Old 04-15-2017, 10:27 PM   #15
humfrz
Originally Posted by treminaor View Post
Is there anything I can do to test this theory before I rip out the console?
Not that I know of.
Maybe ol @Ultramaroon has a recent flash .......??
humfrz
Old 04-15-2017, 11:44 PM   #16
Ultramaroon
not playing cards
Ultramaroon's Avatar
It almost sounds like the tick of an exhaust shield or similar. That you notice it mostly in first makes sense. That's where the driveline twists the most.
I would put it up on stands and while lying underneath it, jiggle the front pipe. It might lead to more inspection but...
Worth a shot.
Old 04-16-2017, 12:28 AM   #17
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Worth a shot.
I'll give it a try. The noise doesn't seem to happen going over bumps or potholes so I ruled out anything with suspension.
As far as mostly noticing it more often in first it could also be that in higher gears the RPM is so high I don't hear it over the noise.
treminaor is offline   Reply With Quote
Old 04-16-2017, 12:29 AM   #18
Ultramaroon
not playing cards
I'm stumped.
Old 04-16-2017, 12:30 AM   #19
treminaor
"DGM BRZ"
treminaor's Avatar
I'm stumped.
My chances of having someone at the local Subaru narrow down the issue are probably lower than winning the lottery tomorrow. And I don't even buy lottery tickets.
Old 04-16-2017, 12:48 AM   #20
Ultramaroon
not playing cards
Holding out for that Easter miracle.
Old 04-19-2017, 03:06 PM   #21
treminaor
"DGM BRZ"
treminaor's Avatar
I haven't had a chance to lift the car yet (probably will do it today), but I've noticed from more driving that I can make the noise happen reliably if I hold the car at a rock steady RPM for about 4+ seconds and then left off the gas pedal. If I hold it at 4k RPM and let off the gas in 2nd gear it happens nearly every time. If I just rev up to 4k RPM and then let off the gas immediately it usually doesn't happen. Something about holding it there for a few seconds first makes it worse.
Old 04-19-2017, 07:30 PM   #22
humfrz
........ NOW, you have made the problem even more of a mystery .....
humfrz
Old 04-19-2017, 09:51 PM   #23
treminaor
"DGM BRZ"
treminaor's Avatar
Had it up on stands today and shook the front mid and back pipes, no noises.
Old 04-20-2017, 12:14 AM   #24
Ultramaroon
not playing cards
Sorry, Trem. I have nothing. Maybe look at driveline mounts; anything that reacts against engine torque.
Old 04-20-2017, 04:26 PM   #25
treminaor
"DGM BRZ"
treminaor's Avatar
It could just be my ears playing tricks but I could swear it's coming from the rear of the car not the front.
Old 04-20-2017, 09:39 PM   #26
sato
sato's Avatar
Drives: Dodge Patitas
Sure its nothing in the cabin, panel, etc.?
Old 04-20-2017, 09:44 PM   #27
treminaor
"DGM BRZ"
treminaor's Avatar
I don't hear anything with the windows raised, it's from under the car
Old 04-20-2017, 10:11 PM   #28
Ultramaroon
not playing cards
Like maybe a spindle ticking in the hub? Loose spindle nut?
I get some ticking from my brake calipers but it's not such a sharp almost glassy sound like in your recording; which is pretty good, btw.
Clutch Fork Squeaks fantah Hawaii 28 11-07-2018 01:22 PM
Clutch Squeaks at the end of travel... clutch fork? treminaor Issues | Warranty | Recalls / TSB 54 12-02-2016 03:53 AM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
Clutch Fork Broken rick s Issues | Warranty | Recalls / TSB 8 08-27-2015 01:49 PM
Clutch clicking/creaking Bg8780 Issues | Warranty | Recalls / TSB 4 03-24-2015 11:27 PM
