Drives: Facelifted brz
Product for better heel and toe
Hey, i dont know if it's related to this sub- forum but i didnt know where to ask it. For easier heel and toe, I rather buy gas pedal extension like this:
http://www.subispeed.com/billet-alum...5-sti-2013-brz Or spacer like this: http://www.ft86speedfactory.com/velo...-s-brz-86.html Together i think that it will be to radical setup... Thanks a lot! Sent from my HUAWEI VNS-L22 using Tapatalk |
Off Topic
What problems are you having with heel and toe shifting? Would it be more beneficial to bring the gas pedal closer to you or make it wider so it's closer to the brake pedal? And there's no reason you couldn't do both; just make sure to identify the specific issue so you can correct it instead of throwing random parts at it.
Drives: 2005 Toyota Camry
If you can't do heel/toe properly on this car without modifying the pedals, you are doing it wrong.
-alex |
Drives: Subaru BRZ
Drives: 2014 Subaru BRZ Limited 6MT SSM
My two cents: you can definitely heel-toe in the stock configuration but there is a lot of room for improvement in the layout of things. I got the Cusco gas pedal and while it's helped, I still want a pedal base extender like you linked, too bad it's a bit pricey. I personally prefer all three pedals on the same plane or close to it. Another thing that would help is a more sensitive throttle pedal/better throttle response.
Drives: 2014 GT86
Menashe123: My advise would be to get that Velox's spacer. I have one that moves pedal position to somewhat similar extent, but Velox's is cheaper & has some extra adjustment range if needed. With stock gas pedal & pedal i find it perfect for H&T. While ago i also had replacement gas pedal, that was angled, had to remove it, as that + spacer = pedal too close to brakes. While aftermarket pedals fix distance to brake pedal, they do nothing with pedal height (gas pedal on ours is imho a bit too low relative clutch & brake pedals). So from what i tried, spacer did best, and i'd use it w/o aftermarket wider pedals.
Mav1178: i could blip with everything stock. But it was PITA. I find it very reasonable to optimise pedal position for more comfortable use vs one, that was directed by "sticking mats & unintended acceleration lawsuits". People change seats, steering wheel, shifter to ones that make driving better for them .. why not pedals too? |
#8 | |
Drives: 2015 BRZ Limited
I am going to try to adjust throttle a little closer and stiff if that helps. If not, I will be getting one of the wider pedals. |
Drives: frs
I use cusco gas pedal and my problem was solved and its cheap
#10 |
Might be a 2016 or 2017 though. From what I've heard/know (I have a 17 myself) the gas pedal is further down than the brake pedal so it makes heel toeing more difficult than earlier MY's.
#11 |
Drives: Q5 + BRZ + M796
You can adjust the brake pedal height. I moved mine lower. Not to heel toe but because it felt high.
#12 |
#13 |
Custom User Title
Drives: Asphalt FR-S MT
I can just as easily heel-toe in my size 10.5 steel toe work boots as I can in sneakers. And that's in the full range of braking.
#14 | |
Drives: Subaru BRZ
Yeah, I haven't had any problems, I drive in Adidas Beckenbauers All round, Dr Marten shoes and occasionally in Redwing boots (but no twisting of ankles).. when I had my Caterham I had to drive in skinny sneakers Converse types as the footwell is really tight leading to a very close set of pedals. |
| Heel-Toe on track | Howardwei | Tracking / Autocross / HPDE / Drifting | 60 | 08-17-2013 07:31 PM |
| Heel-Toe questions | jwlee7ucla | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 07-31-2013 04:29 PM |
| Heel Toe Around Town? | strat61caster | Scion FR-S / Toyota 86 GT86 General Forum | 154 | 06-12-2013 05:30 PM |
| Heel toe | #87 | Other Vehicles & General Automotive Discussions | 21 | 08-25-2012 05:39 AM |
| Heel and Toe | ichitaka05 | Other Vehicles & General Automotive Discussions | 13 | 04-02-2010 02:28 AM |
