Old 11-21-2017, 11:12 AM   #1
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Metal scraping sound at idle
Anyone ever experience this sort of issue or can lead me in the right direction as to what I’m hearing? Sounds like a metal scraping sound.
Car is 2013 BRZ with 60,XXXKm on it. Stock clutch and components. Only bolt ons including intake, oil cooler, OCC, etc.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 11-21-2017, 11:13 AM   #2
brzzy
@anthonysestito
brzzy's Avatar
Video won’t upload, will upload shortly**
IG: @ANTHONYSESTITO
Old 11-21-2017, 03:04 PM   #3
ls1ac
ls1ac's Avatar
If it is while you are moving slowly you notice the sound.
check your brake pads, there is a squeeeeler on some to let you know they are done.
Old 11-21-2017, 03:08 PM   #4
brzzy
@anthonysestito
brzzy's Avatar
Nope. Just did my pads 2 months ago.
I took a video of the noise, tapatalk wont let upload for some reason.
But I hear it at idle while parked. And it even kind of whines on throttle. Hard to tell if modulating the clutch is changing anything because my exhaust is so loud. But I’m beginning to believe it’s the TOB.
IG: @ANTHONYSESTITO
Old 11-21-2017, 03:23 PM   #5
ls1ac
ls1ac's Avatar
ok, clutch in vs clutch out will change TOB noise, bad idler pulley? stop and open the hood, front or back of engine?
Old 11-21-2017, 03:46 PM   #6
rekt ☑ not rekt ☐
Old 11-21-2017, 03:55 PM   #7
brzzy
@anthonysestito
brzzy's Avatar
Heres the video:
Car is parked, no one is modulating throttle its just cycling RPM.
IG: @ANTHONYSESTITO
Old 11-21-2017, 03:56 PM   #8
TOB gets my vote.
brzzy (11-21-2017)
Old 11-21-2017, 09:31 PM   #9
hmmm....... could be a bad TOB.
Could be a pulley going bad or the AC clutch.
I'd suggest check the pulleys by placing a rod next to the pulley and your ear at the other end to see if you can isolate the sound.
Old 11-21-2017, 10:10 PM   #10
It's an odd one for sure. I'm skeptical about the TOB but I've been wrong.
Test it by pulling the clutch fork forward by hand just a little while it's making the sound. Wear gloves for comfort in case it's hot but don't worry. It won't be any worse than McDonalds coffee.
Old 11-21-2017, 11:57 PM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Another vote for the Throw out bearing.
Sounds like mine right before it died.
If you have a buddy with a video scoop you could peek in side and confirm. An old machinist buddy of mine just told me about that trick. Of course after the fact I told him about my throw out bearing ordeal.
The Following User Says Thank You to Mr.ac For This Useful Post:
brzzy (11-22-2017)
Old 11-22-2017, 07:09 AM   #12
BRZnut
Drives: BRZ DGM Limited
Heat shield rattle?
The Following 2 Users Say Thank You to BRZnut For This Useful Post:
DaBoBo21 (11-22-2017), Tcoat (11-22-2017)
Old 11-22-2017, 08:39 AM   #13
Yep. Now that I hear it I am retracting my vote for TOB. I don't have a bloody clue what that one is. If forced to make a call I now change to heat shield.
Old 11-22-2017, 09:21 AM   #14
brzzy
@anthonysestito
brzzy's Avatar
Hmm. I’m going to have a look at everyone’s suggestions after work. Thank you all for the help.
Hopefully it is just a head shield or even a pulley. Clutch Components + downtime just aren’t in the budget right now. However it sounds like a deli machine being sharpened going down the road. Which leads me to believe it has something to do with clutch components. It’s the only metal on metal thing I can think of that could possibly make a sound like that from that region of where I’m hearing it.
We shall see! Snow tires go on tomorrow so I may have the mechanic just take a quick peek.
Thank god Black Friday is this week. Lol
IG: @ANTHONYSESTITO
metal on metal sound when releasing the clutch MyNave Engine, Exhaust, Transmission 7 04-18-2018 12:00 AM
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 10:09 AM
Metal vibration sound when in drive before pressing accelerator theparagon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 08-31-2017 11:05 AM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 04:37 AM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 09:11 PM
