Old 09-04-2017, 09:52 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by H214M View Post
If I get an oft my self and I tune it stock ? You think it will go away? Or how does that work ? He used ecutek and tactrix cable
That makes no sense. Ecutek is a closed encrypted system requiring a license. I don't think you can use the Tactrix adapter.
It is possible to flash OFT ROMs with Tactrix. It also makes more sense because Tactrix is wide open. It's not at all idiot proof. The user has to double-triple check everything to make sure to use the right definition file and rom for the Calibration ID. I'm even more convinced your buddy fucked up. No offense.
That being said. I'm getting out of my element. @steve99 is active here. Be nice to him and the other experts. You're in for a project.
Old 09-04-2017, 09:54 PM   #16
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I got an OFT tune 93 Octane tune from my friend
How? An OFT is married to one car, I didn't think it'd even let you steal someone else's tune. Flash back to stock, get your own and see if the problem persists.
Old 09-04-2017, 09:55 PM   #17
H214M
Drives: Scion FR-S
Yeah man I think he did fucked up and he said "No, it's just that it will think the tune I put on is the cars stock tune." Meaning the tune he put on it will be the one that gets married to the oft
H214M is offline   Reply With Quote
Old 09-04-2017, 09:56 PM   #18
H214M
Drives: Scion FR-S
Old 09-04-2017, 09:59 PM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
Ultramaroon: IIRC one can also do open tunes with ecutek. Though of course it's not in best interests of tuning shops & in majority of cases they'll choose to encrypt tune.
Old 09-04-2017, 10:00 PM   #20
Ultramaroon
not playing cards
The tablet is but not the ROM files.
Old 09-04-2017, 10:02 PM   #21
Ultramaroon
not playing cards
Yeah, the tunes can be left unlocked at the tuner's discretion but they are still licensed and married to the ECU. Is that what you mean?
edit: I'm pretty sure there's no action between an ECUtek ROM and a Tactrix dongle but, again, I'm admittedly at the edge of my knowledge. I have a Tactrix but I still haven't had the balls to flash with it.
Old 09-04-2017, 10:09 PM   #22
steve99
Those codes are not tune related
Fuel level sensor and air temp sensor.
Guy woukd have used tactrix and ecuflash not ecutek, it requires special cabke and an ecutek licience.
Its possibke those codes tripp due fkash process interrupting can buss communications.
Remove a battery termibal fow a few minutes to reset ecu and control modules in car.
See if codes return, if so check above circuits fuses and diagnose and replace as necessary
Old 09-04-2017, 10:12 PM   #23
H214M
Drives: Scion FR-S
Old 09-04-2017, 10:12 PM   #24
H214M
Drives: Scion FR-S
This is what he told me
Old 09-05-2017, 03:28 AM   #25
steve99
Correct tactrix\ecuflash does not lock ecu. You could buy oft and flash over the current tune but it wont solve your issue if its a hardware problem with sensors
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 09:00 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
