Old 06-10-2017, 09:44 AM   #15
Gforce
Drives: 2013 Subaru BRZ
Originally Posted by mav1178 View Post
If you can't do heel/toe properly on this car without modifying the pedals, you are doing it wrong.
-alex
Well, yes and no. Under heavy braking, which is technically when heel and toe is desirable, the brake pedal is close to where it needs to be for easy heel and toe. However, anything less than that and the brake pedal really is "too high" for a smooth throttle application. In reality the accelerator pedal is just too far away from the brake pedal. The clutch pedal is too high also but that's an unrelated issue and easy to fix.
If you had owned a sporting manual shift European car designed before those idiot blue rinse ladies rammed their cadillacs into the drug store window and blamed the car for getting away from them you'd know that no new car has pedals spaced correctly.
All road cars sold in North America since the unintended acceleration debacle have the accelerator pedal positioned too far away from the brake pedal, whether automatic or manual. Very annoying.
Gforce is offline   Reply With Quote
Old 06-13-2017, 05:47 AM   #16
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I used to have trouble reaching over to the accelerator pedal for heel-toe, especially if I wasn't in heavy braking. It could be done, but I often had to really exaggerate the motion to get a good blip in. The accelerator pedal just felt like it was in too deep most of the time to actuate, even with my foot positioned upward and toward the right of the brake pedal center. I have average feet and I wear pretty close-fitting shoes (size 8.5, Vans Authentic).
I bit the bullet, bought, and installed the Cusco Sports Accelerator Pedal. It was a good compromise in price and didn't require drilling. The changes were subtle (about 1/8" depth, 1/4" length, and 3/8" width) but very effective for me. It's really the extra width that made the difference. Heel-toe feels much more natural and consistent. My friend (who also owns an FR-S) didn't believe me until he tried it for himself. I have only one complaint: since the pedal is a little longer now, I can't slide my foot easily underneath the pedal to stretch or rest while in cruise control.
Some recommend against installing a spacer to raise the pedal significantly. When you're in deep braking, the accelerator might be too high for you to comfortably actuate depending on how much you are depressing the brake pedal. Here, preference and comfort are key.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
TofuJoe (10-17-2017)
Old 06-13-2017, 08:20 AM   #17
Wyattkb
Drives: 2014 Whiteout FRS
Originally Posted by Menashe123 View Post
Hey, i dont know if it's related to this sub- forum but i didnt know where to ask it. For easier heel and toe, I rather buy gas pedal extension like this:
http://www.subispeed.com/billet-alum...5-sti-2013-brz
Or spacer like this:
http://www.ft86speedfactory.com/velo...-s-brz-86.html
Together i think that it will be to radical setup...
Thanks a lot!
Sent from my HUAWEI VNS-L22 using Tapatalk
I had both of those options, although not from those manufacturers they were the same exact thing.
My opinion is get the pedal extension first then the spacer.
I had the pedal extension first and it was great, later I got the spacer and it was too much. Maybe I just got used to the extended pedal but the spacer brought the gas pedal up way too much. Great for heel and toe around town but under hard braking I found myself over revving due to the gas pedal being so high once the brake was pushed hard.
Wyattkb is offline   Reply With Quote
Old 10-16-2017, 04:46 PM   #18
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
I think you and your body can adapt to the placement of these pedals. However, have you tried a mix of double clutch and rev matching? I ask because the more I got used to doing double clutch and rev match, heel and toe got much easier to do.. Just my .02 cents
D5teph is offline   Reply With Quote
The Following User Says Thank You to D5teph For This Useful Post:
suppjc (06-18-2021)
Old 10-16-2017, 05:02 PM   #19
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
What would be the reason of double clutching on our cars? Isn't it rendered pointless from having synchronizers, at least as far as my knowledge there is no reason to double clutch a modern transmission.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 10-16-2017, 05:14 PM   #20
D5teph
D5teph's Avatar
Drives: Zenki 86
I use double clutching or rev match to engine break as a means of slowing down without having to apply the brakes...Only time I would heel and toe is when I need to slow down pretty quickly and efficiently.
As far as saving the synchros, I was reading that it doesn't hurt to double clutch. But whatevs, I do these for the enjoyment of driving my car lol. I was just giving my .02
Old 10-16-2017, 05:21 PM   #21
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
I just installed the verlox Throttle space kit. Moves the throttle pedal up and close to the brake pedal. It is all adjustable. I really like it. Makes heel toe a lot easier. I would recommend it.
Elliotw is offline   Reply With Quote
Old 10-16-2017, 05:26 PM   #22
D5teph
D5teph's Avatar
Drives: Zenki 86
Have you ever downshifted and just dropped the clutch? Or slowly release the clutch? There's definitely a difference in momentum...
Old 10-16-2017, 05:37 PM   #23
Detroiter
Detroiter's Avatar
Yes I know and understand how to downshift. Just have never heard of anyone double clutching to do it. If you rev match precisely enough just dropping the clutch is still as smooth as butter. Obviously that takes a lot of skill to get it exact every time.
I was just confused when you said double clutching would help as I didn't think there was any need to do it when normal rev match down shifting or heel and toe downshifting.
Raven
Old 10-16-2017, 10:29 PM   #24
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I wish the pedal spacers were more affordable. I have the Cusco cover and while it is helps a bunch, I would really like the pedal closer to me, along the same plane as the brake pedal. I wonder if there is a cheap DIY solution?
ApexEight is offline   Reply With Quote
Old 10-17-2017, 02:33 AM   #25
churchx
churchx's Avatar
Drives: 2014 GT86
There are multiple spacers, eg. Velox, PST and others, that relocate pedal closer to brake pedal and higher to driver. They cost more then pedal covers though and i have to warn that using those AND pedal covers might be too much, as imho summary result is too closely spaced and it's very easy to mispress two pedals together, so one is better using one OR other.
Old 10-17-2017, 10:15 AM   #26
Old 10-17-2017, 11:03 AM   #27
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Double clutching is pointless in this car.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
Detroiter (10-17-2017), Tcoat (10-17-2017)
Old 10-17-2017, 12:21 PM   #28
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
The only issue with heel-toe downshift in this car is the fact that they set the throttle pedal down so far compared to the brake and that makes it difficult to roll the heel enough to hit the throttle with low brake pedal efforts. Because I've specifically practised it a lot, I can do it fine now but I've come to the conclusion that it's just never worth the effort. If I'm only going to be braking with so little pedal effort in the first place, I'm better off just doing a regular rev-match downshift early and then brake normally a touch later.
Lynxis is offline   Reply With Quote
Heel-Toe on track Howardwei Tracking / Autocross / HPDE / Drifting 60 08-17-2013 07:31 PM
Heel-Toe questions jwlee7ucla Scion FR-S / Toyota 86 GT86 General Forum 26 07-31-2013 04:29 PM
Heel Toe Around Town? strat61caster Scion FR-S / Toyota 86 GT86 General Forum 154 06-12-2013 05:30 PM
Heel toe #87 Other Vehicles & General Automotive Discussions 21 08-25-2012 05:39 AM
Heel and Toe ichitaka05 Other Vehicles & General Automotive Discussions 13 04-02-2010 02:28 AM
