#15 |
Drives: 2014 GT86
Ultramaroon: my goals were similar. I tried camberbolts + camberplates .. it mostly worked ok, with exception of some road uneventies resulting in very loud metallic "hit" sounds, that i was too uncomfortable to drive with daily. Whiteline's Com-C eccentric topmounts should have been answer, but they failed to make one non binding if used on twins, thus ours were de-listed as being compatible. So i was between choice of max -2.2 camber with cambolts, or enough camber but unacceptable NVH result with camberplates on local crappy roads, or i too at one point considered slotting struts. Only recently i found out on my own via googling those PF bushings, somehow never saw them mentioned here before (Maybe because PF to be UK based, and most of their bushings offering is covered by better known Whiteline's/SPC alternatives? But in this case Whiteline has only stiffer rear bushing alternative for front LCA, not eccentric one (eccentric is front one, for extra caster). Maybe because they initially considered using Com-Cs?).
That did it for me, -3 front with stock suspension at stock height while keeping rubber top mounts. Now i don't have to steer around or drop speed at places where i had to suffer NVH problems but just daily drive normally, and also wear & grip on track should be much better. As max with lowering springs with just cambolts (in both holes though) was reported as -2.5 (vs -2.2 to -2.3 stock height), i expect a bit more if both cambolts, this bushing + lowering too. Last edited by churchx; 11-18-2017 at 03:58 PM. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Teseo (11-18-2017), Ultramaroon (11-18-2017) |
#16 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I got -2.5 from bolts only. I have slotted struts now and feel I could get -3 with OEM tophats. Wont know until next year when i get another track aligntment though
| The Following User Says Thank You to finch1750 For This Useful Post: | Ultramaroon (11-18-2017) |
#17 | |
Drives: 2017 BRZ
There's no question for me - camber plates are the only option, because I don't want to try to fight with camber bolts at home. I may also prefer the extra road feel sometimes... though there are times I wish it were a little more comfy.
| The Following 2 Users Say Thank You to cjd For This Useful Post: | strat61caster (11-18-2017), Ultramaroon (11-18-2017) |
#18 | |
not playing cards
Long term I see maybe playing with tire compounds but I'm taking my time getting to know the machine as it ages... um, breaks in.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | strat61caster (11-18-2017) |
| FS: HVT Non-raising camber plates & WL camber bolts | trippinbillies40 | Brakes, Suspension, Chassis | 1 | 05-16-2015 09:00 PM |
| Steering clunk over rough roads | 73TORANA! | Issues | Warranty | Recalls / TSB | 39 | 12-05-2014 07:52 PM |
| Borla UEL rattles over rough roads? | SloS14 | Engine, Exhaust, Transmission | 7 | 10-05-2013 01:03 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
| Camber Plates | delusional | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 10-30-2012 08:17 PM |
