Old 07-23-2012, 12:06 AM   #15
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
The key is to find someone with zero ethanol. Shell here (Ontario, Canada) distinctly says ZERO ethanol in VPower fuels. My car has not had the chirp issue. Though it has the funky idle dip when decelerating.
RandomHero is offline   Reply With Quote
Old 07-23-2012, 12:09 AM   #16
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Yeah I'm having trouble finding a single station that has 0 ethanol in Cali
Old 07-23-2012, 12:24 AM   #17
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Thats gotta be frustrating I understand the whole green movement but at least offer a non-ethanol alternative!
http://pure-gas.org/index.jsp?stateprov=CA
Found this for you. Dunno if any of these places are near you or how up to date the listings are!
Old 07-23-2012, 12:24 AM   #18
hav0c
hav0c's Avatar
Drives: WRB BRZ Limited (AT)
Originally Posted by imravenit View Post
where do you guys find 93 oct? most shell around my area (alhambra) only offers 91 oct..
There's a few places in CA offering higher octane. The most convenient place for me is in Sunol and sells 100 octane around $7/gal. 3 gallons of that in your tank and you're at about 93.1 octane.
http://www.davebarton.com/Unleaded_Racing_Fuel_in_SoCal
hav0c is offline   Reply With Quote
The Following User Says Thank You to hav0c For This Useful Post:
Bonburner (07-23-2012)
Old 07-23-2012, 12:29 AM   #19
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
yeah I checked that listing already, way far away
Old 07-23-2012, 12:33 AM   #20
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
i only noticed mine chirping when i put 100 octane (10% ethanol) in.. prior to that, i didnt notice it.. Not saying it def wasnt there, but I did not notice it.. When I fly back into australia I will try zero ethanol fuel..
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
Old 07-23-2012, 12:36 AM   #21
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
I found a zero ethanol gas station en-route on my work commute, so when I'm back in town I will also fill up here and see what it does...
YukiHachiRoku is offline   Reply With Quote
Old 07-23-2012, 01:23 AM   #22
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I'm skeptical that gas would remove the chirp. I'm fairly sure that engine load and temperature play a part in it. I've noticed it's more noticeable on hotter days as of late.
I've filled up at the same Shell gas station nearly every one of the 2k miles I have (93 V-Power) and still have it.
eriktherod is offline   Reply With Quote
The Following User Says Thank You to eriktherod For This Useful Post:
Marrk (07-24-2012)
Old 07-23-2012, 01:25 PM   #23
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I agree that it has something to do with the engine load.
First of all, as I posted in my previous post, the chirping went away when I switched from Chevron to Shell.
Now regarding the engine load, here is what I tried today:
Drive for 15 minutes, 1/2 city and 1/2 highway, and keep the rev under 3000 RPM = No chirping.
Rev to 4000 RPM in 2nd gear = Chirping starts right away.
Chirping stays there until I turn off the engine for a little wile.
Old 07-23-2012, 02:22 PM   #24
drei
drei's Avatar
Drives: 2013 Scion FR-S Asphalt
i haven't experienced the chirping.. but I have driven it on really hot days and I'm at 1500 KM.. and I've ONLY been using shell v91 0% ethanol
drei is offline   Reply With Quote
Old 07-23-2012, 02:25 PM   #25
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I haven't really paid attention to the chirp or if I even have it... Been using non-ethanol fuel though as I figured the rest of the world doesn't probably use it!
Subaru STI :
Old 07-23-2012, 03:41 PM   #26
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Pscylo View Post
Anyone ever try this stuff? I haven't seen this type of product listed, since the theme is ethanol issues...
Safeguard™ Ethanol Fuel Conditioner with Stabilizers
Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers was developed to specifically address issues associated with using ethanol based fuels. This applies to E-10, E-15, E-85, pure ethanol and any mixtures in between including gasoline. Our Product is completely soluble in all ethanol fuels and will not harm filters. Lucas Safeguard™ Ethanol Fuel Conditioner with Stabilizers contains effective additives to prevent rust and corrosion associated with the use of ethanol fuels.
Safeguard™ Key Benefits:
• Cleans injectors, valve seats, combustion chambers and other critical fuel components
• Stabilizes fuel and prevents varnish & gum formation in ethanol and gasoline
• Combats deposits and protects your engine oil lubricants from the harmful effects of alcohol combustion
Safeguard™ treats up to 80 gallons(302.8) of ethanol fuel. One ounce treats five gallons of ethanol fuel. Our new 5.25 oz bottle treats up to 25 gallons (94.6 liters) of ethanol fuel. Recommended for use in automobile and marine applications.
NOT RECOMMENDED FOR DIESEL APPLICATIONS
Bump, surely someone must have tried this by now? I won't have access to any non-ethanol fuel anywhere in the city of Atlanta or close by. I need a temporary solution when I get my BRZ next week until a TSB is released.
http://www.lucasoil.com/products/dis...tid=8&loc=show
AutoZone carries it...
Old 07-23-2012, 03:48 PM   #27
TennisHsu
TennisHsu's Avatar
Drives: 2013 Whiteout MT Scion FR-S
Just topped off with 92 ethanol-free gas, hoping to have the same success as OP. Will report back shortly.
TennisHsu is offline   Reply With Quote
Old 07-23-2012, 04:06 PM   #28
wbradley
Sarcastic SOB
wbradley's Avatar
From what I am reading, VPower in the US is NOT necessarily ethanol-free.
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
DIY-Changing Clock/HVAC LEDs on FR-S Lil Abner DIY (Do-It-Yourself) Guides 113 03-11-2022 01:40 PM
Changing the Horn? mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 21 10-27-2016 12:27 AM
Changing Premium to Limited? zygrene BRZ First-Gen (2012+) — General Topics 32 10-09-2012 11:58 AM
I'm changing my order from World Rally Blue to Lightning Red Subie BRZ First-Gen (2012+) — General Topics 26 06-12-2012 12:59 PM
