Old 07-10-2018, 03:36 PM   #15
Originally Posted by SaulSNES View Post
Hate to bring this back from the dead, but ….
And. Its. Driving. Me. Nuts.
Any leads would be greatly appreciated!
Here ya go ...
Teseo (07-10-2018)
Old 07-10-2018, 05:35 PM   #16
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Hate to bring this back from the dead, but I havent been able to find much (if any) information on what could be the cause of this and a possible solution. Im experiencing the same sound with the AC on, dissapears when I push the clutch in and only hear it when its idling. I thought it maybe had something to do with the lightweight crank pulley, flywheel and driveshaft I recently installed but im seeing that even stock twins are experiencing this noise.
I had it when I had the light flywheel. Went away when I put the stock flywheel back on.
Old 07-10-2018, 11:02 PM   #17
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
This happens even with my completely stock flywheel/driveline. Some say it could be throwout bearing, worst case scenario. Otherwise, either harsh cold weather or gearbox.
Sounds like ice cubes sloshing around in a bowl of cold water.
Ironically, this noise only started for me the exact day after switching to Motul300 trans fluid.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 07-11-2018, 12:16 AM   #18
That's not irony. That's causality. The factory used thick stuff to damp the rattle.
Old 07-11-2018, 12:29 AM   #19
Lakitu
Lakitu's Avatar
Ironic for my case in particular since many others have run the same fluid with no such aftermath.
Old 07-11-2018, 12:43 AM   #20
They just don't talk about it. Everybody that swapped out their fluid hears more noise.
Old 07-12-2018, 03:28 PM   #21
SaulSNES
SaulSNES's Avatar
Here ya go ...
That's why I figured i'd go with factory fluid when I filled my transmission back up yeah. Even still, seems this is just another one of the many unavoidable sounds these cars are known for making
SaulSNES is offline   Reply With Quote
The Following User Says Thank You to SaulSNES For This Useful Post:
humfrz (07-12-2018)
Old 07-12-2018, 03:39 PM   #22
It's not bad with Redline MT90. I didn't change it for the syncros, just a transmission swap.
Sounds are a good thing. You can more easily hear things when they change. As long as you don't hear any whine when you're on the gas, you're golden.
Old 07-12-2018, 09:14 PM   #23
Bubba says that auto makers should have stuck with straight gears … they ALWAYS whine, no matter what oil you use in the transmission.....
Loud noise from back of car hypebrz Issues | Warranty | Recalls / TSB 20 05-31-2016 08:27 AM
Loud engine noise? Rifle Engine, Exhaust, Transmission 9 08-16-2015 12:26 PM
Loud noise when letting off gas? HachiRo Issues | Warranty | Recalls / TSB 5 04-19-2015 03:36 AM
Loud Buzzing Noise - Car Not Running Apex_BRZ Issues | Warranty | Recalls / TSB 7 04-13-2014 05:00 PM
FR-S Loud Engine Noise White0utFrs Issues | Warranty | Recalls / TSB 15 09-20-2013 08:28 PM
