Old 11-27-2018, 10:58 AM   #15
ermax
ermax's Avatar
Originally Posted by MoonieGT View Post
My biggest issue with the seat is the seat bottom. It feels too firm for me. For reference I am 6 feet tall, 170 lbs, 32 inch waist. I get pressure on boniest part of my rump. If the front of the seat could be raised that might support more of my thigh to take some pressure off of the part that hurts.
I've been wanting to the cover off the seat, remove some of the bottom cushion and replace it with some other kind of foam. Not sure what to replace it with. Maybe an inch or so of memory foam?
The work doesn't seem too involved to do it, but I don't want to ruin my seat cushion if it doesn't work out...
My previous car was a Lexus IS with the F-Sport seats... Would love to have those in my car...
I would like a little lumbar and may do this mod but my biggest complaint is the same as yours which is the seat bottom and I have similar specs as you, 165lbs 6'2".
Old 11-28-2018, 02:02 PM   #16
atomicalex
Drives: 2018 BRZ Limited Perf Pack
Ooh great idea. I have been toying with pulling my seat apart, too. Need more lumbar. I have a little butt.
I added extra lumbar on my old Rabbit Convertible, it was soooooo awesome.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Old 11-28-2018, 02:03 PM   #17
MoonieGT
MoonieGT's Avatar
Drives: '17 BRZ
I would love to know if Lexus IS F-sport seats would fit without much modification and without raising the seating position a ton...
'17 BRZ
MoonieGT is offline   Reply With Quote
The Following User Says Thank You to MoonieGT For This Useful Post:
gravitylover (01-18-2020)
Old 11-08-2019, 06:42 PM   #18
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
DIY - Make your seats comfortable
I did this but installed this corbeau inflatable suport. It worked brilliantly!
Tweaking the shoulder supports makes a big difference too.
https://www.google.com/shopping/prod...:1,prmr:3,cs:1
Old 01-17-2020, 10:54 AM   #19
hestekinj
Drives: 2014 BRZ - WRB
Just out of curiosity, how did you go about attaching the lumbar 'bladder' to the inside of the seat? Do you have any photos of the process?
I'm currently using the STI lumbar pillow, but i would really like something more adjustable and permanent. Plus I have long legs and I don't like how far the pillow scoots me forward in the seat.
Thanks!
hestekinj is offline   Reply With Quote
Old 01-18-2020, 07:11 PM   #20
gshopper
Drives: 2003 330i, 2019 BRZ (blue, with PP)
Here's what I did:
I took the back of the seat apart, like the original post, then I used two pressure bags. These are used in hospitals, to pressurize IV fluids for faster administration. I got them on Ebay
https://www.ebay.com/itm/5-pack-of-5...kAAOSwBahVMTzW
There is a pressure indicator which I removed. A little cutting and reattaching. zipties around the connections to make them airtight.
Where Mausr placed a lumbar pillow, I put them in the same place, running horizontally, one above the other. Took picture but can't get it the right size for upload. sorry.
The stopcock and pump bulb tuck away nicely behind the seat and don't get in the way. You can adjust each bladder individually to your preference.
I can adjust it very easily, and it's very comfortable.
gshopper is offline   Reply With Quote
Old 01-20-2020, 08:15 AM   #21
hestekinj
Originally Posted by gshopper View Post
Here's what I did:
That's awesome, thank you!
Is the pressure of the cushion enough to hold them in place, or did you have to affix them somehow to prevent them from moving around?
thanks again!
Old 02-14-2020, 09:19 PM   #22
gshopper
after you inflate them, they just stay by themselves.
Old 03-08-2020, 08:41 AM   #23
MarylinPurtill
Drives: Toyota GT86
I always have sitting issue and feel uncomfortable. On the advice of the dealer, I changed its foam and used ortho-friendly one. Anyways, thanks for this guide.
MarylinPurtill is offline   Reply With Quote
Old 05-29-2020, 12:27 PM   #24
Yoshoobaroo
TRACKBREAD
Thanks!
I pretty much followed this DIY from a BMW forum:
https://f30.bimmerpost.com/forums/sh...0&postcount=14
I made the plastic backer panel out of an old storage bin lid, drilled some holes in it and secured it to the metal wire seat structure with zip ties.
Old 05-29-2020, 12:32 PM   #25
Yoshoobaroo
TRACKBREAD
@hestekinj here's a better link:
https://f30.bimmerpost.com/forums/sh...fitting+lumbar
Old 04-15-2025, 01:36 PM   #26
Compelica
Compelica's Avatar
Drives: 86 GT
Thread necro, but thank you OP for this. For the longest time I had back pains after long distance driving, but was alleviated with an IKEA BORTBERG lumbar pillow. Despite the pillow nicely fitting onto the inner width of the stock seats it tended to shift around which I didn't like.
So I finally got one of those lumbar inflatables, followed the instructions and now life on the road will be much better.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 05-21-2025, 05:11 PM   #27
RickyBobby
Drives: 2013 Firestorm FR-S AT
The problem with the seats in the FR-S is there is only ~12" between the side bolsters. It's hard to find a lumbar pillow that small. The Ikea one should work since it's 12.2" wide, but it's only available by delivery in the US, and the delivery charge is $15. https://www.ikea.com/sg/en/p/bortber...lack-10447972/
My medicare advantage plan, yes I'm an old fart, gives us $90./quarter for OTC stuff. I ordered this one for free. It's 15" wide, too wide for the seat but works great on my computer chair. https://www.amazon.com/ComfiLife-Lum...08HPLZYS9?th=1
I found a black throw pillow for $9. instore at Walmart. It's ~13"-14" wide and tucks into the space between the bolsters. No straps but once you get it postioned right it does not move. Another con is that it has polyester fill, not memory foam.
I may also try this one. It's 12.6" wide and has 2 elastic straps and buckles that pass the buckle through the gap between the seat and the back. https://www.amazon.com/TISHIJIE-Memo...28&sr=8-5&th=1
Too wide for the seat. Straps are adjusted tight and may rip from the fabric over time.
Top does not sit flat against the seat even with straps adjusted tight.
Pillow fits between the bolsters but no straps to keep it in place.
After using the pillow for awhile it wasn't working. It moved when I got in, was hard to adjust, and too thick. I'm 5'11" and with the seat all the way back I was too cramped. Next up was the Amazon lumbar pillow.
The pilllow fit between the bolsters, the plastic buckles tucked securely into the seat fold and keep it secure. It's memory foam and not that thick but gives you enough support.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
blsfrs (05-31-2025)
Old 05-31-2025, 11:55 AM   #28
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
My 2 cents as a PT: In most cases, a lumbar support should fit between your rib cage and pelvis. I've looked a the seats in client's cars and haven't found any that I think have proper positioning. I generally recommend a folded bath or beach towel. Pillows tend to compress too much.
lumbar support, seats
How much experience did it take for you to become comfortable with car control? hpde_addict Tracking / Autocross / HPDE / Drifting 17 04-13-2017 11:26 PM
most comfortable shock with Eibach Pro Kit Crashhollywood12 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-15-2016 01:01 PM
Which is the most comfortable coilover on brz/frs?? HowL Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 04-27-2015 09:02 AM
Stock Suspension comfortable? dannythetran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-10-2015 08:17 AM
Lowering the car and a comfortable ride etherealfall Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 12-21-2014 04:03 AM
