Old 09-13-2017, 12:59 PM   #15
humfrz
Originally Posted by JazzleSAURUS View Post
Do you know if that's vacuum or RPM based?
Calculated engine load v. user demand.
but, I would guess vacuum based.
humfrz
Old 09-13-2017, 01:18 PM   #16
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
It seems to me the A/C cuts out at particular throttle settings regardless of actual load (of course I could be wrong here).
I haven't monitored the actual throttle percentage at where this seems to occur (data is available on OBD Fusion when connected to the A Network through a Carista reader) but I would guess it's around 85-90% of throttle travel.
The effect on the A/C in those circumstances is like a light switch. Running the system on recirculate does help moderate the effect, but there's not enough Squash air freshener in the world to solve what happens when you run it that way for a long time... even with a fresh cabin filter.
Shinigami301 is offline   Reply With Quote
Old 09-13-2017, 01:20 PM   #17
lol you know California's Central Valley. Not much has changed since you first visited I'd wager.
Oh I think it has changed a lot since Hum was there the first time.
Old 09-13-2017, 01:29 PM   #18
humfrz
Ahhh ....... The Central Valley ......most likely he was cruising on a portion of I-5.
Back-in-the-day, we called that stretch of I-5 the West Side Freeway.
I remember, back when I was roaming the Central Valley, getting on the uncompleted portion of I-5 off of 152 near Los Banos, and roaring down the west side at over 100 mph and jumping off at Lost Hills, just north of where the freeway ended.
How could I go 100 mph..?? There was virtually no traffic, because the freeway ended in the middle of nowhere, so very few people took it. Secondly, it wasn't patrolled, because there was no traffic......
humfrz
Old 09-13-2017, 05:54 PM   #19
Shinigami301
I would regularly run 120-130 in fairly tight "caravans" of slightly fast cars (factory supercharged and tuned MR2 MK1 at that time) on that stretch when I lived in LA and would drive to Sacramento or the bay area. Had to slow way down in places like Stockton but there were plenty of spots where you could drop the go-fast button right to the floor.
Old 09-13-2017, 06:02 PM   #20
lantsalot
Derp
lantsalot's Avatar
Originally Posted by Imrac View Post
Could it be the 110 Degree heat being forced in via high pressure area where the cabin intake is and overwhelming the evaporator?
Try turning on cabin recirculate to shutout air from the outside. Otherwise it's possibly the ECU turning off the AC unit due to load/demand.
Wouldn't think it's JUST the 110 heat...Here in phoenix it hits 110 a few times a year and I've never had the AC go out during normal traffic speeds.
lantsalot is offline   Reply With Quote
Old 09-13-2017, 08:06 PM   #21
pjp
Drives: frs
Central Valley = Big Valley
Lots of fast cruising if you pay attention to the overpass , day light only,
and use WAZE!!!!
Am heading back next week LA to Napa
Will try in Recec mode
All so try 5th and 6th to check throttle position for changes
Thanks For the Help
Paul
pjp is offline   Reply With Quote
Old 09-13-2017, 09:05 PM   #22
steve99
and use WAZE!!!!
Thanks For the Help
Paul
Just guessing but ecu likely controls a\c like it does the alternator . With alternator it will stop charging unler highh acceleration ( may not of battery\volts low) so it likely a\c is controled in similar way.
Now how the ecu does this is unknown ie is it a combination of speed, engine load rpm coolant or oil temps throttle position for a certian time period who knows. But if it consistetly drops out at certian times it lilely the ecu doing its thing but it may not be based on a single parameter more likely based on several conditions being tripped
Old 09-14-2017, 09:51 AM   #23
Icecreamtruk
Drives: Track preped NA FRS
Its normal, AC will cut under full throtle, at any speed. Like it wont shut down, but the compressor wont work until you let off some. Gotta choose between ponies or cool air (you might try not going wot for a few seconds at a time to keep the air cool enough).
Old 09-14-2017, 10:27 AM   #24
Imrac
Drives: 13 SWP BRZ Prem
Sorry, I implied the faster speed causing an even higher than normal high pressure on the cabin intake with the combination of high heat. I wasn't so clear in my reply.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 09-14-2017, 11:10 AM   #25
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Interesting use case. If I usually cruised at 90mph, I think I would of opted for a bigger displacement engine.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-14-2017, 12:38 PM   #26
lantsalot
Derp
lantsalot's Avatar
Ah okay. I definitely didn't catch that xD
Old 09-21-2017, 11:03 AM   #27
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
It's a safety feature designed to reduce compressor freeze/wear issues. The A/C compressor as you know is on a parasitic pulley that can shut off. But it's not designed to operate at high speeds for long durations, and all cars are optimized for the mass market, which typically doesn't cruise over 90.
My car does the same thing, if you want to adjust it I wouldn't be surprised if you can in techstream via OBD II. Freeze shouldn't be an issue when it's 110°, but wear on the compressor will still be higher at high RPM.
DoomsdayJesus is offline   Reply With Quote
Unstable idle when A/C cuts out paulca Engine, Exhaust, Transmission 14 10-24-2015 09:18 PM
Help, Audio cuts off with sub amp install. 2014 FR-S Waukeen Electronics | Audio | NAV | Infotainment 8 07-02-2014 04:29 PM
AC cuts out at high revs. Cool feature? Superhatch BRZ First-Gen (2012+) — General Topics 9 06-28-2012 02:13 PM
Possible Final production cuts. Syldrin Scion FR-S / Toyota 86 GT86 General Forum 46 11-23-2011 09:02 PM
