Old 04-15-2017, 10:27 PM   #15
Originally Posted by treminaor View Post
Is there anything I can do to test this theory before I rip out the console?
Not that I know of.
Maybe ol @Ultramaroon has a recent flash .......??
Old 04-15-2017, 11:44 PM   #16
It almost sounds like the tick of an exhaust shield or similar. That you notice it mostly in first makes sense. That's where the driveline twists the most.
I would put it up on stands and while lying underneath it, jiggle the front pipe. It might lead to more inspection but...
Worth a shot.
treminaor (04-16-2017)
Old 04-16-2017, 12:28 AM   #17
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
Worth a shot.
I'll give it a try. The noise doesn't seem to happen going over bumps or potholes so I ruled out anything with suspension.
As far as mostly noticing it more often in first it could also be that in higher gears the RPM is so high I don't hear it over the noise.
treminaor is offline   Reply With Quote
The Following User Says Thank You to treminaor For This Useful Post:
Ultramaroon (04-16-2017)
Old 04-16-2017, 12:29 AM   #18
I'm stumped.
Old 04-16-2017, 12:30 AM   #19
treminaor
"DGM BRZ"
treminaor's Avatar
I'm stumped.
My chances of having someone at the local Subaru narrow down the issue are probably lower than winning the lottery tomorrow. And I don't even buy lottery tickets.
Old 04-16-2017, 12:48 AM   #20
Holding out for that Easter miracle.
Old 04-19-2017, 03:06 PM   #21
treminaor
"DGM BRZ"
treminaor's Avatar
I haven't had a chance to lift the car yet (probably will do it today), but I've noticed from more driving that I can make the noise happen reliably if I hold the car at a rock steady RPM for about 4+ seconds and then left off the gas pedal. If I hold it at 4k RPM and let off the gas in 2nd gear it happens nearly every time. If I just rev up to 4k RPM and then let off the gas immediately it usually doesn't happen. Something about holding it there for a few seconds first makes it worse.
Old 04-19-2017, 07:30 PM   #22
........ NOW, you have made the problem even more of a mystery .....
Old 04-19-2017, 09:51 PM   #23
treminaor
"DGM BRZ"
treminaor's Avatar
Had it up on stands today and shook the front mid and back pipes, no noises.
Ultramaroon (04-20-2017)
Old 04-20-2017, 12:14 AM   #24
Sorry, Trem. I have nothing. Maybe look at driveline mounts; anything that reacts against engine torque.
treminaor (04-20-2017)
Old 04-20-2017, 04:26 PM   #25
treminaor
"DGM BRZ"
treminaor's Avatar
It could just be my ears playing tricks but I could swear it's coming from the rear of the car not the front.
Old 04-20-2017, 09:39 PM   #26
sato
sato's Avatar
Drives: Dodge Patitas
Sure its nothing in the cabin, panel, etc.?
sato is offline   Reply With Quote
Old 04-20-2017, 09:44 PM   #27
treminaor
"DGM BRZ"
treminaor's Avatar
I don't hear anything with the windows raised, it's from under the car
Old 04-20-2017, 10:11 PM   #28
Like maybe a spindle ticking in the hub? Loose spindle nut?
I get some ticking from my brake calipers but it's not such a sharp almost glassy sound like in your recording; which is pretty good, btw.
sato (04-21-2017), treminaor (04-20-2017)
Clutch Fork Squeaks fantah Hawaii 28 11-07-2018 01:22 PM
Clutch Squeaks at the end of travel... clutch fork? treminaor Issues | Warranty | Recalls / TSB 54 12-02-2016 03:53 AM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
Clutch Fork Broken rick s Issues | Warranty | Recalls / TSB 8 08-27-2015 01:49 PM
Clutch clicking/creaking Bg8780 Issues | Warranty | Recalls / TSB 4 03-24-2015 11:27 PM
