Old 06-06-2017, 02:04 PM   #15
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Update: Charcoal canister did not fix the problem. Now they are going to drop the gas tank and replace the valve to the tank. Fingers crossed.
Originally Posted by guybo View Post
@5hairpins do you ever top off when you gas up? Has the nozzle ever failed to click off on its own and spilled out? It only takes one time. Even once can cause probs with the evap system and the canister. What you describe is the classic symptoms.
If you are not getting a CEL [yet] then you can either live with the PITA of filling up (it'll get worse) or just fix it. It tends to be expensive although I don't know how it is for this car.
No, I do not top off. I have done so a few times but not the vast majority of the time.
5hairpins is offline   Reply With Quote
Old 06-06-2017, 02:36 PM   #16
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I've had issues sort of like this with certain pumps. I've had to just hold the nozzle in the right spot keeping the trigger down to fill up. In my case I blame the nozzle, other pump nozzles don't have any issues.
DandoX is offline   Reply With Quote
Old 06-06-2017, 07:23 PM   #17
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
My wife's camaro had this problem. the purge valve was the problem, but she got a CEL (no other symptom). The aftermarket warranty (I know that a lot of chevy products have shit evap systems so I made sure it was covered) covered almost the entire $3000+ to fix it.
Old 06-07-2017, 05:30 PM   #18
5hairpins
5hairpins's Avatar
2nd Update:
The valve is built into the tank and cannot be replaced so a new tank and valve will be going on the car. Since the tank is above the drive-train, the rear suspension and axle come out. Ouch, my wallet hurts.
Old 06-15-2017, 11:54 AM   #19
5hairpins
5hairpins's Avatar
3rd update:
Replacement tank went on but issue persists. Tank coming back off to try and figure out the cause. Good times!
Old 06-15-2017, 01:52 PM   #20
humfrz
Heck, at this point I'd be tempted to get a length of garden hose and a funnel to put gas in the tank ......
humfrz
Old 06-29-2017, 11:29 AM   #21
5hairpins
5hairpins's Avatar
humfrz
I think I should have followed your advice. Still waiting on the second tank to be delivered. I really miss my car.
Old 07-07-2017, 06:03 PM   #22
5hairpins
5hairpins's Avatar
4th update: the second tank did not fix the issue so Toyota Engineers have gotten involved. 5 weeks without my car with no solution in sight. I think I have forgotten how to drive a stick at this point.
Old 07-07-2017, 08:45 PM   #23
guybo
Huge E85 fan!
guybo's Avatar
I wonder if it's an ECU issue. If the purge valve never gets the signal to open, it won't. But that is something a tech should have tested before throwing parts at the problem. With a laptop a tech should be able to remotely test the evap valves- and the entire evap system. Something ain't right if they just wasted all that time replacing th tank and not doing the most basic tests.
Old 07-07-2017, 09:26 PM   #24
humfrz
For cryen out loud ....... it's a tank with a filler neck and a cap......how could our brilliant automotive engineers, take such a simple concept and turn it into a nightmare .......
humfrz
Old 07-08-2017, 01:51 AM   #25
Ultramaroon
not playing cards
Ultramaroon's Avatar
This is truly painful to witness.
Old 07-11-2017, 12:47 PM   #26
5hairpins
5hairpins's Avatar
I don't think any ECU testing occurred, at least the local technician never mentioned it. That said, I would hope the Toyota Engineers would have thought to do so.
Old 07-11-2017, 12:55 PM   #27
Anarki101
Drives: Silver 2017 Brz w/ PP
Do these cars have a leak detection pump? My other car had a super hard time with filling when it broke, and I never got a CEL for it either.
Hopefully this gives you a direction to go in.
Anarki101 is offline   Reply With Quote
Old 07-11-2017, 06:44 PM   #28
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
2nd Update:
3rd update:
Oh wow! This really is a good (bad?) example of swapping parts that don't fix the problem!!
Has the dealer or Toyota indicated that this should be covered by a warranty or warranty extension based on this history of ineffectiveness??
Silver Supra is offline   Reply With Quote
Slight hesitation after filling 'er up stranger things Issues | Warranty | Recalls / TSB 5 05-21-2017 08:09 PM
Filling out the low-end buzznasa Electronics | Audio | NAV | Infotainment 20 03-31-2014 01:21 AM
Fuel overflowing when filling... TRBO2NR Scion FR-S / Toyota 86 GT86 General Forum 26 09-13-2013 09:56 PM
Filling holes in front grill? Fast_Freddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-20-2013 11:44 AM
I was planning on just filling out paperwork... Longhorn248 BRZ First-Gen (2012+) — General Topics 34 06-05-2012 07:31 PM
