#15 |
Drives: 2016 STI DGM
I know the 86 is supposed to be a light weight sports car, but I always wished it had adaptive headlights that moved with the steering... Hell, all cars should!
Subaru STI :![]() |
#16 |
I have never heard of auto-leveling headlights in the USDM versions. for my MY15, there's a scroll wheel next to the trunk release to change headlight levels. there's also a manual adjustment behind the actual headlight housing.
| The Following User Says Thank You to ryoma For This Useful Post: | Apoc (07-01-2017) |
#17 |
Drives: 2012 GT86 EU-spec
Auto leveling is usually combined with HID, halogen gets the scroll wheel.
#18 |
must be the EUDM and JDM ones then. USDM definitely doesn't have it. you guys also got the headlight washers too... all the cool stuff are overseas lol
#19 |
Drives: '17 Toyota 86
The USDM '17's do have automatic leveling, it's a sensor connected to the left rear control arm. I didn't reinstall mine after swapping out control arms since there really wasn't a spot for it, and I didn't know what it was, and my beams got pretty freaky. I personally love the new headlights, they're a nice wide beam, too bright, and I don't have that dead spot you mentioned.
| The Following User Says Thank You to TheLowlyThird For This Useful Post: | murdoc (04-10-2017) |
#20 | |
Drives: 2017 Subaru BRZ PP
The dead spot is me being picky. Comparing it to other cars I've owned, as well as the HIDs on previous year twins. I assure you guys my lights aren't malfunctioning. Like I said above they're great for on-road use other than the low beams being aimed too high and getting high beamed all the time by oncoming traffic. I suppose an interesting project would be to see if I could manipulate that sensor, or sensor signal to make the automatic levelers do my bidding For now, here is what I have come up with as a fix. One of these under each fog light, facing up and out https://www.amazon.com/gp/product/B00T8UY53Q And one of these in the grill, facing up https://www.amazon.com/Auxbeam-7200l.../dp/B00T7GYDTC |
#21 | |
You shouldn't need all those lights. Have your eyes checked if you need that much light.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | VIP BRZ (04-11-2017) |
#22 |
Drives: 2014 Subaru BRZ
#23 | |
Drives: 2014 FR-S
These are made for off road or work vehicles that need a full beam pattern in front of them, lighting up everything. You will blind so many people coming the other way. And you live in Cali, the cops will be on you like a fat kid to cake. This is a very poor option. |
#24 |
In California you'd actually have to have the light covered every time you get on the highway.
24411. Notwithstanding any other provision of law, a vehicle may be equipped with not more than eight lamps for use as headlamps while the vehicle is operated or driven off the highway. The lamps shall be mounted at a height of not less than 16 inches from the ground, or more than 12 inches above the top of the passenger compartment, at any place between the front of the vehicle and a line lying on a point 40 inches to the rear of the seat occupied by the driver, shall be wired independently of all other lighting circuits, and, whenever the vehicle is operated or driven upon a highway, shall be covered or hooded with an opaque hood or cover, and turned off. |
| The Following User Says Thank You to VIP BRZ For This Useful Post: | Var (04-11-2017) |
#25 | |
Researched beam patterns and decided to try flood first Do you have any better ideas? |
#26 | |
#27 | |
[ame="https://www.youtube.com/watch?v=wjHttdyw7EE"]Rally Lights Explained - YouTube[/ame] If you're not interested in rally lighting, go read a different thread? Thanks for your helpful opinion |
#28 |
Drives: between cars...
I know this idea is overly technical, but it would be cool to tap into the steering angle sensor to have the right and left pointing lights to turn on and off when cornering...
FYI. my wife's 2015 Outback does that with its foglights from the factory, There's a button on the dash for SRF, steering responsive fog-lights. |
| 2017 Toyota 86 recommended oil change at 16,000km | rkaywhodat | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 21 | 01-26-2017 11:24 PM |
| WTB OEM FRS headlights preferably painted black housings | 420zn6 | Want-To-Buy Requests | 0 | 12-17-2016 01:00 AM |
| Valenti / Lexon / Tom Tail lights, Winjet Headlights, Front Bumper lights and Mirrors | Speed Element | Exterior Parts - Lighting | 224 | 12-06-2016 03:07 PM |
| NEW EXCLUSIVE Valenti Tail lights, Winjet Headlights, Front Bumper lights and Mirrors | Speed Element | Northern California | 34 | 01-14-2015 06:32 PM |
| FS: FRS fog light housings and glass lense fog lights. | Alliedforces86 | Exterior Parts (Aero, Lighting, Etc.) | 6 | 10-11-2013 11:18 AM |
