#15 | |
humfrz |
#16 | |
Famous Potatoes
Drives: '15 ultramarine
I had it when I had the light flywheel. Went away when I put the stock flywheel back on. |
#17 |
Drives: 2017 Halo 86
This happens even with my completely stock flywheel/driveline. Some say it could be throwout bearing, worst case scenario. Otherwise, either harsh cold weather or gearbox.
Sounds like ice cubes sloshing around in a bowl of cold water. Ironically, this noise only started for me the exact day after switching to Motul300 trans fluid.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#18 |
not playing cards
That's not irony. That's causality. The factory used thick stuff to damp the rattle.
#19 | |
Ironic for my case in particular since many others have run the same fluid with no such aftermath.
#20 |
not playing cards
They just don't talk about it. Everybody that swapped out their fluid hears more noise.
#21 | |
![]() Quote:
#22 | |
not playing cards
Sounds are a good thing. You can more easily hear things when they change. As long as you don't hear any whine when you're on the gas, you're golden.
#23 |
Bubba says that auto makers should have stuck with straight gears … they ALWAYS whine, no matter what oil you use in the transmission.....
![]() humfrz |
| Loud noise from back of car | hypebrz | Issues | Warranty | Recalls / TSB | 20 | 05-31-2016 08:27 AM |
| Loud engine noise? | Rifle | Engine, Exhaust, Transmission | 9 | 08-16-2015 12:26 PM |
| Loud noise when letting off gas? | HachiRo | Issues | Warranty | Recalls / TSB | 5 | 04-19-2015 03:36 AM |
| Loud Buzzing Noise - Car Not Running | Apex_BRZ | Issues | Warranty | Recalls / TSB | 7 | 04-13-2014 05:00 PM |
| FR-S Loud Engine Noise | White0utFrs | Issues | Warranty | Recalls / TSB | 15 | 09-20-2013 08:28 PM |
