Old 11-20-2017, 04:17 PM   #15
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
REALLY! So, squeezing the oil out of that sand up in Canada, is just cleaning up the environment ......
After all, mother nature NEVER got sloppy ....... cepten at places like the la brea tar pits ........
humfrz
EXACTLY! We are taking all that dirty dirty oil out of the ground, so it's cleaner.
Makes sense to me!
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
humfrz (11-20-2017)
Old 11-20-2017, 04:34 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
[ame="https://www.youtube.com/watch?v=6x_Eijnn1Ak"]Simpsons - Koyaanisqatsi Spoof - YouTube[/ame]
TofuJoe (12-02-2017)
Old 11-20-2017, 08:06 PM   #17
exE36M3
Ha! Yep, getting a similar leak. If it's under the intake runners toward the back of the motor, I got bad news for you. It's NOT the timing cover. Signs are looking at the head gasket BUT I am confirming with Racer's Line in Concord, CA Tuesday AM. Stay tuned!
exE36M3 is offline   Reply With Quote
The Following 3 Users Say Thank You to exE36M3 For This Useful Post:
Clipdat (11-20-2017), snk828 (11-21-2017), tintumz22 (11-21-2017)
Old 11-21-2017, 04:35 AM   #18
snk828
snk828's Avatar
Drives: raven FRS
Nice ,keep me update from your issue , thanks .My leak is under the intake go around the front at driver side between timing chain seal. I will take my car for 60K service soon. Let see what the dealer gonna say about that.
snk828 is offline   Reply With Quote
The Following User Says Thank You to snk828 For This Useful Post:
exE36M3 (11-22-2017)
Old 11-22-2017, 04:34 AM   #19
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
I had an oil leak behind the cam that Subaru techs had to fix on my Brz before . I took it in for a leak because I noticed oil in the same area as you . Techs then said it was the cam position sensor and then I got the car back with no leak about a month later from Subaru dealer ship . They warrantied it for me and the car even had the Jackson racing super charger on it . I just had to pay for them to remove and install the super charger as the parts and labor were under warranty .
mswbrz is offline   Reply With Quote
The Following User Says Thank You to mswbrz For This Useful Post:
snk828 (11-22-2017)
Old 11-22-2017, 07:04 PM   #20
exE36M3
Originally Posted by snk828 View Post
Oil build up/ or leak under intake ? Is this normal for N/A set up? Need a catch can?
Leak by Louis li, on Flickr
So following up... my leak is different.
After taking it to an independent Subaru Shop - the 2 sources for my leak are the head gasket or the injector. Mine appears to be spray leaking under pressure.
I'm not versed enough with the FA20 motor to know all the oil leak spots.
Given where yours is on the motor. It's hard to fathom a timing cover leak on top of the motor as I don't *think* the timing cover has that much oil pressure... Enough to push oil upward anyway.
The Following User Says Thank You to exE36M3 For This Useful Post:
snk828 (11-22-2017)
Old 12-02-2017, 04:14 AM   #21
snk828
snk828's Avatar
Drives: raven FRS
update: first dealer visit , dealer can't confirm where's the leak come from,so they clean it up as much they could and let me drive the car for a week to see does it happen again. The leak comes back two days after normal driving, I would take it back to dealer for second visit tomorrow.
exE36M3 (12-02-2017)
Old 12-02-2017, 12:25 PM   #22
exE36M3
Isn't this fun? I've been about 3 times and 3 weeks for this case. I have to wait until after January to bring it back in (as I am in/out over the holidays) and IF they find something with the car, it's at least a week turnaround.
Good luck with your case. Here's to hoping for easy fixes right?
snk828 (12-03-2017)
Old 12-03-2017, 03:13 AM   #23
humfrz
Oh, I'm thinken you young-ens are spoilt.
As long as it's not leaking more that a quart of oil a week ....... just drive it....
humfrz
exE36M3 (12-03-2017)
Old 12-03-2017, 03:58 AM   #24
snk828
snk828's Avatar
Drives: raven FRS
I bring my car in today, service adviser told me they will do timing chain cover seal repair for me, but I think that will not fix my issue. Service adviser doesn't let me talk to the mechanic about my concern and he insisted I should listen to him, because they have done a lots of those timing chain cover repair. I hope the mechanic will try to find out what's the issue for oil leak between two block after taking the timing chain cover off, I think it should be something leak from the PCV channel inside the block. picture below.
Old 12-03-2017, 01:19 PM   #25
exE36M3
humfrz
Well it looks like I like a 1/2 quart this month. :P
humfrz (12-03-2017)
Old 12-03-2017, 03:49 PM   #26
humfrz
Oh, that ain't all bad ........ you got a ways to leak before a fix is in order ......
humfrz
Old 03-22-2018, 11:35 PM   #27
DieselxIndustry
Drives: 2013 Firestorm FR-S
Did you ever solve where he oil under your intake was coming from?
DieselxIndustry is offline   Reply With Quote
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 05:28 PM
Intake manifold leak Diz86x Engine, Exhaust, Transmission 5 07-13-2017 01:42 PM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 08:08 PM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 02:31 AM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 11:31 PM
