Old 09-14-2017, 09:37 PM   #15
alan.chalkley
Drives: 4wd zooks
Is the engine cranking over slowly when starting?
It could be low charge on the car battery , especially if the car is only driven on weekends or used for short distance commutes/shopping.
alan.chalkley is offline   Reply With Quote
Old 09-14-2017, 10:49 PM   #16
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Oh. 2013. Lol. Well that just reinforces my position.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-14-2017, 11:54 PM   #17
qqzj
Drives: MDX, Camry
The car drives fine. My commute is 32 miles one way. I am sure it is charged very well.
qqzj is offline   Reply With Quote
Old 09-15-2017, 12:02 AM   #18
Stang70Fastback
A.K.A. Starlord
Other than the key fob issues, I had no sign of a dying car battery until it suddenly pooped out at a dealer visit. Just FYI.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Tcoat (09-20-2017)
Old 09-19-2017, 08:06 PM   #19
qqzj
Drives: MDX, Camry
Unfortunately, you might be correct! Today my Energizer battery came and I replaced the old Panasonic battery with it. However, things did not change for the better. No apparent change at all.
I last drove the car for 60 miles on last Thursday. So the car has been sitting for 5 days. Maybe a new car battery is due soon. How sad! Since I routinely get about 7 years' service out of my batteries (Acura OEM and Bosch), I did not expect this to be the cause initially. But my OEM Toyota did die twice around 3 years. So maybe Toyota and Subaru uses lesser batteries than Honda/Acura?
How long did it take for your battery to die after the symptom first started? Thanks a lot.
Old 09-19-2017, 09:34 PM   #20
humfrz
You may consider taking your car in to a shop and have the battery "load tested". If it doesn't score well ...... it's time for a new battery......
humfrz
Old 09-19-2017, 09:56 PM   #21
Stang70Fastback
A.K.A. Starlord
I honestly can't remember. It was at least a few weeks - maybe even a few months.
Old 09-21-2017, 06:46 PM   #22
funwheeldrive
It was weird to find this thread today because my keyfob just died too. At first it was slow to unlock my car. And then I couldn't open the trunk with the push-button.
Even though you have never used it the battery in it is 4 years old as well. They don't have an infinite shelf life.
The small black one is the valet key. It won't open the trunk.
I am almost positive that I have used my valet key to open the trunk. I can't remember why, but it was a PITA.
Originally Posted by ajcarson11 View Post
Yep -- Your fob battery is almost dead. If you have to sit there waiting for it to detect your hand for more than a second or two it is the battery. I couldn't believe it either until I replaced my batteries (buy from amazon) -- good as new.
I'm being super lazy since this thread is already alive and kicking. Does anyone have a recommendation for replacement keyfob batteries? Any brands that work better than others with these things?
Old 09-21-2017, 06:59 PM   #23
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I like to use one fob for 6 months then I swap and use the other. I may be wrong but I thought your fob battery gets recharged when in the ignition and driving around.
Side question what's the battery spec for the key fob?
DandoX is offline   Reply With Quote
Old 09-21-2017, 07:06 PM   #24
qqzj
Drives: MDX, Camry
CR1632
The Following User Says Thank You to qqzj For This Useful Post:
DandoX (09-21-2017)
Old 09-21-2017, 08:25 PM   #25
It shouldn't since that is the whole reason it exists. Can't have nosey valets poking around in the trunk and finding the bodies... I mean valuables.
No the battery does not get recharged.
DandoX (09-21-2017)
Old 09-22-2017, 12:24 AM   #26
funwheeldrive
[/QUOTE]
If you don't want the valet to open the trunk then you hit a button inside the trunk to prevent the trunk from opening with the key fob. You give the valet the key fob and keep the small key for yourself. The valet wouldn't be able to start the car with the small key part.
Maybe that's what you meant though and I just misunderstood your original post.
Edit- you're probably talking about cars without push start right? Mine has push start so I've never seen the valet key for a FRS before.
Old 09-22-2017, 12:58 AM   #27
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
My keyless entry used to work fine but recently i can seem to lock/unlock the car when i'm more than 10 feet away. I've replaced the batteries in the fob but it hasn't solved the issue. Any ideas?
shaynek is offline   Reply With Quote
Old 09-28-2017, 05:09 PM   #28
qqzj
Drives: MDX, Camry
Final update: after changing the battery of the key fob, it did not have any apparent effect at the first. BUT, after the 1st day, it started to work really well again. After 10 days' experience, I am pretty confident that changing battery solved the issue. So it is not due to a defective car battery IN THIS CASE. If my car battery dies in the next 6 months, I shall report back. Otherwise, consider the mystery is solved. Thanks for the help!
The Following 3 Users Say Thank You to qqzj For This Useful Post:
funwheeldrive (09-29-2017), shiumai (09-29-2017), Tcoat (09-28-2017)
Keyless Entry not working! Frs x3 Scion FR-S / Toyota 86 GT86 General Forum 16 10-20-2015 05:10 PM
keyless entry not working ninjasaurusrex Scion FR-S / Toyota 86 GT86 General Forum 0 06-06-2014 10:08 AM
Keyless Entry Upgrade Tr1huynh Electronics | Audio | NAV | Infotainment 3 02-24-2014 09:07 PM
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 11:04 PM
BRZ Keyless entry? Motopythons CANADA 7 06-03-2012 06:56 PM
