Old 04-29-2017, 03:21 PM   #15
steve99
Originally Posted by HLHachiRoku View Post
It was a base E85 OFT tune that I have changed a ton on, and will no long run E85, as we have "flex fuel" here now E51~65. So I have made changes the same tune and just keep making changes and saving my different versions, lol. Thanks @steve99
arrh ok then you should be able to use kodes OFT D00C def , but theirs so many version of oft you mat need to look at tune with hex editor search for ZA1J their will be 3 instances if all three not same then the real tune base will be the third one around 11000 hex.
HLHachiRoku (04-29-2017)
Old 04-29-2017, 04:26 PM   #16
HLHachiRoku
Drives: 2015 HL FR-S
@Steve 99 All 3 are the same ZA1J (last is ZZZA1JD00C) extra z's im assuming its fine tho. I don't see on @Kodename47 defs he has a D00C def for OFT. I tried using the C def zip OFT file but none would load my current map. Would I have to change anything inside to match D00C then? I was reading your tactrix post and it states ZA1JD00C for late 2014/2015 cars only. Thanks again!
[||•]=(86)=[•||]
2015 Hot Lava FR-S (Sold)
OFT → My non sensor flexfuel UEL tune
Plus other mods
HLHachiRoku is offline   Reply With Quote
Old 04-29-2017, 04:37 PM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
My defs go as far as ZA1JB01C on the USA MT ones. @steve99 will have to let you know If you can flash a B01C derived ROM on a newer ECU.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-30-2017, 07:48 AM   #18
steve99
Yes you can run a B01C rom in place of a D00C, but if you have oft you will need to do a bit of rom hacking to fool oft
Old 04-30-2017, 03:04 PM   #19
HLHachiRoku
Ok thanks @steve99 & @Kodename47 =D From your list in tactrix I was thinking I could run the B01C but didn't know what I needed to replace, etc as I do have an OFT. I'm trying to get the delay table in there (as the delay seems long in logging). When looking at the code it looks as if it is in there just not showing for some reason in the D00C =\ I could be wrong but don't know what hacking I would need to accomplish in order for it to work correctly an not brick the ecu, as its my daily driver. lol. I wish the OFT would let me just save the B01C onto it =(
[||•]=(86)=[•||]
Plus other mods
Old 04-30-2017, 03:24 PM   #20
steve99
PMed you instructions
DBW TQ requested table?? Grip Ronin Software Tuning 26 09-14-2020 10:22 AM
How to print Romraider table??? ROADRACER Software Tuning 9 03-20-2016 09:19 PM
ROM Table Discovery & Definitions Kodename47 Software Tuning 21 01-28-2016 03:30 PM
AFR table nickw14 Software Tuning 9 04-01-2015 05:14 PM
2014 PAX table Scooby South Tracking / Autocross / HPDE / Drifting 11 11-26-2013 10:35 AM
