Old 11-22-2017, 10:24 AM   #15
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Originally Posted by brzzy View Post
However it sounds like a deli machine being sharpened going down the road.
Does is sound like this?
Forgive my exhaust, if you listen carefully you'll hear the heatshield rattle.
[ame="https://www.youtube.com/watch?v=g7C5jONDjgo"]https://www.youtube.com/watch?v=g7C5jONDjgo[/ame]
DaBoBo21 is offline   Reply With Quote
Old 11-22-2017, 10:28 AM   #16
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Hmmm. I hear it but not quite. Yours sounds like there’s metal grit being tossed around or something.
Check it my video post #7 on the first page. Sounds like a lathe.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
The Following User Says Thank You to brzzy For This Useful Post:
DaBoBo21 (11-22-2017)
Old 11-22-2017, 10:28 AM   #17
If it is the TOB you shouldn't really hear much when it is engaged. The noise is much worse at idle and should come and go (or at least change sounds) when pushing the pedal.
In the list of mods you say "etc". Are any exhaust related?
Old 11-22-2017, 10:49 AM   #18
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Doesn't sound anything like any TOB sound I've ever heard.
When my TOB went it was more the squealing and the "water through a copper pipe" type sound that I experienced. Nothing even remotely similar to this.
This to me sounds like something metallic vibrating against something else metallic, so I'm gonna jump on the heat shield bandwagon as well.
Good luck!
@bpennerz
SLVRSRFR is offline   Reply With Quote
The Following User Says Thank You to SLVRSRFR For This Useful Post:
brzzy (11-22-2017)
Old 11-22-2017, 10:50 AM   #19
brzzy
@anthonysestito
brzzy's Avatar
Only HFC front pipe and 3” Greddy catback
IG: @ANTHONYSESTITO
Old 11-22-2017, 10:58 AM   #20
Won't let me quote you.
OK so the front pipe was changed. I would start my search with the heat shield on the far left of the picture. The one over the cat.
DaBoBo21 (11-23-2017), Ultramaroon (11-22-2017)
Old 11-22-2017, 11:04 AM   #21
brzzy
@anthonysestito
brzzy's Avatar
Hmmm. Going to look tonight. Front pipe has been on there for 1.5 years. But very possible.
IG: @ANTHONYSESTITO
Old 11-22-2017, 06:37 PM   #22
Ultramaroon
not playing cards
Ultramaroon's Avatar
Try the test that I suggested. Pulling the fork forward completely disengages the TOB. You may need to pump the clutch pedal a couple times to send fluid back to the slave cylinder.
Your deli machine comment has me triple-guessing. Does the sound change when you tap the clutch pedal?
Old 11-22-2017, 06:48 PM   #23
brzzy
@anthonysestito
brzzy's Avatar
UPDATE:
Just drove home, did a rather thorough inspection. No noise whatsoever ever.
Clutch in/out. Nothing.
Pulleys, slight hissing. Normal.
Exhaust components, nothing visibly rubbing.
If it WAS the TOB it would be persistent no?
IG: @ANTHONYSESTITO
Old 11-22-2017, 08:06 PM   #24
Ultramaroon
not playing cards
Yes, TOB failure ends badly 100% of the time. It can be a long road but it doesn't get better.
Meh. Give it time. It'll come back.
Old 11-22-2017, 08:55 PM   #25
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I heard my tob going out at 40k lasted well into 80k but like said before when it goes out it goes out bad. So who knows? Video scoop it. At lest to make sure, well visually anyway.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 11-23-2017, 12:05 AM   #26
brzzy
@anthonysestito
brzzy's Avatar
UPDATE:
Noise came back, clutch modulation does nothing. Noise changes based on RPM and can be modulated in that way. From my past Audio experience this tells me something is rubbing/rattling.
I’ll bet $10 it’s a nut/bolt on the skid plate and I have just wasted all of your time.
IG: @ANTHONYSESTITO
Old 11-23-2017, 01:08 AM   #27
Ultramaroon
not playing cards
UPDATE:
Oh, well. It's common, especially when the not-a-skid plate starts coming loose. It's a new sound for me so I'm curious to hear what it turns out to be.
Would've just wasted my time here anyhow.
Old 11-23-2017, 08:45 AM   #28
BRZnut
Drives: BRZ DGM Limited
No waste of time. Its thanksgiving...eat, watch TV, check this forum, eat more, check forum again. Repeat.
Let us know if you ever figure it out for sure.
And Happy Thanksgiving everyone. Thanks for the years of interesting reading!
The Following 2 Users Say Thank You to BRZnut For This Useful Post:
brzzy (11-23-2017), Ultramaroon (11-23-2017)
metal on metal sound when releasing the clutch MyNave Engine, Exhaust, Transmission 7 04-18-2018 01:00 AM
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 11:09 AM
Metal vibration sound when in drive before pressing accelerator theparagon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 08-31-2017 12:05 PM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 05:37 AM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 10:11 PM
