| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
I think therefore.....
Drives: Toyota 86 860 Halo White (Manual)
In general I am storing a vehicle only for the winter and will use it as my daily driver in the spring/summer/autumn. There will also be weekends in the winter where I will take the vehicle for a drive. Inflating the tire ensures I do not get flat spots however modern tires are less prone to this issue. The fact that I am using the vehicle and therefore the tires for most of the year means I will run out of tread long before improper storage and tire aging becomes and issue. Supporting the hubs is reasonable but only necessary if you are removing the wheels. The natural setup of the suspension with the wheels on mean you are minimizing the stress on the springs, shockers and steering components. (The car is designed that way). So in Short: Long term storage is for very low mileage vehicles where the tires are expected to last in excess of five years , (at least) that would never happen with my tires.
May the N.A. force be with you.
#16 |
btr.life
Drives: 2022 GR86
What is considered "long term" storage? My e36 BMW sits for weeks at a time between track events, sometimes a month or two. I just leave it under a car cover on the side of the house...probably not the best storage approach but I have not had any issues in the 2 years I have been doing that.
I keep waiting for it to not start one of these times so I can have an excuse to put a V8 in it...but it just keeps on going (205k+ miles).
#17 | |
Be careful of old, low mileage tires. While they may have lots of tread, depending on how old they are the rubber may have hardened. Not a big deal if you are just cruising around the block, but if you have to make a hard stop or take a corner fast you might unexpectedly find you have significantly less traction. |
| The Following User Says Thank You to jvincent For This Useful Post: | Overdrive (09-22-2017) |
#18 |
Drives: '13 FR-S
My buddy has a quick-jack like this that we've used on a number of cars, our 86's included. They're really great. Sure, it'd be nice if they went a BIT higher, but all things considered this is a great option for a home garage. They are still hundreds less than even the least expensive post-style lift and take a lot less space.
| The Following User Says Thank You to CatDaddysBBQ For This Useful Post: | justinco (09-22-2017) |
#19 | |
Drives: 2015 Raven FRS
#20 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
| The Following 2 Users Say Thank You to BirdTRD For This Useful Post: | justinco (07-07-2018), Ultramaroon (07-07-2018) |
#21 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Thanks for the help Sorry about taking the block with me during the test drive. haha
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
| The Following User Says Thank You to Soloside For This Useful Post: | BirdTRD (07-07-2018) |
#22 |
Famous Potatoes
Drives: '15 ultramarine
Pinch weld blocks are a must with the twin.
| The Following User Says Thank You to Sapphireho For This Useful Post: | BirdTRD (07-07-2018) |
#23 |
Simply Forgotus
#24 |
Drives: none
For those of you with the Quickjack, instead of using the pinch weld blocks by QJ, could any pinch weld pad that rests securely on the stock block work? Thinking either of these two styles: https://www.amazon.com/DEDC-Universa...120729&sr=8-47 https://www.amazon.com/DEDC-Universa...ustomerReviews |
#25 |
Just to add to the mix.
Wheel dollies with rounded pan work well for storing. You can even push the car up next to the wall to get more room in the garage. Also you might consider Danmar MaxJax for just a little more. It is a true two post that will work in most garages. Can not beat a two post for working under a car. We set one up at my sons house with two sets of anchors for different width cars, and can move it out of the way when not in use. He now just leaves it in place and parks normally between the posts. |
#26 | |
Rust bucket enthusiast
I have to agree, 2 post is the ultimate luxury. I wish I could fit one in my garage, I could put my car up for winter storage and still fit the snowblower underneath, rather than having to hope I don't catch my front bumper as I wheel it narrowly by
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#27 |
The posts rises to just under 8 feet. measure from the top of your car to the ceiling, this is as far as you can lift. I had one in a 7 foot low bay for rewiring sports cars.
The only problem is if you have a single door with a chain type opener. Some people move the opener to the side, but others, like me, use a shaft drive on the door. My son even uses his for changing the oil on his wife's mini van, partial lift but better than jack stands |
| The Following User Says Thank You to ls1ac For This Useful Post: | DarkPira7e (12-28-2020) |
#28 |
Drives: none
*thought this was a thread about quickjack*
| FS: (MA) Bendpak QuickJack BL3500 Portable Lift | gutbomb | Mechanical Maintenance and Tools | 9 | 07-25-2021 11:12 PM |
| Bendpak QuickJack BL-5000 | cnk | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 104 | 05-22-2017 06:21 PM |
| Exhaust setup and noise testing? What DB is yours? | Rich196 | Engine, Exhaust, Transmission | 3 | 08-31-2016 06:11 PM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
