#15 |
SW5 Driver
Drives: Asphalt FRS
The key is to find someone with zero ethanol. Shell here (Ontario, Canada) distinctly says ZERO ethanol in VPower fuels. My car has not had the chirp issue. Though it has the funky idle dip when decelerating.
#16 | |
6/22/12-2/6/24
#17 | |
SW5 Driver
Drives: Asphalt FRS
I understand the whole green movement but at least offer a non-ethanol alternative!http://pure-gas.org/index.jsp?stateprov=CA Found this for you. Dunno if any of these places are near you or how up to date the listings are! |
#18 | |
Drives: WRB BRZ Limited (AT)
http://www.davebarton.com/Unleaded_Racing_Fuel_in_SoCal |
| The Following User Says Thank You to hav0c For This Useful Post: | Bonburner (07-23-2012) |
#19 | |
6/22/12-2/6/24
#20 |
Drives: FT86, BMW 5, JZA80, Porsche 986S
i only noticed mine chirping when i put 100 octane (10% ethanol) in.. prior to that, i didnt notice it.. Not saying it def wasnt there, but I did not notice it.. When I fly back into australia I will try zero ethanol fuel..
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
#21 |
Lex Luger
Drives: 2004 GS430
I found a zero ethanol gas station en-route on my work commute, so when I'm back in town I will also fill up here and see what it does...
#22 |
Drives: 2013 Scion FR-S Firestorm Red MT
I'm skeptical that gas would remove the chirp. I'm fairly sure that engine load and temperature play a part in it. I've noticed it's more noticeable on hotter days as of late.
I've filled up at the same Shell gas station nearly every one of the 2k miles I have (93 V-Power) and still have it.
| The Following User Says Thank You to eriktherod For This Useful Post: | Marrk (07-24-2012) |
#23 | |
Waited 5 years for this
Drives: '18 MX-5 Club
First of all, as I posted in my previous post, the chirping went away when I switched from Chevron to Shell. Now regarding the engine load, here is what I tried today: Drive for 15 minutes, 1/2 city and 1/2 highway, and keep the rev under 3000 RPM = No chirping. Rev to 4000 RPM in 2nd gear = Chirping starts right away. Chirping stays there until I turn off the engine for a little wile. |
#24 |
Drives: 2013 Scion FR-S Asphalt
i haven't experienced the chirping.. but I have driven it on really hot days and I'm at 1500 KM.. and I've ONLY been using shell v91 0% ethanol
#25 |
Drives: 2016 STI DGM
I haven't really paid attention to the chirp or if I even have it... Been using non-ethanol fuel though as I figured the rest of the world doesn't probably use it!
Subaru STI :![]() |
#26 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
http://www.lucasoil.com/products/dis...tid=8&loc=show AutoZone carries it... |
#27 |
Drives: 2013 Whiteout MT Scion FR-S
Just topped off with 92 ethanol-free gas, hoping to have the same success as OP. Will report back shortly.
#28 | |
Sarcastic SOB
| Checking and Changing BRZ/FR-S Engine Coolant | GrimmSpeed | DIY (Do-It-Yourself) Guides | 39 | 05-29-2023 09:15 AM |
| DIY-Changing Clock/HVAC LEDs on FR-S | Lil Abner | DIY (Do-It-Yourself) Guides | 113 | 03-11-2022 02:40 PM |
| Changing the Horn? | mechaghost | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 10-27-2016 01:27 AM |
| Changing Premium to Limited? | zygrene | BRZ First-Gen (2012+) — General Topics | 32 | 10-09-2012 12:58 PM |
| I'm changing my order from World Rally Blue to Lightning Red | Subie | BRZ First-Gen (2012+) — General Topics | 26 | 06-12-2012 01:59 PM |
