v=R4w3tJGozCM"]GrimmSpeed Subaru Lightweight Crank Pulley Install Video - YouTube[/ame]
kendalldwhite is offline   Reply With Quote
The Following 2 Users Say Thank You to kendalldwhite For This Useful Post:
Imti (01-23-2013), Snoopyalien24 (07-22-2012)
Old 07-22-2012, 06:15 PM   #17
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
Hm. On second thoughts I don't think my pulley's getting changed-- those drill marks are balance marks...
Nezz is offline   Reply With Quote
Old 07-22-2012, 06:18 PM   #18
Nezz
86DESU
Nezz's Avatar
A long and strong breaker bar, is a long and strong breaker bar. Google the tool, it's important to have a good one if you work on cars. I've got a few of varying lengths and some different angles too.
If you have the car on the ground, in sixth gear, with the handbrake on tight, that will help to add resistance against the crank from the drivetrain at the -back- of the crank, meaning you can pop the nut more easily. If you have an AT, disregard this step. You're going to have to use a rattlegun (pneumatic wrench), and hope for the best.
Old 07-22-2012, 06:38 PM   #19
D1cker
Drives: B9 S4/ND2
OP can you check to see if there is any rubber in that OEM pulley? If it's all steel them it's not a balancer or damper and is totally fine to replace.
D1cker is offline   Reply With Quote
Old 07-22-2012, 06:38 PM   #20
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
you can see the rubber vibration dampener in the stock pulley, it's the ring between the rib section and the inner.
If you do change the crank pulley, ensure you torque the crank pulley bolt correctly. If the bolt isn't torqued correctly it can easily flog out the snout of the crank.
JP is offline   Reply With Quote
Old 07-22-2012, 06:44 PM   #21
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I bought it because someone mentionned the original pulley wasnt a damper. I just looked at it and i confirm that it is. I know of a couple of people that have been running those for years without any issues. We will see. Any engineer can tell us about the downsides?
Silverdub is offline   Reply With Quote
Old 07-22-2012, 06:49 PM   #22
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Pic of original pulley and pen pointing at the rubber damper.
The Following 2 Users Say Thank You to Silverdub For This Useful Post:
Bonburner (07-22-2012), Bristecom (07-29-2012)
Old 07-22-2012, 06:50 PM   #23
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I got the perrin pulley and installed it, but still debating if keeping it because of this....
Old 07-22-2012, 07:00 PM   #24
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Will a Perrin pulley improve how quickly the car revs up out of gear for double clutching?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-22-2012, 07:21 PM   #25
Sportsguy83
Drives: Limited BRZ
The downside is the potential for vibrations in your motor internals, especially at high RPM.
Old 07-22-2012, 07:21 PM   #26
empower-auto
Kouki-Monster
empower-auto's Avatar
someone chime in on long term risks in running this?
I know for most engines it's a horrible idea. I replaced the stock pulley on my 1JZGTE with a properly balanced Fluidampr unit
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-22-2012, 07:25 PM   #27
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Im thinking of getting it balanced at a machine shop
Old 07-22-2012, 07:27 PM   #28
Sportsguy83
Drives: Limited BRZ
I read countless of threads, and people swear by this mod. Lots and lots of positive reviews, not really anyone reporting any issues with a regular LW pulley. People have issues with Underdriven pulleys but this Perrin Pulley is not underdriven. NOW I am a bit concerned, as pointed out by @Nezz, that the stock pulley is balanced.
My question to anyone with way more knowledge than me is: are those balance marks of just the pulley being balanced, or are those marks of the pulley being balanced together with the crank, rods, pistons, flywheel?
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
