#15 | |
Drives: 2013 Subaru BRZ
If you had owned a sporting manual shift European car designed before those idiot blue rinse ladies rammed their cadillacs into the drug store window and blamed the car for getting away from them you'd know that no new car has pedals spaced correctly. All road cars sold in North America since the unintended acceleration debacle have the accelerator pedal positioned too far away from the brake pedal, whether automatic or manual. Very annoying. |
#16 |
Wheels for Brains
I used to have trouble reaching over to the accelerator pedal for heel-toe, especially if I wasn't in heavy braking. It could be done, but I often had to really exaggerate the motion to get a good blip in. The accelerator pedal just felt like it was in too deep most of the time to actuate, even with my foot positioned upward and toward the right of the brake pedal center. I have average feet and I wear pretty close-fitting shoes (size 8.5, Vans Authentic).
I bit the bullet, bought, and installed the Cusco Sports Accelerator Pedal. It was a good compromise in price and didn't require drilling. The changes were subtle (about 1/8" depth, 1/4" length, and 3/8" width) but very effective for me. It's really the extra width that made the difference. Heel-toe feels much more natural and consistent. My friend (who also owns an FR-S) didn't believe me until he tried it for himself. I have only one complaint: since the pedal is a little longer now, I can't slide my foot easily underneath the pedal to stretch or rest while in cruise control. Some recommend against installing a spacer to raise the pedal significantly. When you're in deep braking, the accelerator might be too high for you to comfortably actuate depending on how much you are depressing the brake pedal. Here, preference and comfort are key.
| The Following User Says Thank You to EndlessAzure For This Useful Post: | TofuJoe (10-17-2017) |
#17 | |
Drives: 2014 Whiteout FRS
My opinion is get the pedal extension first then the spacer. I had the pedal extension first and it was great, later I got the spacer and it was too much. Maybe I just got used to the extended pedal but the spacer brought the gas pedal up way too much. Great for heel and toe around town but under hard braking I found myself over revving due to the gas pedal being so high once the brake was pushed hard. |
#18 |
Automotive Enthusiast
Drives: Zenki 86
I think you and your body can adapt to the placement of these pedals. However, have you tried a mix of double clutch and rev matching? I ask because the more I got used to doing double clutch and rev match, heel and toe got much easier to do.. Just my .02 cents
| The Following User Says Thank You to D5teph For This Useful Post: | suppjc (06-18-2021) |
#19 |
Drives: 2014 Scion FR-S Monogram
What would be the reason of double clutching on our cars? Isn't it rendered pointless from having synchronizers, at least as far as my knowledge there is no reason to double clutch a modern transmission.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#20 | |
Drives: Zenki 86
As far as saving the synchros, I was reading that it doesn't hurt to double clutch. But whatevs, I do these for the enjoyment of driving my car lol. I was just giving my .02
#21 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
I just installed the verlox Throttle space kit. Moves the throttle pedal up and close to the brake pedal. It is all adjustable. I really like it. Makes heel toe a lot easier. I would recommend it.
#22 | |
Drives: Zenki 86
Have you ever downshifted and just dropped the clutch? Or slowly release the clutch? There's definitely a difference in momentum...
#23 | |
I was just confused when you said double clutching would help as I didn't think there was any need to do it when normal rev match down shifting or heel and toe downshifting.
#24 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
I wish the pedal spacers were more affordable. I have the Cusco cover and while it is helps a bunch, I would really like the pedal closer to me, along the same plane as the brake pedal. I wonder if there is a cheap DIY solution?
#25 |
Drives: 2014 GT86
There are multiple spacers, eg. Velox, PST and others, that relocate pedal closer to brake pedal and higher to driver. They cost more then pedal covers though and i have to warn that using those AND pedal covers might be too much, as imho summary result is too closely spaced and it's very easy to mispress two pedals together, so one is better using one OR other.
#26 | |
#27 | |
Drives: Neptune GR86
#28 |
Drives: 2013 WRB BRZ 6MT
The only issue with heel-toe downshift in this car is the fact that they set the throttle pedal down so far compared to the brake and that makes it difficult to roll the heel enough to hit the throttle with low brake pedal efforts. Because I've specifically practised it a lot, I can do it fine now but I've come to the conclusion that it's just never worth the effort. If I'm only going to be braking with so little pedal effort in the first place, I'm better off just doing a regular rev-match downshift early and then brake normally a touch later.
| Heel-Toe on track | Howardwei | Tracking / Autocross / HPDE / Drifting | 60 | 08-17-2013 07:31 PM |
| Heel-Toe questions | jwlee7ucla | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 07-31-2013 04:29 PM |
| Heel Toe Around Town? | strat61caster | Scion FR-S / Toyota 86 GT86 General Forum | 154 | 06-12-2013 05:30 PM |
| Heel toe | #87 | Other Vehicles & General Automotive Discussions | 21 | 08-25-2012 05:39 AM |
| Heel and Toe | ichitaka05 | Other Vehicles & General Automotive Discussions | 13 | 04-02-2010 02:28 AM |
